查看: 2426|回復: 1
請教各位大佬解決一下OLED點不亮的問題.C和.H文件如下
ID:434093 發表于 2019-1-10 11:30 | 顯示全部樓層 |閱讀模式
OLED.c
#include "OLED.h"
#include "delay.h"
#include "codetab.h"
void OLED_SPI_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP ;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void OLED_SPI_WriteByte(unsigned char data,unsigned char cmd)
    unsigned char i=0;
    OLED_DC =cmd;
//    OLED_CLK=0;
    for(i=0;i<8;i++)
        OLED_CLK=0;
        if(data&0x80)OLED_MOSI=1;
        else OLED_MOSI=0;
        OLED_CLK=1;
        data<<=1;
//    OLED_CLK=1;
//    OLED_DC=1;
void WriteCmd(unsigned char cmd)
    OLED_SPI_WriteByte(cmd,OLED_CMD);
void WriteData(unsigned char data)
    OLED_SPI_WriteByte(data,OLED_DATA);
//OLED_SPIÄ£ÄaSPI3ìDòíê±Ï
void OLED_Init(void)
        OLED_SPI_Init();
        OLED_CLK = 1;
  OLED_RST = 0;
        delay_ms(1000);
        OLED_RST = 1;
        WriteCmd(0xAE); //display off
        WriteCmd(0x20);        //Set Memory Addressing Mode
        WriteCmd(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        WriteCmd(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        WriteCmd(0xc8);        //Set COM Output Scan Direction
        WriteCmd(0x00); //---set low column address
        WriteCmd(0x10); //---set high column address
        WriteCmd(0x40); //--set start line address
        WriteCmd(0x81); //--set contrast control register
        WriteCmd(0xff); //l亮度0x00~0xff
        WriteCmd(0xa1); //--set segment re-map 0 to 127
        WriteCmd(0xa6); //--set normal display
        WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
        WriteCmd(0x3F); //
        WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        WriteCmd(0xd3); //-set display offset
        WriteCmd(0x00); //-not offset
        WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
        WriteCmd(0xf0); //--set divide ratio
        WriteCmd(0xd9); //--set pre-charge period
        WriteCmd(0x22); //
        WriteCmd(0xda); //--set com pins hardware configuration
        WriteCmd(0x12);
        WriteCmd(0xdb); //--set vcomh
        WriteCmd(0x20); //0x20,0.77xVcc
        WriteCmd(0x8d); //--set DC-DC enable
        WriteCmd(0x14); //
        WriteCmd(0xaf); //--turn on oled panel
        OLED_SetPos(0,0);
void OLED_ON(void)//½«OLED′óDYÃßÖD»½DÑ
        WriteCmd(0x8D);
        WriteCmd(0x14);
        WriteCmd(0xAF);
void OLED_OFF(void)
        WriteCmd(0X8D);
        WriteCmd(0X10);
        WriteCmd(0XAE);
void OLED_SetPos(unsigned char x, unsigned char y)
        WriteCmd(0xb0+y);
        WriteCmd(((x&0xf0)>>4)|0x10);
        WriteCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char fill_Data)
        unsigned char m,n;
        for(m=0;m<8;m++)
                WriteCmd(0xb0+m);                //page0-page1
                WriteCmd(0x00);                //low column start address
                WriteCmd(0x10);                //high column start address
                for(n=0;n<128;n++)
                                WriteData(fill_Data);
void OLED_CLS(void)
        OLED_Fill(0x00);
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
        unsigned char c = 0,i = 0,j = 0;
        switch(TextSize)
                case 1:
                        while(ch[j] != '\0')
                                c = ch[j] - 32;
                                if(x > 121)//126
                                        x = 0;
                                        y++;
                                OLED_SetPos(x,y);
                                for(i=0;i<6;i++)
                                        WriteData(F6x8[c][ i]);[ i]
                                x += 6;
                                j++;
                }break;
                case 2:
                                c = ch[j] - 32;
                                if(x > 119)//120
                                        x = 0;
                                        y++;
                                OLED_SetPos(x,y);
                                for(i=0;i<8;i++)
                                        WriteData(F8X16[c*16+i]);
                                OLED_SetPos(x,y+1);
                                for(i=0;i<8;i++)
                                        WriteData(F8X16[c*16+i+8]);
                                x += 8;
                                j++;
                }break;
void OLED_ShowNum(unsigned char x, unsigned char y, float num, unsigned char TextSize)
        unsigned char i;
        unsigned char result[9];
        unsigned int  tempH;
        unsigned char tempL;
        result[8]='\0';
        result[3]='.';
        if(num<0)
                result[0]='-';
                num=-num;
        else result[0]=' ';
        tempH = (unsigned int)num;
        tempL = (unsigned char)(num*100 - tempH*100);
        result[2] = tempH%10 + '0';tempH/=10;
        result[1] = tempH + '0';
        result[7] = tempL%10 + '0';tempL/=10;
        result[6] = tempL%10 + '0';tempL/=10;
        result[5] = tempL%10 + '0';tempL/=10;
        result[4] = tempL + '0';
        if(result[1]=='0')result[0]=' ';
        for(i=7;i<4;i--)
                if(result[ i]=='0')[ i]
                  if(i==7)
                        result[ i]=' ';
                        else if(i==6)
                                    if(result[7]=='0')result[ i]=' ';
                                          result[ i]='0';
                                         else if(i==5)
                                                      if(result[7]=='0'& result[6]=='0')result[ i]=' ';
                                                result[ i]='0';
                                              else if(i==4)
                                                           if(result[7]=='0'& result[6]=='0' & result[5]=='0')result[ i]=' ';
                                                     result[ i]='0';
                        break;
        OLED_ShowStr(x,y,result,TextSize);
OLED.h
#ifndef __OLED_H
#define        __OLED_H
#include "sys.h"
#define OLED_CMD 0
#define OLED_DATA 1
#define OLED_CLK    PBout(7)    // CLK
#define OLED_MOSI   PBout(6)    // SDA(MOSI)
#define OLED_RST    PBout(4)    // RES
#define OLED_DC     PBout(5)
void OLED_SPI_Init(void);
void OLED_SPI_WriteByte(unsigned char data,unsigned char cmd);
void WriteCmd(unsigned char cmd);
void WriteData(unsigned char data);
void OLED_Init(void);
void OLED_ON(void);
void OLED_OFF(void);
void OLED_SetPos(unsigned char x, unsigned char y);
void OLED_Fill(unsigned char fill_Data);
void OLED_CLS(void);
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize);
void OLED_ShowNum(unsigned char x, unsigned char y, float num, unsigned char TextSize);
#endif
ID:434093 發表于 2019-1-10 11:31 | 顯示全部樓層
main函數中已經while(1) OLED_Fill(0xff);
