查看: 4442|回復: 4
HC6800-ES V2.0單片機DS1302可調電子時鐘程序
實現的功能如下(無鬧鐘功能)。實物圖和工程文件在壓縮包
制作出來的實物圖如下:
1302顯示可調時間日期+設置鬧鐘
  1. //顯示格式24-35-25 ,小時-分鐘-秒鐘, 按下S3后,顯示年月日,2017.09.10,延時6秒后返回
  2. #include <reg52.h>
  3. #include <intrins.h>
  5. #define uint unsigned  int
  6. #define sce   timedate[1]
  7. #define min   timedate[2]
  8. #define hour  timedate[3]
  9. #define date  timedate[4]
  10. #define week  timedate[6]
  11. #define month timedate[5]
  12. #define year  timedate[7]
  13. uchar displaychar1[8]={0,1,2,3,4,5,6,7},a,ya,ja ;                                         //a結尾的字符都用來專門延時,a通用,ya日期延時程序用
  14. uchar commandchar[9]={0,0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e};                  //與timedate對應,分別控制每個寄存器的寫,讀時數組+1,第8個數是控制寫保護位
  15. uchar timedate[8],sdat,seta,m;
  16. bit s,s2,s3,s4,K,setbit,sk;
  17. sbit d = P2^6;
  18. sbit w = P2^7;
  19. sbit S2 = P3^0;
  20. sbit S3 = P3^1;
  21. sbit S4 = P3^2;
  22. sbit SCLK = P3^3;
  23. sbit TIO  = P3^4;
  24. sbit TRST = P3^5;
  25. uchar LD = 1;             //************數碼管,亮度調節,0最小,10最高,越亮越閃 因會影響開始信號查詢時間,建議最高設置為3**************
  26. unsigned char code duan[]=
  27. {                0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x00                };           //段選碼0-9
  28. void timeout(uchar a)
  29. {
  30.    uchar b;
  31.    for(;a>0;a--)
  32.                 for(b=114;b>0;b--);
  33. }
  34. void timeout5us()
  35. {
  36.         _nop_();
  37. }
  38. void display()                                           //兩個數,分別記錄鍵值和重復碼個數
  39. {
  40.
  41.         P0 = 0xfe;                                         w = 1;          w = 0;    //顯示1位
  42.         P0 = (displaychar1[0]);                d = 1;                 d = 0;
  43.         timeout(LD);
  44.         P0 = 0;                                                d = 1;                d = 0;                                                            //清除段選
  45.
  46.         P0 = 0xfd;                                  w = 1;                 w = 0;    //顯示2位
  47.         P0 = displaychar1[1];                 d = 1;                d = 0;
  48.         timeout(LD);
  49.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段選
  50.         P0 = 0xfb;                                  w = 1;                 w = 0;   //顯示3位
  51.         P0 = displaychar1[2];                d = 1;                 d = 0;
  52.         timeout(LD);
  53.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段選
  54.         P0 = 0xf7;                                        w = 1;                w = 0;   //顯示4位
  55.         P0 = displaychar1[3];                d = 1;                 d = 0;
  56.         timeout(LD);
  57.         P0 = 0;                                                d = 1;                d = 0;                                                        //清除段選,否則下一個位選變化后由于段選沒變會將此位信息顯示到下一個位。
  58.
  59.         P0 = 0xef;                                        w = 1;          w = 0;   //顯示5位
  60.         P0 = displaychar1[4];                d = 1;                d = 0;
  61.         timeout(LD);
  62.         P0 = 0;                                                d = 1;                d = 0;                                                          //清除段選
  63.
  64.         P0 = 0xdf;                                         w = 1;                 w = 0;   //顯示6位
  65.         P0 = displaychar1[5];                d = 1;                d = 0;
  66.         timeout(LD);
  67.         P0 = 0;                                                d = 1;                 d = 0;                                                  //清除段選
  68.         P0 = 0xbf;                                         w = 1;                w = 0;   //顯示7位
  69.         P0 = displaychar1[6];                 d = 1;                 d = 0;
  70.         timeout(LD);
  71.         P0 = 0;                                                d = 1;                 d = 0;                                                  //清除段選
  72.         P0 = 0x7f;                                        w = 1;                w = 0;  //顯示8位
  73.         P0 = displaychar1[7];                d = 1;                d = 0;
  74.         timeout(LD);
  75.         P0 = 0;                                                d = 1;                d = 0;                                                        //清除段選,否則下一個位選變化后由于段選沒變會將此位信息顯示到下一個位。
  76.
  77. }
  78. /************************************************************************************
  79. -------------------------------以下是與時鐘芯片的數據時序---------------------------*/
  80. //寫控制和一個字節
  81. void sendchar(uchar csdat,uchar sdat)
  82. {        SCLK = 0;
  83.         TRST = 1;
  84.         for(a=0;a<8;a++)
  85.         {
  86.                 SCLK = 0;
  87.                 TIO  = (csdat%2);
  88.                 SCLK = 1;
  89.                 csdat >>=1;
  90.         }
  91.         for(a=0;a<8;a++)
  92.         {
  93.                 SCLK = 0;
  94.                 TIO  = (sdat%2);
  95.                 SCLK = 1;
  96.                 sdat >>=1;
  97.         }
  98.         SCLK = 0;
  99.         TRST = 0;
  100. }
  101. //讀一個字節
  102. uchar receviechar(uchar crdat)
  103. {
  104.         uchar rdat;
  105.         TRST = 1;
  106. //        TIO  = 1;
  107.         TRST = 1;
  108.         for(a=0;a<8;a++)
  109.         {
  110.                 SCLK = 0;
  111.                 TIO  = (crdat%2);
  112.                 SCLK = 1;
  113.                 crdat >>=1;
  114.         }
  115.         for(a=0;a<8;a++)
  116.         {
  117.                 SCLK =   1;
  118.                 rdat >>= 1;
  119.                 SCLK =   0;
  120.
  121.                 if(TIO)
  122.                         rdat = rdat|0x80;
  123.         }
  124.         SCLK = 0;        TRST = 0;
  125.         return rdat ;
  126. }
  127. //讀取時分秒
  128. void readtime()
  129. {
  130.         sendchar(0x8e,0);
  131.         hour = receviechar(0x85);
  132.         min  = receviechar(0x83);
  133.         sce  = receviechar(0x81);
  134.         sendchar(0x8e,0x80); //
  135.
  136. }
  137. //讀取年月日
  138. void readyear()
  139. {
  140.         sendchar(0x8e,0);
  141.         date = receviechar(0x87);
  142.         month  = receviechar(0x89);
  143.         year  = receviechar(0x8d);
  144.         sendchar(0x8e,0x80);         //
  145.
  146. }
  147. //=========================鍵盤掃描,用定時器延時================================
  148. bit jianpan(K)
  149. {
  150.         if((!K)&TF0)    //如果S2按下且計時器0溢出
  151.                 {
  152.                         TF0 = 0;
  153.                         ja++;
  154.                         if(ja>=2)
  155.                                 {//        P1 = 0;
  156.                                         TR0 = 0;                    //每次按下后都會關閉定時器,后面的程度會檢測松手,松開按鍵后會重新打開定時器,可以保護每次按下只起作用一次
  157.                                         ja = 0;
  158.                                         s = 1;
  159.                                 }
  160.                         return s;
  161.                 }
  162.         return s;
  163. }
  164. //===========================================================================================================
  165. //**********************************************設置時間日期子函數*******************************************
  166. //===========================================================================================================
  167. void settime()
  168. {
  169. //        uchar sdat,seta;
  170. //        bit sk;
  171.         setbit=1;                                           //設置控制標識,進本函數后先就讓標識打開,在下面延時跳出前都會一直跳入設置功能函數
  172.         if(TF1&(s2==s3==s4==0))                          //沒有按鍵按下時用定時器1來延時跳出
  173.         {
  174.                 TF1=0;
  175.                 seta ++;
  176.         }
  177.         if(!(s2==s3==s4==0))        seta = 0;        //延時時間超過一定值,或者有按鍵被按下(注意!這個符號)時,時間會被延長
  178.         if(s3); //P1++;                                                  //P1++無用:調試軟件時檢測運行的次數
  179.         if(seta>=70)
  180.         {
  181.                 setbit=0;                                          //關閉設置
  182.                 sdat = 0;
  183.         }
  184.         if(sk!=s2)                                              //sk用來做s2的中間暫存數據,用來用來識別S2是否變化過
  185.         {
  186.                 sk = s2;
  187.                 if(s2)
  188.                 sdat ++;                                               //每次進行一次S2動作時才自加一次SDTA
  189.                 if(sdat ==6)sdat=7;                         //跳過星期,本程序不顯示星期
  190.         }
  191.         m = timedate[sdat]/16*10+timedate[sdat]%16;                          //m用10進制存下
  192.         if(s3) m--;
  193.         if(s4) m++;
  194.         switch (sdat)                                                   //每次進入設置的對應操作判斷
  195.         {
  196.         case 1:
  197.                 if(m>59) m = 0;                                break;
  198.         case 2:
  199.                 if(m>59) m = 0;                                break;
  200.         case 3:
  201.                 if(m>23) m = 0;                                break;
  202.         case 4:
  203.                 if(timedate[5]==4|timedate[5]==6|timedate[5]==9|timedate[5]==11)  //小月
  204.                 {
  205.                         if(m>30) m = 1;                        break;
  206.                 }
  207.                 if(timedate[5]==2&(timedate[7]%4==0))                                                  //閏年2月
  208.                 {
  209.                         if(m>29) m=1;         P1++;                break; //
  210.                 }
  211.                 if(timedate[5]==2&(timedate[7]%4!=0))                                                  //平年2月
  212.                 {
  213.                         if(m>28) m=1;                        break;
  214.                 }
  215.                 if(m>31) m =1;                                break;                                                          //其它月分情況
  216.         case 5:
  217.                 if(m>12) m = 1;                                 break;
  218.         case 6:                 sdat++;                                           //跳過星期本程序不顯示星期
  219.                 if(m>7)  m = 1;                                 break;
  220.         case 7:
  221.                 if(m>99) m = 0;                                 break;
  222.         default : /****不在判斷范圍的進行初始化處理*/
  223.                 sdat = 0; sk=0; setbit = 0;s2 = 0;//        P1++;        //本程序所有P1++都是測試軟件運行情況用                                  //每次在不滿足條件時自動讓數據初始化,
  224.        break;
  225.                                                    //s2=0是優化點,在按下S2后按鍵標識不會清零,松手時程序已重復運行了很多遍,所以會重新跳回設置的第一位,加本命令可以讓設置判斷失效,不進設置頁。
  226.         }
  227.         //==================================
  228.         //setbit為1則說明以上有成立的條件,需要發送修改數據
  229.         if(setbit)
  230.         {
  231.                 sendchar(0x8e,0);        //去寫保護
  232.                 sendchar(commandchar[sdat],m/10*16+m%10);                                                //將改好的數字發送到1302
  233.                 sendchar(0x8e,0x80);        //加寫保護
  234.
  235.                 if(seta%5>2&seta<50)
  236.                 timedate[sdat] = 0xbb;        //設置延時操作期間控制閃爍時間
  237.         }                                          //顯示空,對應段選的兩位11;0xbb/16=11,0xbb%16=11  ,而上面段選數組中第12個數是顯示空
  238. //寫程序時用的測試語句,無用時未刪供復習時看看當時的思路
  239. /*        switch (sdat)
  240.         {
  241.                 case 1:
  242.                 P1=0xfe;
  243.                 m = sce;
  244.                 if(s4) m++;
  245.                 if(s3) m--;
  246.
  247.                            break;
  248.                 case 2:
  249.                 P1=0xfd;                   break;
  250.                 case 3:
  251.                 P1=0xfb;                   break;
  252.                 case 4
  253.                 :P1=0xf7;                   break;
  254.                 case 5:
  255.                 P1=0xef;                   break;
  256.                 case 6:
  257.                 P1=0xdf;                   break;
  258.                 case 7:
  259.                 P1=0xbf;                   break;
  260.                 case 8:
  261.                 P1=0x7f;                   break;
  262.                 default :
  263.                 sdat = 0;sk=0;                                //每次在不滿足條件時自動讓數據初始化,
  264.                 break;
  265.         } */
  266. }
  267. //===================================================================================
  268. //============================== 主函數==============================================
  269. main()
  270. {
  271.
  272.         SCLK = 0 ;
  273.         TRST = 0 ;
  274.         readyear();        //讀取年月日
  275.         if(year!=0x17)        //如果不是2017年,就初始化1302        ,給初值是17年10月03日,12:11:15
  276.         {
  277.                 sendchar(0x8e,0);
  278.                 sendchar(0x80,0x15);
  279.                 sendchar(0x82,0x11);
  280.                 sendchar(0x84,0x12);
  281.
  282.                 sendchar(0x86,0x03);
  283.                 sendchar(0x88,0x10);
  284.                 sendchar(0x8c,0x17);
  285.                 sendchar(0x8e,0x80);
  286.         }
  287.         TMOD = 0x12;                   //設置定時器工作模式
  288.         TR1 = 1;
  289.         TR0 = 1;
  290.         while(1)
  291.         {
  292.                 if(!S2) s2 = jianpan(S2);
  293.                 if(!S3) s3 = jianpan(S3);
  294.                 if(!S4) s4 = jianpan(S4);
  295.
  296.                 TRST = 0;
  297.         /*以下是開始年月日自動歸零的問題修改,問題產生原因是開始沒有加!setbit這個條件,程序在運行到設置年月日時依然會進
  298.           入下面這個判斷,然后再進入設置,但是年月日在這里還沒有讀數,所以這里的設置就會進入M=0然后加或減,從而讓設置值
  299.           出現錯誤
  300.         */
  301.                 if((!ya&(!setbit)&(!s3))|(setbit&(sdat<4)))                                         //如果S2沒有被按下且不在顯示年月日的延時范圍,而且設置標識為0時,或者在標識為1但是設置值在123中時,則正常顯示時間格式
  302.                 {
  303.                         readtime();         //P1++;           //先讀一下時間然后再判官設置程序,這樣的主要目的是讓初m的值由1302決定。
  304.                         if(s2|setbit)                        //按下S2或設置標識打開時會進入本判斷
  305.                         {
  306.                                 ya = 0;
  307.                                 settime();
  308.                         }
  309.                         displaychar1[0] = duan[hour/16];
  310.                         displaychar1[1] = duan[hour%16];
  311.                         displaychar1[2] = duan[10];
  312.                         displaychar1[3] = duan[min/16];
  313.                         displaychar1[4] = duan[min%16];
  314. ……………………
  315. …………限于本文篇幅 余下代碼請從51黑下載附件…………
單片機DS1302可調電子時鐘.rar (214.88 KB, 下載次數: 52)
ID:619942 發表于 2019-12-23 11:17 | 只看該作者
實驗程序很方便,就是還沒上去試試行不行
自己技術太差了,需要師兄們幫助啊、~~~~~
ID:619942 發表于 2019-12-23 12:53 | 只看該作者
感覺這個程序還是太長了點,不過比我自己寫的好很多,說實話,小拜對這些東西了解起來實在是困難
ID:315554 發表于 2020-1-8 10:23 | 只看該作者
謝謝樓主,不錯的程序代碼,注釋詳細,如果有個原理圖更妙,
ID:737450 發表于 2020-4-25 08:31 | 只看該作者
有點讀不懂
