查看: 2239|回復: 2
PIC12F675單片機奇怪問題
ID:206067 發表于 2019-1-13 02:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序目的是實現上電燈就亮”輸出1“ 定時后”輸出0“
#include<pic.h>
#include <xc.h>
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF      // GP3/MCLR pin function select (GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#define KEY GP3
unsigned char count=0;
unsigned char miao=0;
unsigned char fen=0;
    OSCCAL=0b00000100;//intside RC
    TRISIO=0b00001000;//IO方向設置
    OPTION_REG=0b00000111;//分頻比1:256
    TMR0=0;
    GP0=1;
  //  GP1=GP2=GP4=GP5=0;  寫進這行燈就一直不亮,不寫就是正常的
            if(TMR0==180)//50ms
                TMR0=0;
                count++;
                if(count==20)//1秒定時
                    miao++;
                    count=0;
                    if(miao==5)
                        miao=0;
                        GP0=0;
ID:206067 發表于 2019-1-21 11:35 | 只看該作者
有人知道嗎
ID:138119 發表于 2019-1-27 11:16 | 只看該作者
印象中我也遇到過類似問題,很久了,記得可能是編譯器優化級別的問題。
