查看: 7718|回復(fù): 9
51單片機LCD12864多圖片顯示源程序(馬和熊貓)
ID:21069 發(fā)表于 2018-12-30 16:24 | 顯示全部樓層 |閱讀模式
單片機源代碼:
//馬與熊的顯示
#include <reg52.h>
#define uint  unsigned int
sbit rs=P3^5;
sbit rw=P3^6;
sbit en=P3^4;
sbit cs1=P3^1;
sbit cs2=P3^0;
uchar pianxian,ye,lie,shu;
void delay(uint k);
uchar code xiong[]={
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x80,0x80,0x00,0xC0,0x00,0x00,0x00,0x66,0x70,0x40,0x80,0xF0,0xF8,0xFC,0xFE,0xFE,
                0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7E,0x7E,0x7C,0x70,0xE0,0xE0,0xEF,0xE7,0xC3,0xC2,
                0xB3,0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x80,0x80,0xC3,0xE3,0x72,0x3B,0x1C,0x0E,0x07,0x07,0x0B,0x01,0x03,0x03,0x03,0x8B,
                0xC9,0xC8,0xC0,0xE0,0xE0,0xE0,0xC0,0xC0,0x00,0x06,0x00,0x0C,0xB0,0xD0,0xD0,0xD1,
                0x83,0x1F,0xFF,0xFF,0xFF,0xFE,0xFE,0x7C,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x8C,0xE7,0xF0,0xFC,0xFE,0xFE,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFD,0xF0,0xF0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x9F,
                0xDF,0x9F,0x1F,0x1F,0xCF,0xC7,0xC3,0xC1,0x80,0xE0,0xE8,0xC6,0x1F,0x7F,0xFF,0x7F,
                0xBF,0xFF,0xFE,0xFF,0xCF,0xC3,0x81,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x80,0xE4,0xFA,0x7C,0x1F,0x0F,0x0F,0x3F,0x7F,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xEF,0xE7,0xF3,0xFB,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xF6,0xFE,0xFF,0xDF,0xFF,0xFF,0xFF,0xFF,0xF9,0xF8,0xFC,0xFE,0xFE,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0xC0,0xC6,0xC0,0xC0,0xC0,
                0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0x70,0x70,0x70,0x74,0x74,0x70,0xE0,0xF0,0xF0,
                0xF8,0xF8,0xFC,0xFC,0xFC,0xFC,0xFC,0xF8,0xF0,0xE6,0x86,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0xC2,0xFC,0xFF,0x7F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x01,
                0x13,0x07,0x07,0x0F,0x1F,0x1F,0x3F,0x3F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x3F,0x3F,0x1F,0x1F,0x1F,0x2F,0x9F,0x7F,0x7F,0xFF,
                0xFF,0xDF,0x0F,0x1F,0x3F,0x7B,0x71,0xE1,0x00,0xD0,0xE0,0xF0,0xF0,0x30,0x18,0x18,
                0x0C,0x0E,0x0E,0x07,0x07,0x07,0x03,0x03,0x01,0x01,0x01,0xE0,0xF8,0xFE,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0x80,0xC1,0xC0,0x00,0xC0,0x00,0x01,0x03,0x03,
                0x03,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x05,0x01,0x03,0x07,0x0F,0x0E,0x3F,0x1C,
                0x38,0xF8,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xA0,0x00,0x60,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x7F,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0xC0,0xC8,
                0xE8,0xEC,0xF4,0xF4,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF8,0xF8,0xF0,0xF0,0xF0,
                0xE0,0xC0,0xC0,0x80,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x1F,
                0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x17,0x03,0x00,0x00,0x00,0x00,0x00,
                0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0x00,0x38,0x7C,0x7C,0xFC,0xFE,
                0xFE,0xFE,0x7E,0x7E,0x7C,0x3C,0x1A,0x00,0x80,0xC0,0xE0,0xE0,0xC0,0x00,0x00,0x00,
                0xE0,0xF0,0xFD,0x1F,0x0F,0x0F,0x0F,0x0F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x01,0x0F,0x9F,0x7E,0xF8,0xE0,0xC0,0x00,0x01,0xFE,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFE,0xFC,0xFC,0xFC,0xFC,0xFD,0xFD,0x99,
                0x81,0xC0,0xC7,0xCF,0xEF,0x7F,0xFF,0xE7,0x08,0x00,0xC8,0xF0,0xF8,0xFB,0xFB,0xF8,
                0xF8,0xF8,0xFC,0xFE,0xFE,0xFE,0xFE,0xFC,0xE0,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x3F,0x3E,0x30,0x70,
                0xEE,0xFC,0xFC,0xFC,0xFC,0xFC,0xE8,0xF7,0xFF,0xEF,0xEF,0xFF,0xF7,0xFF,0xFC,0xFE,
                0xE7,0x03,0x01,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x83,0x87,0x0E,0x0E,0xAD,0x9F,0xBF,
                0x3F,0x9F,0xBF,0xBF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x3F,0x3F,0x3F,0x1F,0x1F,
                0x1F,0x1F,0x1F,0x0F,0x0F,0x2F,0x2F,0x0F,0x0F,0x0F,0x0F,0x0F,0x07,0x01,0x00,0x01,
                0x01,0x01,0x01,0x00,0x00,0x00,0x07,0x0F,0x0E,0x0C,0x1F,0x1F,0x1F,0x1F,0x3F,0x3F,
                0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x3B,0xC7,0xCF,0x1F,0x1F,
                0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3E,0x3E,0x3D,0x00,0x00,0x00,0xC0,
                0xC0,0xE0,0x00,0xC0,0xC1,0x07,0x8F,0x8F,0x9F,0x3F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
                0x7F,0x7C,0x7C,0x78,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar code ma[]={
                0x00,0x00,0x00,0x00,0x80,0x90,0xD0,0x78,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,0xE0,0xE0,
                0xE0,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x06,0x0F,0x0F,0x07,0x0F,0x0F,0x0F,0xCF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xDD,0x9F,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF0,0x78,0xF8,0xF0,0xE0,0xC0,0xC0,0x80,
                0xC0,0xE0,0xE0,0xF0,0xFC,0xFE,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFD,0x3B,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x40,0x20,0x80,
                0x00,0x00,0x00,0x00,0x00,0xF8,0xFF,0xFF,0xFC,0x9C,0x3C,0x3D,0x3F,0x7F,0xFD,0xFF,
                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xE1,0xC3,0x87,
                0x05,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFE,0xE3,0xF1,
                0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x1F,0x1F,0x78,0xF0,0x00,0x00,0x00,0x01,
                0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                0xFF,0xFE,0xFE,0xFC,0xF8,0xF0,0xE0,0x80,0x80,0x80,0xC0,0xE0,0xFF,0xDF,0x7F,0x1F,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1F,0x7F,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,
                0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x1F,0x07,0xBF,0xFF,0x3F,0x1F,0x05,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,
                0x07,0x07,0x07,0x07,0x06,0x06,0x06,0x06,0x0E,0x0E,0x0E,0x1F,0x1F,0x07,0x9F,0xFF,
                0xFF,0x7B,0x61,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x18,0x18,0x1C,0x1E,0x07,0x03,0x01,
void command(uchar cmd);
void date(uchar dat);
void pianxuan(uchar pianxian);
void shuzu();
void LCD12864_init();
        LCD12864_init();
                disp(&ma);
                delay(500);
                disp(&xiong);
                delay(500);
void delay(uint k)
        unsigned int i,j ;
        for(i=0;i<k;i++)
                for(j=0;j<800;j++)
        rs=0;
        rw=0;
        P0=cmd;
        en=1;
        en=0;
        rs=1;
        rw=0;
        P0=dat;
        en=1;
        en=0;
        if(pianxian==1)
                cs1=0;
                cs2=1;
        if(pianxian==2)
                cs1=1;
                cs2=0;
        if(pianxian==3)
                cs1=0;
                cs2=0;
void shuzu()
        pianxuan(pianxian);
        command(ye);
        command(lie);
        date(shu);
        command(0xc0);
        command(0x3f);
全部資料51hei下載地址:
12864顯示多圖片.rar (16.21 KB, 下載次數(shù): 106)
參與人數(shù) 4黑幣 +85 收起 理由
shuisheng + 15 很給力!
Trump1438 + 10 贊一個!
Sawardeakar + 10 絕世好帖!
ID:79874 發(fā)表于 2019-2-3 10:52 | 顯示全部樓層
圖片用什么軟件做的
ID:472242 發(fā)表于 2019-2-5 22:52 | 顯示全部樓層
真的很精彩,學(xué)習(xí)了
參與人數(shù) 4黑幣 +77 收起 理由
刀刀見紅 + 35
找人PK + 12
yoxi + 15
#include51.h + 15
ID:472325 發(fā)表于 2019-2-7 00:03 | 顯示全部樓層
不錯不錯收下了
參與人數(shù) 3黑幣 +62 收起 理由
找人PK + 12
Sawardeakar + 35
#include51.h + 15
ID:360535 發(fā)表于 2019-4-10 10:44 | 顯示全部樓層
謝謝樓主
ID:448142 發(fā)表于 2020-4-3 18:00 | 顯示全部樓層
disp 函數(shù)沒有???
ID:689247 發(fā)表于 2020-4-3 21:13 | 顯示全部樓層
這個程序是沒有完結(jié)么?是不是還有一部分要下載
ID:725424 發(fā)表于 2020-4-9 11:45 | 顯示全部樓層
shuisheng60 發(fā)表于 2019-2-5 22:52
真的很精彩,學(xué)習(xí)了
太好了
ID:121859 發(fā)表于 2023-11-7 10:12 | 顯示全部樓層
坑爹!沒有disp函數(shù),下載下來的沒有代碼。
ID:412177 發(fā)表于 2024-4-4 15:05 | 顯示全部樓層
disp沒有怎么工作?
