查看: 1626|回復: 1
拼數游戲 (lcd)課題要求:進入游戲之后,產生一個兩位的隨機數,在lcd上顯示,通...
ID:412944 發表于 2019-1-5 21:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include <stdlib.h>
#include "lcd.h"
sbit Key_1 = P3^3;
sbit Key_2 = P3^4;
sbit Key_3 = P3^6;
sbit Key_4 = P3^7;
uchar Num_Temp,Num_Ture,Num_False;//temp???????
uchar Total;//????
uchar Num_Dat=0;
uint Time_Coont;//???????????
bit Change_Flag=0;
void Delay10ms(uchar delaytime);  //@11.0592MHz
void Key_Scan();
void Timer0Init(void);
Timer0Init();//??????????
    LcdInit(); //LCD??????????
LcdWriteCom(0x0f);   //?????? LcdWriteCom ??lcdд????????????? ????com ?????
    LcdWriteStr(1,1,"N:00    T:0");//д??λ??//
LcdWriteStr(2,1,"T:0  F:0  C:0");
LcdWriteCom(0x80+3);//?????λ??N??00????0λ??
        Key_Scan();
void Key_Scan()
    if(Key_1 == 0)
        Delay10ms(1);
        if(Key_1 == 0)
            while(Key_1 == 0);
   if(Change_Flag == 1)
    if(Num_Dat /10 < 9)
     Num_Dat = Num_Dat+10;
    LcdWriteNum(1,3,Num_Dat/10);
    LcdWriteCom(0x80+2);
    if(Num_Dat %10 < 9)
     Num_Dat++;;
    LcdWriteNum(1,4,Num_Dat%10);
    if(Key_2 == 0)
        Delay10ms(1);
        if(Key_2 == 0)
            while(Key_2 == 0);
    if(Num_Dat /10 > 1)
     Num_Dat = Num_Dat-10;
    if(Num_Dat %10 > 0)
     Num_Dat--;
    if(Key_3 == 0)  //?л?????????
        Delay10ms(10);
  if(Key_3 == 0)
            while(Key_3 == 0);
   Change_Flag = ~Change_Flag;
   if( Change_Flag == 1)
if(Key_4 == 0)
        Delay10ms(10);
  if(Key_4 == 0)
            while(Key_4 == 0);
   LcdWriteCom(0x0c);  //?????????????
   TR0 = 1;   //???????
TMOD &= 0xF0;
TMOD |= 0x01;
TL0 = 0x00;
TH0 = 0xDC;
TF0 = 0;
TMOD &= 0x0f;
TMOD |= 0x20;
TR1 = 1;
ET0 = 1;
EA = 1;
void Delay10ms(uchar delaytime)  //@11.0592MHz
    unsigned char i, j,k;
    for(k=0; k<delaytime; k++)
        i = 18;
        j = 235;
        do
            while (--j);
        } while (--i);
void Timer_0()    interrupt 1
TL0 = 0x00;
TH0 = 0xDC;
Time_Coont++;
if(Time_Coont > 100)
  Time_Coont = 0;
  Total++;
  if(Total > 59)
   TR0 = 0;
  srand(TL1);
  Num_Temp = rand()%(91)+10;
  if(Num_Temp == Num_Dat)
   Num_Ture++;
   Num_False++;
  LcdWriteNum(2,13,Num_Temp);
  LcdWriteNum(2,3,Num_Ture);
  LcdWriteNum(2,8,Num_False);
  LcdWriteNum(1,11,Total);
ID:1 發表于 2019-1-6 04:16 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
