查看: 3645|回復: 1
arduino 433M無線遙控接收問題求助
ID:389836 發表于 2019-1-7 12:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
433遙控器,我用庫RCSwitch里面接收例程,收到信號的value值是:
遙控器按鍵A:Received 5264652 / 24bit Protocol: 1
遙控器按鍵B:Received 5264688 / 24bit Protocol: 1
以上是串口讀取出的數據。
#include <RCSwitch.h>
int led=13;
RCSwitch mySwitch = RCSwitch();
void setup() {
  Serial.begin(9600);
  pinMode(led,OUTPUT);
  mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
void loop() {
  if (mySwitch.available()) {
    int value = mySwitch.getReceivedValue();
    if (value == 0) {
      Serial.print("Unknown encoding");
    } else {
      Serial.print("Received ");
      Serial.print( mySwitch.getReceivedValue() );
      Serial.print(" / ");
      Serial.print( mySwitch.getReceivedBitlength() );
      Serial.print("bit ");
      Serial.print("Protocol: ");
      Serial.println( mySwitch.getReceivedProtocol() );
    if(value==5264652){
      digitalWrite(led,HIGH);
    if(value==5264688){
      digitalWrite(led,LOW);
    mySwitch.resetAvailable();
以上是例程代碼簡單修改,就是按鍵A時,LED亮燈,按鍵B時,LED滅燈;
實際情況是LED不亮燈也不滅燈,哪位大俠幫我看看問題出在哪里?
我還是放上接收解碼的例程吧:
  Simple example for receiving
void setup() {
  Serial.begin(9600);
void loop() {
    if (value == 0) {
    } else {
ID:585217 發表于 2019-7-16 16:19 | 只看該作者
你好 怎么發送的放float數據 接收到的只能是int整數
