查看: 1327|回復: 0
明遠智睿MY-IMX6 Linux-4.1.15 編譯參考手冊(2)
ID:295355 發表于 2019-1-16 10:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
【接上一章節明遠智睿MY-IMX6 Linux-4.1.15 編譯參考手冊】
3  u-boot編譯3.1  編譯前的準備
創建編譯工作目錄
=====> Input:
mkdir ~/my-work/02_source/ -p
解壓源碼包到工作目錄
=====> Input:
tar xf u-boot-2016.03-svn*.tar.bz2 -C ~/my-work/02_source/
3.2  編譯u-boot目標文件
進入源碼目錄
=====> Input:
cd ~/my-work/02_source/u-boot-2016.03
生成目標開發板的 .config 文件
=====> Input:
make myimx6ek140p-6y-256m-emmc_defconfig
=====> Output:
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
【注意】:上面 make 后面的 myimx6ek140p-6y-256m-emmc_defconfig 改為與開發板型號對應的配置文件。
********** MY-IMX6-EK140 **********
myimx6ek140-6g-128m-emmc_defconfig  myimx6ek140-6y-128m-emmc_defconfig
myimx6ek140-6g-128m-nand_defconfig  myimx6ek140-6y-128m-nand_defconfig
myimx6ek140-6g-256m-emmc_defconfig  myimx6ek140-6y-256m-emmc_defconfig
myimx6ek140-6g-256m-nand_defconfig  myimx6ek140-6y-256m-nand_defconfig
myimx6ek140-6g-512m-emmc_defconfig  myimx6ek140-6y-512m-emmc_defconfig
myimx6ek140-6g-512m-nand_defconfig  myimx6ek140-6y-512m-nand_defconfig
********** MY-IMX6-EK140P **********
myimx6ek140p-6g-128m-emmc_defconfig  myimx6ek140p-6y-128m-emmc_defconfig
myimx6ek140p-6g-128m-nand_defconfig  myimx6ek140p-6y-128m-nand_defconfig
myimx6ek140p-6g-256m-emmc_defconfig  myimx6ek140p-6y-256m-emmc_defconfig
myimx6ek140p-6g-256m-nand_defconfig  myimx6ek140p-6y-256m-nand_defconfig
myimx6ek140p-6g-512m-emmc_defconfig  myimx6ek140p-6y-512m-emmc_defconfig
myimx6ek140p-6g-512m-nand_defconfig  myimx6ek140p-6y-512m-nand_defconfig
********** MY-IMX6-EK200 **********
myimx6ek200-6q-1g_defconfig     myimx6ek200-6q-2g_defconfig     myimx6ek200-6q-512m_defconfig
myimx6ek200-6u-1g_defconfig     myimx6ek200-6u-2g_defconfig     myimx6ek200-6u-512m_defconfig
myimx6ek200-6s-512m_defconfig   myimx6ek200-6s-1g_defconfig     myimx6ek200-6s-128m_defconfig
myimx6ek200-6qp-1g_defconfig    myimx6ek200-6qp-2g_defconfig    myimx6ek200-6qp-512m_defconfig
********** MY-IMX6-EK314 **********
myimx6ek314-6q-1g_defconfig     myimx6ek314-6q-2g_defconfig     myimx6ek314-6q-512m_defconfig
myimx6ek314-6u-1g_defconfig     myimx6ek314-6u-2g_defconfig     myimx6ek314-6u-512m_defconfig
myimx6ek314-6s-512m_defconfig   myimx6ek314-6s-1g_defconfig     myimx6ek314-6s-128m_defconfig
myimx6ek314-6qp-1g_defconfig    myimx6ek314-6qp-2g_defconfig    myimx6ek314-6qp-512m_defconfig
********** MY-IMX6-EK336 **********
myimx6ek336-6q-1g_defconfig     myimx6ek336-6q-2g_defconfig     myimx6ek336-6q-512m_defconfig
執行編譯
=====> Input:
make
=====> Output:
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config.h
  UPD     include/config.h
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
  CHK     include/config/uboot.release
  CHK     include/generated/timestamp_autogenerated.h
  CFG     u-boot.cfg
  LD      u-boot
  OBJCOPY u-boot-nodtb.bin
  OBJCOPY u-boot.srec
  SYM     u-boot.sym
  COPY    u-boot.bin
  CFGS    board/myzr/myimx6/myimx6a7-6y-ddr3.cfg.cfgtmp
  MKIMAGE u-boot.imx
Note: 如果有提示 “cc1: error”,通常是交叉編譯工具的配置沒生效,可以按前面 “交叉編譯工具鏈安裝” 中的 “source 工具鏈配置文件” 操作一次后再執行此步驟。
· u-boot 目標文件
u-boot.imx 即目標文件。
3.3  編譯u-boot環境變量腳本
=====> Input:
mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "myzr bootscripts" -d board/myzr/bootscripts/myimx6a7_l4115_emmc_script.cmd my_environment_emmc.scr
=====> Output:
Image Name:   myzr bootscripts
Created:      Wed Jan  2 09:40:40 2019
Image Type:   ARM Linux Script (uncompressed)
Data Size:    1450 Bytes = 1.42 kB = 0.00 MB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 1442 Bytes = 1.41 kB = 0.00 MB
3.4  目標文件
u-boot.imx 和 my_environment_emmc.scr 即編譯得到的目標文件,保存這兩個文件
4  內核編譯4.1  編譯前的準備
創建編譯工作目錄
=====> Input:
解壓源碼包到工作目錄
=====> Input:
tar xf linux-4.1.15-svn*.tar.bz2 -C ~/my-work/02_source/
4.2  編譯內核目標文件
進入內核源碼目錄
=====> Input:
cd ~/my-work/02_source/linux-4.1.15
生成目標平臺的 .config 文件
=====> Input:
make myimx6a9_defconfig
=====> Output:
Note: 如果有“Can't find default configuration "arch/x86/configs” 的錯誤,是因為交叉編譯工具鏈的配置沒有生效,可以按前面 “交叉編譯工具鏈安裝” 中的 “source 工具鏈配置文件” 操作一次后再執行此步驟
【注意】:上面 make 后面的 myimx6a7_defconfig 改為與開發板型號對應的配置文件。
********** MY-IMX6-EK140、MY-IMX6-EK140P **********
myimx6a7_defconfig
********** MY-IMX6-EK200、MY-IMX6-EK314、MY-IMX6-EK336 **********
myimx6a9_defconfig
編譯內核目標文件
=====> Input:
make zImage
=====> Output:
  CHK     include/config/kernel.release
  UPD     include/config/kernel.release
  WRAP    arch/arm/include/generated/asm/auxvec.h
  AS      arch/arm/boot/compressed/piggy.lzo.o
  LD      arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
內核目標文件
arch/arm/boot/zImage 即內核目標文件
【下章節為明遠智睿MY-IMX6 Linux-4.1.15 編譯參考手冊(3)】
