查看: 2269|回復: 0
基于51單片機 10秒的秒表
ID:464253 發表于 2019-1-9 22:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
十秒秒表代碼如下:
#include <reg52.h>
sbit K1 = P3^7;
uchar i,Second_Counts,Key_Flag_Idx;
bit Key_State;
uchar DSY_CODE[]=
        0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
void DelayMS(uint ms)
        uchar t;
        while(ms--)
                 for(t=0;t<120;t++);
void Key_Event_Handle()
        if(Key_State == 0)
                 Key_Flag_Idx=(Key_Flag_Idx+1)%3;
                switch(Key_Flag_Idx)
                         case 1:EA=1;ET0=1;TR0=1;break;
                        case 2:EA=0;ET0=0;TR0=0;break;
                        case 0:P0=0x3f;P2=0x3f;i=0;Second_Counts=0;
        P0 = 0x3f;
        P2 = 0x3f;
        i = 0;
        Second_Counts = 0;
        Key_State = 1;
        TMOD = 0x01;
        TH0  = (65535-50000)/256;
        TL0  = (65535-50000)%256;
                 if(Key_State != K1)
                         DelayMS(10);
                        Key_State = K1;
                        Key_Event_Handle();
void DSY_Refresh() interrupt 1
        if(++i==2)
                 i = 0;
                ++Second_Counts;
                P0 = DSY_CODE[Second_Counts/10];
                P2 = DSY_CODE[Second_Counts%10];
                if(Second_Counts == 100) Second_Counts = 0;
10秒的秒表.zip
45.04 KB, 下載次數: 8, 下載積分: 黑幣 -5
