AT89S52 超聲波測距 LCD12864串行顯示 程序 有詳細注釋
- #include <reg52.h>
- #include <intrins.h>
- /************引腳定義**************/
- sbit RX = P3 ^ 1; //ECH0
- sbit TX = P3 ^ 2;//TRIG
- sbit CS = P3 ^ 3;
- sbit SID = P3 ^ 4; //RW 數據
- sbit SCLK = P3 ^ 5; //E 時鐘
- /*************函數聲明**************/
- void Lcd_init(void);
- void Write_char(bit start, unsigned char ddata);
- void Send_byte(unsigned char bbyte);
- void Delaynms(unsigned int di);
- void Clr_Scr(void);
- void LCD_set_xy( unsigned char x, unsigned char y );
- void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
- void LCD_Write_number(unsigned char s);
- void Lcd_Mark2(void);
- void Conut(void);
- void delayms(unsigned int ms);
- void StartModule();
- unsigned char code num[]={"0123456789 :.-"};
- unsigned char code Q[] ={"前:"};
- unsigned char code CM[] = {"m"};
- unsigned int time=0;
- long S=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- void Lcd_init(void) //初始化LCD
- Delaynms(10); //啟動等待,等LCM講入工作狀態
- CS=1;
- Write_char(0,0x30); //8 位介面,基本指令集
- Write_char(0,0x0c); //顯示打開,光標關,反白關
- Write_char(0,0x01); //清屏,將DDRAM的地址計數器歸零
- void Write_char(bit start, unsigned char ddata) //寫指令或數據
- unsigned char start_data,Hdata,Ldata;
- if(start==0)
- start_data=0xf8; //寫指令
- else
- start_data=0xfa; //寫數據
- Hdata=ddata&0xf0; //取高四位
- Ldata=(ddata<<4)&0xf0; //取低四位
- Send_byte(start_data); //發送起始信號
- Delaynms(5); //延時是必須的
- Send_byte(Hdata); //發送高四位
- Delaynms(1); //延時是必須的
- Send_byte(Ldata); //發送低四位
- void Send_byte(unsigned char bbyte) //發送一個字節
- unsigned char i;
- for(i=0;i<8;i++)
- SID=bbyte&0x80; //取出最高位
- SCLK=1;
- SCLK=0;
- bbyte<<=1; //左移
- void Delaynms(unsigned int di) //延時
- unsigned int da,db;
- for(da=0;da<di;da++)
- for(db=0;db<10;db++);
- void Clr_Scr(void)//清屏函數
- { //設置LCD顯示的起始位置,X為行,Y為列
- unsigned char address;
- switch(x)
- case 0: address = 0x80 + y; break;
- case 1: address = 0x80 + y; break;
- case 2: address = 0x90 + y; break;
- case 3: address = 0x88 + y; break;
- case 4: address = 0x98 + y; break;
- default:address = 0x80 + y; break;
- Write_char(0, address);
- { // 中英文字符串顯示函數
- LCD_set_xy( X, Y );
- while (*s)
- Write_char( 1, *s );
- s ++;
- Delaynms(1);
- void LCD_Write_number(unsigned char s)// 數字顯示函數
- Write_char(1,num[s]);
- Delaynms(1);
- Clr_Scr();//清屏
- LCD_Write_string(1,2,Q);//
- LCD_Write_string(1,6,CM);//
- void Conut(void)
- time=TH0*256+TL0;
- TH0=0;
- TL0=0;
- S=time*1.87/100; //算出來是CM 11。0592M晶振
- if(flag==1) //超出測量
- flag=0;
- LCD_set_xy( 1, 4 );
- LCD_Write_number(13);
- LCD_Write_number(12);
- LCD_set_xy( 1, 5 );
- else
- disbuff[1]=S%1000/100;
- disbuff[2]=S%1000%100/10;
- disbuff[3]=S%1000%10 %10;
- LCD_Write_number(disbuff[1]);
- LCD_Write_number(disbuff[2]);
- LCD_Write_number(disbuff[3]);
- unsigned char i=100,j;
- for(;ms;ms--)
- while(--i)
- j=10;
- while(--j);
- void zd0() interrupt 1 //T0中斷用來計數器溢出,超過測距范圍
- flag=1; //中斷溢出標志
- void StartModule() //T1中斷用來掃描數碼管和計800MS啟動模塊
- TX=1; //800MS 啟動一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- TX=0;
- void main(void)
- TMOD=0x01; //設T0為方式1,GATE=1
- TH0=0;
- TL0=0;
- TR0=1;
- Lcd_init(); //設置液晶顯示器
- Clr_Scr(); //清屏
- Lcd_Mark2();
- while(1)
- StartModule();
- //計算
- while(!RX); //當RX為零時等待
- TR0=1; //開啟計數
- while(RX); //當RX為1計數并等待
- TR0=0; //關閉計數
- Conut();
- delayms(80); //80MS
main.zip
(1.92 KB, 下載次數: 32)
2018-12-29 21:50 上傳
有詳細注釋
