查看: 2235|回復(fù): 2
st7920指針式時(shí)鐘程序,在12864上總顯示不了,求大神,下面是程序
ID:398554 發(fā)表于 2019-1-1 22:11 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg51.h>
#include <intrins.h>
#include<stdlib.h>
#include<math.h>
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
#define pi 3.1415926
/************* 12864LCD引腳定義 *************/
#define LCD_data  P0       //數(shù)據(jù)口
sbit LCD_RS  =  P1^0;      //寄存器選擇輸入
sbit LCD_RW  =  P1^1;      //液晶讀/寫控制
sbit LCD_EN  =  P1^2;      //液晶使能控制
sbit LCD_PSB =  P2^4;      //串/并方式控制
sbit LCD_RST =  P2^5;      //液晶復(fù)位端口
sbit k1=P3^5;                                //按鍵
sbit k2=P3^2;
sbit k3=P3^3;
sbit k4=P3^4;
sbit DQ = P1^7;                       //數(shù)據(jù)口define interface
uchar a,b,c,count,num;
uint temp;
uchar tabbjsj[]="北京時(shí)間";
uchar tabsswd[]="實(shí)時(shí)溫度";
uchar tab[]="01:00:00";
uchar code table[]={        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0xF8,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x87,0x13,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x03,0xF7,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x30,0x0E,0x30,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x78,0x1C,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3C,0xFC,0x38,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x79,0xDE,0x71,0xDE,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x79,0x9E,0x79,0x9E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x3C,0x3C,0x3C,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x3B,0x9E,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xF7,0x0F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xEF,0x37,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x03,0xDE,0x7B,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xBC,0xFD,0x80,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x79,0xDE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x79,0x8E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x1E,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x20,
0x00,0x01,0x9C,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0xC0,0x00,0x99,0x00,0x00,0x30,0x00,0x03,0x9A,0x00,0x0C,0x23,0x00,0x00,0x00,0x02,0xC6,
0x00,0x99,0x80,0x06,0xB4,0x00,0x02,0x21,0x00,0x06,0x33,0x00,0x10,0x80,0x07,0x26,0x00,0x98,0x00,0x12,0x88,0x00,0x02,0x24,0x80,0x06,0x3F,
0x00,0x1F,0xC0,0x05,0x26,0x00,0x15,0x00,0x1C,0x00,0x00,0x03,0x66,0x70,0x17,0x67,0x00,0x0F,0x00,0x01,0xBE,0x00,0x02,0x00,0x0E,0x70,0x00,
0x03,0x7E,0x00,0x17,0xE2,0x00,0x07,0x00,0x07,0x00,0x01,0xA0,0x40,0x18,0x00,0x00,0x06,0xCE,0x00,0x0E,0x62,0x00,0x07,0x00,0x03,0xA6,0x00,
0x9C,0x80,0x12,0x38,0x00,0x06,0x0F,0x80,0x06,0x62,0x00,0x06,0x00,0x03,0x08,0x00,0x84,0x00,0x10,0xF0,0x00,0x0C,0xFC,0x00,0x06,0x22,0x00,
0x1E,0x00,0x05,0x1C,0x00,0x1E,0x00,0x10,0x40,0x00,0x12,0x24,0x80,0x3E,0x42,0x00,0x1E,0x00,0x01,0x1C,0x00,0x04,0x00,0x10,0x80,0x00,0x02,
0x44,0xC0,0x3C,0x43,0x00,0x7F,0xF0,0x01,0x0E,0x00,0x04,0x00,0x11,0x10,0x80,0x02,0x64,0x80,0x00,0x03,0x00,0x20,0x00,0x00,0xFA,0x80,0x08,
0x00,0x13,0x08,0x80,0x02,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x18,0x00,0x00,0x07,0x00,0x02,0x0C,0x00,0x00,0x00,0x00,0x00,
0x00,0x00};
/*  延時(shí)函數(shù)                                                       */
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<150;i++)
            _nop_();
                _nop_();
                _nop_();
                _nop_();
/*  精確延時(shí)函數(shù),延時(shí)1秒,軟件算得                                                       */
void Delay_S(void)   //延時(shí)1s誤差 0us
    unsigned char a,b,c;
    for(c=167;c>0;c--)
        for(b=171;b>0;b--)
            for(a=16;a>0;a--);
    _nop_();  //if Keil,require use intrins.h
/*檢查LCD忙狀態(tài)                                                    */
/*lcd_busy為1時(shí),忙,等待。lcd-busy為0時(shí),閑,可寫指令與數(shù)據(jù)。      */
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*寫指令數(shù)據(jù)到LCD                                                  */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。                             */
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    LCD_data = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD                                                  */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。                               */
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    LCD_data = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*從lcd讀取數(shù)據(jù)到data                                              */
uchar lcd_rdat()
        uchar dat;
          while(lcd_busy());
           LCD_data = 0XFF;
    LCD_RS = 1;
    LCD_RW = 1;
    LCD_EN = 0;
    LCD_EN = 1;
        dat = LCD_data;
    LCD_EN = 0;
        return(dat);
/*  LCD初始化設(shè)定                                                  */
void lcd_init()
    LCD_PSB = 1;         //并口方式
        LCD_RST = 0;                 //液晶復(fù)位
    delay(3);
    LCD_RST = 1;
    delay(3);
    lcd_wcmd(0x34);      //擴(kuò)充指令操作
    delay(5);
    lcd_wcmd(0x30);      //基本指令操作
    delay(5);
    lcd_wcmd(0x0C);      //顯示開,關(guān)光標(biāo)
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
    delay(5);
函數(shù)名:  DrawPoint
函數(shù)說明:畫點(diǎn)
傳入?yún)?shù):打點(diǎn)位置(x0,y0);color=1,點(diǎn)亮;color=0,擦除
傳出參數(shù):無
返回值:  無
void DrawPoint(unsigned char x,unsigned char y,unsigned char color)
        unsigned char row,collum,cbite;
        unsigned char tempH,tempL;
        lcd_wcmd(0x34);//打開擴(kuò)充指令集
        lcd_wcmd(0x36);//打開圖形顯示
        collum=x>>4;
        cbite=x&0x0f;
        if(y<32)
                row=y;
                row=y-32;
                collum+=8;
        lcd_wcmd(0x80+row);//先寫Y坐標(biāo)
        lcd_wcmd(0x80+collum);//再寫X坐標(biāo)
        lcd_rdat();
        tempH = lcd_rdat();//先讀出高字節(jié)
        tempL = lcd_rdat();//再讀出低字節(jié)
        if (color)
                if(cbite<8)
                        tempH|=(1<<(7-cbite));
                        tempL|=(1<<(15-cbite));
                 if(cbite<8)
                         tempH&=~(1<<(7-cbite));
                         tempL&=~(1<<(15-cbite));
        lcd_wdat(tempH);
        lcd_wdat(tempL);
        lcd_wcmd(0x30);
函數(shù)名:  line
函數(shù)說明:畫直線
傳入?yún)?shù):直線起始位置(x0,y0);終點(diǎn)(x1,y1)
傳出參數(shù):無
返回值:  無
void line(unsigned char x0,unsigned char y0, unsigned char x1,unsigned char y1,unsigned char color)
    int    dx;                         /* 直線x軸差值變量*/
    int    dy;                         /* 直線y軸差值變量 */
    char    dx_sym;                     /* x軸增長方向,為-1時(shí)減值方向,為1時(shí)增值方向 */
    char    dy_sym;                     /* y軸增長方向,為-1時(shí)減值方向,為1時(shí)增值方向 */
    int    dx_x2;                      /* dx*2值變量,用于加快運(yùn)算速度*/
    int    dy_x2;                      /* dy*2值變量,用于加快運(yùn)算速度*/
    int    di;                         /* 決策變量  */
    if (x0 == x1)                       /* 畫垂直線   */
        if (y0 > y1)
            dx = y0;
            y0 = y1;
            y1 = dx;
        for (dx = y0; dx < y1+1; dx++)
            DrawPoint(x0, dx,color);
    if (y0 == y1)                       /* 畫水平線   */
        if(x0 > x1)
            dy = x0;
            x0 = x1;
            x1 = dy;
        for (dy = x0; dy < x1+1; dy++)
            DrawPoint(dy, y0,color);
        /****************************畫斜線******************************/
    dx = x1-x0;                         /* 求取兩點(diǎn)之間的差值       */
    dy = y1-y0;
    if (dx > 0)                         /* 判斷x軸方向              */
        dx_sym = 1;                     /* dx>0,設(shè)置dx_sym=1       */
        if (dx < 0)
            dx_sym = -1;                /* dx<0,設(shè)置dx_sym=-1      */
    if (dy > 0)                         /* 判斷y軸方向              */
        dy_sym = 1;                     /* dy>0,設(shè)置dy_sym=1       */
        if (dy < 0)
            dy_sym = -1;                /* dy<0,設(shè)置dy_sym=-1      */
    dx = dx_sym * dx;                   /* 將dx、dy取絕對值         */
    dy = dy_sym * dy;
    dx_x2 = dx*2;                       /* 計(jì)算2倍的dx及dy值        */
    dy_x2 = dy*2;
                                        /* 使用Bresenham法進(jìn)行畫直線    */
    if (dx >= dy)                       /* 對于dx>=dy,則使用x軸為基準(zhǔn)  */
        di = dy_x2 - dx;
        while(x0!=x1)
            DrawPoint(x0, y0,color);
            x0 += dx_sym;
            if (di < 0)
                di += dy_x2;            /* 計(jì)算出下一步的決策值         */
                di += dy_x2 - dx_x2;
                y0 += dy_sym;
        DrawPoint(x0, y0,color);             /* 顯示最后一點(diǎn)                 */
   else                                 /* 對于dx<dy,則使用y軸為基準(zhǔn)   */
        di = dx_x2 - dy;
        while(y0!=y1)
            y0 += dy_sym;
            if (di < 0)
                di += dx_x2;
                di += dx_x2 - dy_x2;
                x0 += dx_sym;
函數(shù)名:  circle
函數(shù)說明:畫圓
傳入?yún)?shù):圓心坐標(biāo)(x1,y1),半徑r
傳出參數(shù):無
返回值:  無
void circle(int x1, int y1, unsigned int r)
    int   x, y, d;
    x = 0;
    y = r;
    d = 1-r;                    /* 計(jì)算初始值                                           */
    while (x <= y)
        /* 繪制點(diǎn)(x,y)及其在八分圓中的另外7個(gè)對稱點(diǎn)             */
        DrawPoint(x1+x, y1+y,1);
        DrawPoint(x1+y, y1+x,1);
        DrawPoint(x1-y, y1+x,1);
        DrawPoint(x1-x, y1+y,1);
        DrawPoint(x1-x, y1-y,1);
        DrawPoint(x1-y, y1-x,1);
        DrawPoint(x1+y, y1-x,1);
        DrawPoint(x1+x, y1-y,1);
        if (d < 0)
            d += 2*x+3;         /* 根據(jù)誤差項(xiàng)d的判斷,決定非最大位移方向上是走還是不走   */
            d += 2*(x-y)+5;
            y--;
        x++;
函數(shù)名稱:void DrawHand(char x0,char y0,char a,char b,char c,char color)
功    能:畫時(shí)鐘指針
參    數(shù):(x0,y0)表盤圓心坐標(biāo),
                  R指針長度
                  Time指針?biāo)缚潭龋搿⒎?0進(jìn)制,時(shí)12進(jìn)制)
                  step指針步長(秒、分為6,時(shí)為30)
                  color指針顏色
返回值  :無
void DrawHand(char x0,char y0,char R,char Time,char step,char color)
        char x,y;
        x=R*cos(Time*step*pi/180-pi/2)+x0;
        y=R*sin(Time*step*pi/180-pi/2)+y0;
        line(x0,y0,x,y,color);
函數(shù)名稱:clr_screen(void)
功    能:清除液晶GDRAM內(nèi)部的隨機(jī)數(shù)據(jù)
參    數(shù):無
返回值  :無
void clr_screen(void)
        uchar i,j;
           for(j=0;j<64;j++)
                for(i=0;i<128;i++)
                        DrawPoint(i,j,0);
*  描述:        *
*      12864標(biāo)準(zhǔn)字庫液晶演示 數(shù)據(jù)p0,控制p2                                     *
#define x0 31
#define y0 31   //表盤圓心坐標(biāo)
函數(shù)名:  DISP_BP
函數(shù)說明:畫表盤
傳出參數(shù):無
返回值:  無
void DISP_BP(void)
        circle(x0,y0,30);//畫圓
        line(31,1,31,3,1);//12點(diǎn)
        line(30,1,30,3,1);
        line(32,1,32,3,1);
        line(31,61,31,59,1);//6點(diǎn)
        line(30,61,30,59,1);
        line(32,61,32,59,1);
        line(61,31,59,31,1);//3點(diǎn)
        line(61,30,59,30,1);
        line(61,32,59,32,1);
        line(1,31,3,31,1);//9點(diǎn)
        line(1,30,3,30,1);
        line(1,32,3,32,1);
        line(109,51,111,51,1);//℃符號
        line(109,50,111,50,1);
        line(109,49,111,49,1);
        line(110,50,110,50,0);
        circle(8,8,8);        //耳朵左
        line(16,7,16,11,0);
        line(7,16,12,16,0);
        line(15,12,11,15,0);
        line(15,11,12,17,0);
        line(12,15,12,15,0);
        circle(54,8,8);        //耳朵右
        line(46,7,46,11,0);
        line(55,16,50,16,0);
        line(47,12,51,16,0);
        line(47,11,47,11,0);
//        line(48,14,48,14,1);
        line(51,15,51,15,0);
/*****************顯示時(shí)分秒*****************/
void sfm(uchar add,uchar sfm)
        uchar sfm1,sfm2;
        sfm1=sfm/10;
        sfm2=sfm%10;
        lcd_wcmd(0x90+add);
        lcd_wdat(0x30+sfm1);
        lcd_wdat(0x30+sfm2);
void sfmfen()
        uchar fen1,fen2;
        fen1=b/10;
        fen2=b%10;
        lcd_wcmd(0x90+5);
        lcd_wdat(0x3a);
        lcd_wdat(0x30+fen1);
        lcd_wdat(0x30+fen2);
//按鍵掃描函數(shù)
void keyscan()
//        uchar i,j,k;
           if(k1==0)
        delay(5);
    if(k1==0)
                while(!k1);
                DrawHand(x0,y0,25,a,6,0);                // 消除秒針位置
                DrawHand(x0,y0,20,b,6,1);        //顯示新的分針位置
                DrawHand(x0,y0,15,c,6,1);//顯示新的時(shí)針位置
            a++;
                if(a==60)
                   a=0;
                sfm(7,a);
                     DrawHand(x0,y0,25,a,6,1);                 //顯示秒針位置
  if(k2==0)
        delay(5);
        if(k2==0)
                while(!k2);
                DrawHand(x0,y0,20,b,6,0);         //消除原來分針位置
                b++;
                if(b==60)
                    b=0;
                sfmfen();
        if(k3==0)
        delay(5);
        if(k3==0)
                while(!k3);
                DrawHand(x0,y0,15,c,6,0);//消除原來的時(shí)針位置
                c++;
                if(c==60)
                        c=0;
                sfm(4,c/5);
/*******************畫開機(jī)畫面********************/
void GUI_CLEAR(const uchar *pic)
        uchar i,j,k;
lcd_wcmd(0X34);
        lcd_wcmd(0X34);
        for(i=0;i<2;i++)
                for(j=0;j<32;j++)
                        lcd_wcmd(0X80+j);
                        delay(2);
                        if(i==0)
                                lcd_wcmd(0X80);
                                delay(2);
                                lcd_wcmd(0X88);
                                delay(2);
                        for(k=0;k<16;k++)
                                lcd_wdat(*(pic++));
                                //LCD_WRITE_DATA(0X00);
                                delay(2);
lcd_wcmd(0X36);
lcd_wcmd(0X30);
  /********************DS18B20***********************************/
void delay18b20(unsigned char i)
while(--i);
void Init_Ds18b20(void)     //DS18B20初始化send reset and initialization command
DQ = 1;                     //DQ復(fù)位,不要也可行。
delay18b20(1);                  //稍做延時(shí)
DQ = 0;                    //單片機(jī)拉低總線
delay18b20(250);                //精確延時(shí),維持至少480us
DQ = 1;                    //釋放總線,即拉高了總線
delay18b20(100);                //此處延時(shí)有足夠,確保能讓DS18B20發(fā)出存在脈沖。
uchar Read_One_Byte()       //讀取一個(gè)字節(jié)的數(shù)據(jù)read a byte date
                            //讀數(shù)據(jù)時(shí),數(shù)據(jù)以字節(jié)的最低有效位先從總線移出
uchar i   = 0;
uchar dat = 0;
for(i=8;i>0;i--)
   DQ = 0;                  //將總線拉低,要在1us之后釋放總線
                           //單片機(jī)要在此下降沿后的15us內(nèi)讀數(shù)據(jù)才會有效。
   _nop_();                //至少維持了1us,表示讀時(shí)序開始
   dat >>= 1;               //讓從總線上讀到的位數(shù)據(jù),依次從高位移動到低位。
   DQ = 1;                  //釋放總線,此后DS18B20會控制總線,把數(shù)據(jù)傳輸?shù)娇偩上
   delay18b20(1);                 //延時(shí)7us,此處參照推薦的讀時(shí)序圖,盡量把控制器采樣時(shí)間放到讀時(shí)序后的15us內(nèi)的最后部分
   if(DQ)                   //控制器進(jìn)行采樣
    dat |= 0x80;            //若總線為1,即DQ為1,那就把dat的最高位置1;若為0,則不進(jìn)行處理,保持為0
   delay18b20(10);               //此延時(shí)不能少,確保讀時(shí)序的長度60us。
return (dat);
void Write_One_Byte(uchar dat)
uchar i = 0;
for(i=8;i>0;i--)
   DQ = 0;                        //拉低總線
   _nop_();                       //至少維持了1us,表示寫時(shí)序(包括寫0時(shí)序或?qū)?時(shí)序)開始
   DQ = dat&0x01;                 //從字節(jié)的最低位開始傳輸
                                 //指令dat的最低位賦予給總線,必須在拉低總線后的15us內(nèi),
                                 //因?yàn)?5us后DS18B20會對總線采樣。
   delay18b20(10);                     //必須讓寫時(shí)序持續(xù)至少60us
   DQ = 1;                        //寫完后,必須釋放總線,
   dat >>= 1;
   delay18b20(1);
uint Get_Tmp()                   //獲取溫度get the temperature
float tt;
uchar a,b;
Init_Ds18b20();                //初始化
Write_One_Byte(0xcc);          //忽略ROM指令
Write_One_Byte(0x44);          //溫度轉(zhuǎn)換指令
Write_One_Byte(0xbe);          //讀暫存器指令
a = Read_One_Byte();           //讀取到的第一個(gè)字節(jié)為溫度LSB
b = Read_One_Byte();           //讀取到的第一個(gè)字節(jié)為溫度MSB
temp = b;                      //先把高八位有效數(shù)據(jù)賦于temp
temp <<= 8;                    //把以上8位數(shù)據(jù)從temp低八位移到高八位
temp = temp|a;                //兩字節(jié)合成一個(gè)整型變量
tt = temp*0.0625;              //得到真實(shí)十進(jìn)制溫度值
                                //因?yàn)镈S18B20可以精確到0.0625度
                                //所以讀回?cái)?shù)據(jù)的最低位代表的是0.0625度
temp = tt*10+0.5;               //放大十倍
                                //這樣做的目的將小數(shù)點(diǎn)后第一位也轉(zhuǎn)換為可顯示數(shù)字
                                //同時(shí)進(jìn)行一個(gè)四舍五入操作。
return temp;
/****************動態(tài)顯示溫度函數(shù)**************/
void Display(uint temp)   //顯示程序
uchar A1,A2,A3;
A1 = temp/100;    //百位
A2 = temp%100/10;   //十位
A3 = temp%10;    //個(gè)位
lcd_wcmd(0x98+4);
lcd_wdat(' ');
lcd_wdat(0x30+A1);
lcd_wdat(0x30+A2);
lcd_wdat('.');
lcd_wdat(0x30+A3);
* 主函數(shù)                                                 *
    lcd_init();
        GUI_CLEAR(table);
        Delay_S(); Delay_S();Delay_S();
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;ET0=1;TR0=1;
        a=0;b=0;c=45;
        delay(100);                 //上電,等待穩(wěn)定
        lcd_init();                 //初始化LCD
        clr_screen();                                //清屏
        DISP_BP();                                        //畫表盤
        //DrawHand(x0,y0,25,a,6,1);         //顯示秒針
        //DrawHand(x0,y0,20,b,6,1);        //顯示分針
        //DrawHand(x0,y0,15,c,6,1);          //顯示時(shí)針
        lcd_wcmd(0x90+4);                                 //顯示初始時(shí)間
        for(num=0;num<8;num++)
                lcd_wdat(tab[num]);
        lcd_wcmd(0x98+7);                 //顯示溫度符號C
        lcd_wdat('C');
        lcd_wcmd(0x80+4);                                 //顯示”北京時(shí)間“
                lcd_wdat(tabbjsj[num]);
        lcd_wcmd(0x88+4);                                 //顯示"實(shí)時(shí)溫度"
                lcd_wdat(tabsswd[num]);
        c=5;b=0;a=0;
                keyscan();
                Display(Get_Tmp());//顯示溫度
                if(count==20)
                        count=0;
                        a++;
                        if(a==60)
                                a=0;
                                b++;
                                if(b==60 )
                                        b=0;
                                        c++;
                                        if(c==60)
                                                c=0;
                                        sfm(4,c/5);          DrawHand(x0,y0,15,c,6,1);//顯示新的時(shí)針位置
                                sfmfen();        DrawHand(x0,y0,20,b,6,1);        //顯示新的分針位置
                        sfm(7,a);        DrawHand(x0,y0,25,a,6,1);                  //顯示新的秒針位置
void ser0()interrupt 1
        count++;
收藏收藏4 分享淘帖 頂 踩
ID:358930 發(fā)表于 2019-1-2 23:06 | 只看該作者
顯成什么樣,如屏上一個(gè)字沒有就是連接線接錯(cuò),程序這么大不是一般小白寫的,不會有大問題你再找找吧。我弄過12864和OLED12864多種摸擬鐘圓圓的都成功了。你找找
ID:94031 發(fā)表于 2019-1-3 08:14 | 只看該作者
查接線,調(diào)對比度電位器。
