使用ADC采樣時,使用STC12單片機內(nèi)部AD采樣,其10位8通道高速采樣可以滿足大多采樣需求,相較于普通ADC模塊更方便,花費一天查看手冊完成測試。
- /* 功能:使用12C5A60S2內(nèi)部AD讀取外部三路電壓,顯示在1602上 */
- /* 最多可同時輸入8路電壓,設(shè)置P1ASF */
- #include <STC12C5A60S.H>
- #include<intrins.h>
- sbit RS = P2^6; //定義1602使用的端口
- sbit RW = P2^5;
- sbit EN = P2^7;
- #define uchar unsigned char;
- #define uint unsigned int;
- #define RS_CLR RS=0
- #define RS_SET RS=1
- #define RW_CLR RW=0
- #define RW_SET RW=1
- #define EN_CLR EN=0
- #define EN_SET EN=1
- #define DataPort P0 //連接1602數(shù)據(jù)口 P0
- //uchar b,i,ge,shi,bai;
- uchar da1=0,da2=0,da3=0;
- double Data,c;
- char a[5]="";
- uchar ADC_Chanul_Turn=0;
- uS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
- unsigned char 是定義無符號字符變量,其值的范圍是
- 0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
- 長度如下 T=tx2+5 uS
- void DelayUs2x(unsigned char t)
- while(--t);
- mS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
- void DelayMs(unsigned char t)
- while(t--)
- //大致延時1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 判忙函數(shù)
- bit LCD_Check_Busy(void)
- DataPort= 0xFF;
- RS_CLR;
- RW_SET;
- EN_CLR;
- _nop_();
- EN_SET;
- return (bit)(DataPort & 0x80);
- 寫入命令函數(shù)
- void LCD_Write_Com(unsigned char com)
- while(LCD_Check_Busy()); //忙則等待
- RS_CLR;
- RW_CLR;
- EN_SET;
- DataPort= com; //
- _nop_();
- EN_CLR;
- 寫入數(shù)據(jù)函數(shù)
- void LCD_Write_Data(unsigned char Data)
- RS_SET;
- RW_CLR;
- EN_SET;
- DataPort= Data;
- _nop_();
- EN_CLR;
- 清屏函數(shù)
- void LCD_Clear(void)
- LCD_Write_Com(0x01);
- DelayMs(5);
- 寫入字符串函數(shù)
- void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)//y為行數(shù),x為橫坐標(biāo),最后一個是字符
- if (y == 0)
- LCD_Write_Com(0x80 + x); //表示第一行
- else
- LCD_Write_Com(0xC0 + x); //表示第二行
- while (*s)
- LCD_Write_Data( *s);
- s ++;
- 寫入字符函數(shù)
- void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
- if (y == 0)
- else
- LCD_Write_Data( Data);
- 初始化函數(shù)
- void LCD_Init(void)
- LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
- DelayMs(5);
- DelayMs(5);
- DelayMs(5);
- LCD_Write_Com(0x08); /*顯示關(guān)閉*/
- LCD_Write_Com(0x01); /*顯示清屏*/
- LCD_Write_Com(0x06); /*顯示光標(biāo)移動設(shè)置*/
- DelayMs(5);
- LCD_Write_Com(0x0C); /*顯示開及光標(biāo)設(shè)置*/
- ADC函數(shù)
- void InitADC()//初始AD寄存器
- P1ASF=0X07; //0xff設(shè)置P1口全部為ADC通道,0x07=0000,0111 即使用P10,P11,P12作為輸入
- ADC_RES=0X00; //清除高8位緩沖數(shù)據(jù)
- if(ADC_Chanul_Turn%3==0)//外部基準(zhǔn)電壓
- ADC_CONTR=0xF0; //AD轉(zhuǎn)換控制寄存器,1111,0000 P10口
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ADC_CONTR=0xE8; //1110,1000(清零Flag,置位Start)
- if(ADC_Chanul_Turn%3==1)
- ADC_CONTR=0xF1; // 1111,0001 P11口
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ADC_CONTR=0xE9; //1110,1001
- if(ADC_Chanul_Turn%3==2)
- ADC_CONTR=0xF2; //1111,0010 P12口
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ADC_CONTR=0xEA; //1110,1010
- void timer0() interrupt 1 //interrupt 1: 定時器0,interrupt3:定時器3
- TH0=(65536-20000)/256; //高八位,(需要表示Xms的定時,計數(shù)器由65536-X數(shù)到65536,由于16位,只能分高低位)
- TL0=(65536-20000)%256; //低八位
- InitADC();
- void adc_isr() interrupt 5 //FLAG標(biāo)志位置位觸發(fā)中斷,沒有設(shè)優(yōu)先級,但是同優(yōu)先級下定時器0更高
- //V_5REF=V_1REF*256/da_ref;
- if(ADC_Chanul_Turn%3==0) //外部基準(zhǔn)電壓
- da1=ADC_RES; //獲取轉(zhuǎn)換結(jié)果
- Data=((double)da1/256)*5; //取八位計算基準(zhǔn)電壓Data,
- c =Data;
- da2=ADC_RES; //獲取轉(zhuǎn)換結(jié)果
- Data=((double)da2/256)*5; //取八位計算實際值Data,
- c =Data;
- da3=ADC_RES; //獲取轉(zhuǎn)換結(jié)果
- Data=((double)da3/256)*5; //取八位計算實際值Data,
- c =Data;
- a[0]=((int)c%10+0x30);//個位(電壓<5,僅有個) //0x30: ASCAI碼里代表“0”,必須轉(zhuǎn)換成字符存在字符型數(shù)組里才可以在1602液晶屏上顯示
- a[1]=0x2e; //小數(shù)點
- a[2]=((int)(c*10)%10+0x30); // 十分位
- a[3]=((int)(c*100)%10+0x30);// 百分位
- a[4]='\0'; // 加了串尾符才成了字符串哦
- if(ADC_Chanul_Turn%3==0) LCD_Write_String(0,0,a);
- if(ADC_Chanul_Turn%3==1) LCD_Write_String(5,0,a);
- if(ADC_Chanul_Turn%3==2) LCD_Write_String(0,1,a);
- ADC_CONTR&=0xEF; //標(biāo)志位清零
- ADC_Chanul_Turn++;
- if(ADC_Chanul_Turn==252)
- ADC_Chanul_Turn=0;
- void main()
- LCD_Init();
- LCD_Clear(); //清屏
- //LCD_Write_String(0,2,"Hello Dog!");
- DelayMs(255);
- TH0=(65536-20000)/256; //開定時器0
- EA=1; //開全局中斷
- ET0=1; //允許定時器零中斷
- EADC=1; //允許ADC中斷
- TR0=1;
- while(1);
新建文本文檔.rar
(2.19 KB, 下載次數(shù): 393)
2019-1-5 17:50 上傳
