附原理圖與程序
2018-12-30 18:38 上傳
#include<reg51.h>
#include<math.h>
#include<intrins.h>
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=8*10;
bit mode;
uchar code tab[]={
// (0) 0(1) 1(2) 2(3) 3(4) 4(5) 5(6) 6(7) 7(8) 8(9) 9(10) (11)
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x00,0x1C,0x22,0x22,0x22,0x22,0x1C,0x00,/*"0",1*/
0x00,0x12,0x12,0x3E,0x02,0x02,0x00,0x00,/*"1",2*/
0x00,0x12,0x26,0x26,0x26,0x2A,0x36,0x00,/*"2",3*/
0x00,0x14,0x22,0x32,0x32,0x2A,0x2C,0x00,/*"3",4*/
0x00,0x08,0x14,0x24,0x26,0x7E,0x00,0x00,/*"4",5*/
0x00,0x3C,0x2A,0x2A,0x2A,0x2A,0x24,0x00,/*"5",6*/
0x00,0x1C,0x2A,0x2A,0x2A,0x2A,0x04,0x00,/*"6",7*/
0x00,0x30,0x20,0x2E,0x28,0x30,0x20,0x00,/*"7",8*/
0x00,0x34,0x2A,0x2A,0x2A,0x2A,0x34,0x00,/*"8",9*/
0x00,0x10,0x2A,0x2A,0x2A,0x2E,0x1C,0x00,/*"9",10*/
void delay(uint z) //延時(shí)子函數(shù)
uchar x;
for(;z>0;z--)
for(x=110;x>0;x--);
void xianshi() //顯示
uchar aa,i,num=2;
for(i=0;i<16;i++)
switch(i){
case 0:
num=1;
break;
case 1:
num=2;
break;
case 2:
num=4;
break;
case 3:
num=8;
break;
case 4:
num=16;
break;
case 5:
num=32;
break;
case 6:
num=64;
break;
case 7:
num=128;
break;
default :
num=0;
break;
P2=0xff-num; //列掃描
data1=tab[net+aa]; //取出上8行數(shù)據(jù)輸出
aa++;
delay(5); //延時(shí)
data1=0; //清屏
P1=0x00; //消除余輝
if(aa>15) aa=0; //字模地址
void main() //主函數(shù)
ET1=1; //使能定時(shí)器0
EA=1; //開(kāi)啟總中斷
TR1=1; //開(kāi)始計(jì)數(shù)
while(1) //無(wú)限循環(huán)
xianshi(); //顯示
if(s1==0) //檢測(cè)按鍵
delay(30); //延時(shí)消抖
TR1=~TR1; //按下暫停 ,暫按繼續(xù)
while(!s1)xianshi();
delay(30);
if(s2==0) //檢測(cè)按鍵
fangxiang=~fangxiang; //方向取反
while(!s2)xianshi();
delay(30);
void timer1() interrupt 3
alt++;
if(alt==30) //到一定的時(shí)間加以實(shí)現(xiàn)左移
alt=0;
if(fangxiang==0) //如果是正向 正向移動(dòng)
net=net+2;
if(net>sl) //字移動(dòng)數(shù)量
net=0;
else //否則反向移動(dòng)
net=net-2;
if(net<2)
net=sl; //字移動(dòng)數(shù)量
