查看: 6438|回復(fù): 4
關(guān)于51單片機(jī)存儲FLASH的問題
ID:239793 發(fā)表于 2019-1-16 10:21 | 顯示全部樓層 |閱讀模式
50黑幣
STC89C52 STC12 STC15 STC8系列等 串口接收到數(shù)據(jù) 如何存儲在FLASH中 然后換串口或者 在此串口中換器件 并且發(fā)送存儲的數(shù)據(jù)。求資料,求程序,或者指教下該去看哪方面的東西。
ID:469039 發(fā)表于 2019-1-16 11:39 | 顯示全部樓層
直接看數(shù)據(jù)手冊,中間Flash編程部分詳細(xì)看。網(wǎng)上例程非常多。
ID:7485 發(fā)表于 2019-1-16 14:58 | 顯示全部樓層
數(shù)據(jù)手冊中有示范程序,可以直接套用。
ID:386762 發(fā)表于 2019-1-16 15:04 | 顯示全部樓層
ID:281071 發(fā)表于 2019-1-16 15:26 | 顯示全部樓層
給一個STC8的作為參考
u8 iap_byte_rd(u16 addr)
    u8  tmp;
    F0 = EA;
    EA = 0;
    IAP_CONTR = 0x80;
    IAP_CMD   = 1;
    IAP_ADDRH = (u8)(addr >> 8);
    IAP_ADDRL = addr;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    tmp       = IAP_DATA;
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
    return tmp;
void iap_byte_wr(u16 addr, u8 val)
    F0 = EA;
    EA = 0;
    IAP_CONTR = 0x80;
    IAP_CMD   = 2
    IAP_ADDRL = addr;
    IAP_DATA  = val;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
void iap_sec_erase(u16 addr)
    F0 = EA;
    EA = 0;
    IAP_ADDRL = addr;
    IAP_CONTR = 0x80;
    IAP_CMD   = 3;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
