查看: 1623|回復: 1
心率測試儀程序
ID:464263 發表于 2019-1-8 11:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit wei1=P2^0;
sbit wei2=P2^1;
sbit wei3=P2^2;
sbit wei4=P2^3;
unsigned char i=0;timecount=0;displayOK=0,rate=0,aa=0;
unsigned int time[6]={0};
uchar code table[]={0xc0,0xcf,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,};
void DelayMs(unsigned int z)
   unsigned int x;
   for(;z>0;z--)
    for(x=110;x>0;x--);
void display(uchar bai,uchar shi,uchar ge)
   wei1=0;
   P0=bai;
   DelayMs(1);
   wei1=1;
   P0=0xff;
   wei2=0;
   P0=shi;
   DelayMs(1);
   wei2=1;
   P0=0xff;
   wei3=0;
   P0=ge;
   DelayMs(1);
   wei3=1;
   P0=0xff;
        TCON=0x01;
                EX0=1;
                TMOD=0X01;
                TH0=(65536-50000)/256;
                TL0=(65536-50000)%256;
                ET0=1;
            TR0=0;
                EA=1;
                       if(displayOK==1)
                                   rate=60000/(time[1]/5+time[2]/5+time[3]/5+time[4]/5+time[5]/5);
                                           while(1)display(table[rate/100],table[rate/10%10],table[rate%10]);
                                        DelayMs(300);
                                        void ex0() interrupt 0
                                            EX0=0;
                                                 if(timecount<8)
        TR0=1;
                                                      time[i]=timecount*50+TH0*0.256+TL0/1000;
                                                          timecount=0;
                                                          i++;
                                                          if(i==6)
                                                               i=1;
        displayOK=1;
                EX0=1;
void et0() interrupt 1
        timecount++;
        if(timecount>25)
           i=0;
           timecount=0;
           displayOK=0;
           TR0=0;
           TH0=0;
ID:1 發表于 2019-1-8 15:20 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
