查看: 6407|回復(fù): 0
[求助]regx51.h對(duì)應(yīng)的是哪種單片機(jī)
ID:40336 發(fā)表于 2012-5-16 13:07 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include #include #define uchar unsigned char #define uint unsigned int #define k1 P3_7 //k1功能鍵 #define k2 P3_6 //k2數(shù)值調(diào)整鍵 #define bjh P3_1 //定值輸出 #define sx P0_2 //報(bào)警值輸出(聲音) #define csbout P2_7 //超聲波發(fā)送 #define csbint P3_5 //超聲波接收 uchar ec,cls;cs;xl,mq,xm0,xm1,xm2,sec20,sec,sec1,buffer[3],BitCounter,temp,Number[8]={1,2,3,4,5,6,7,8}; uchar temp1,convert[10]={0x81,0xED,0xA2,0xA8,0xCC,0x98,0x90,0xAD,0x80,0x88};//0~9段碼 uint zzz,dz,zzbl,i,jsz,yzsj,kk,s,ss; static uchar bdata ke,kw; //可位尋址的狀態(tài)寄存器 float csbc,wdz; sbit LED1 = P3^4; //數(shù)碼管位驅(qū)動(dòng) sbit LED2 = P3^2; //數(shù)碼管位驅(qū)動(dòng) sbit LED3 = P3^3; //數(shù)碼管位驅(qū)動(dòng) sbit k11=ke^0; sbit k12=ke^1; sbit k22=ke^2; sbit k21=ke^3; sbit b=ke^4; sbit c=ke^5; sbit d=ke^6; sbit e=ke^7; sbit w=kw^0; sbit zj1=kw^1; sbit zj2=kw^2; 上面居然還有ke^0口 怎么發(fā)表后沒有回車?
[此貼子已經(jīng)被作者于2012-5-16 13:09:06編輯過]
