查看: 2217|回復: 0
keil編譯的error C141
ID:383845 發表于 2018-12-28 14:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#ifndef _LED_H_
#define _LED_H_
sbit L298N_DT1=P1^2;           //L298N驅動,左輪正轉
sbit L298N_DT2=P1^3;           //左輪反轉
sbit L298N_OT1=P1^4;           //右輪正轉
sbit L298N_OT2=P1^5;           //右輪反轉
sbit BUZZ=P2^3;               //蜂鳴器
#define left_EX P3^7           //左探頭
#define Right_EX P3^6           //右探頭
#define Left_PWM P1^6           //左PWM
#define Right_PWM P1^7           //右PWM
#define Left_Go      {P1^2=1,P1^3=0;}      //左輪正轉
#define Left_Back    {P1^2=0,P1^3=1;}      //左輪反轉
#define Left_Stop      {P1^2=0,P1^3=0;}      //左輪停轉
#define Right_Go      {P1^4=1,P1^5=0;}      //右輪正轉
#define Right_Back      {P1^4=0,P1^5=1;}      //右輪反轉
#define Right_Stop      {P1^4=0,P1^5=0;}      //右輪停轉
unsigned char Left_val_PWM=0;        //定義變量
unsigned char Left_val_Push=0;        //左占空比
unsigned char Right_val_PWM=0;
unsigned char Right_val_Push=0;    //右占空比
bit Right_stop=1;
bit Left_stop=1;
unsigned int time=0;
void delay(int i)
{                               //延時函數
  while(i--);
//全速前進
void run(void)
  Left_val_Push=12;             //速度調節,12級
  Right_val_Push=12;
   Left_Go ;                     //左右前轉
  Right_Go ;
//全速后退
void back(void)
   Left_val_Push=12;
   Right_val_Push=12;
   Left_Back;                //左右后轉
   Right_Back;
//左轉
void leftrun(void)
   Left_val_Push=5;          //左輪慢
   Right_val_Push=15;      //右輪快
   Left_Back;              //左輪后轉
   Right_Go;              //右輪前轉
//右轉
void rightrun(void)
   Left_val_Push=15;      //左輪快
   Right_val_Push=5;      //右輪慢
   Left_Go;                  //左輪前轉
   Right_Back;              //右輪后轉
//停止
void stop(void)
      Left_Stop;              //左輪停止
     Right_Stop;              //右輪停止
//左電機PWM調速
void Left_PWM_out(void)
if(Left_Stop)
  if(Left_val_Push>=Left_val_PWM)
        Left_PWM=1;
    Left_PWM=0;
  if(Left_val_PWM>=20)
        Left_val_Push=0;
    Left_PWM=0;
//右電機調速
void Right_PWM_out(void)
if(Right_Stop)
  if(Right_val_Push>=Right_val_PWM)
        Right_PWM=1;
    Right_PWM=0;
  if(Right_val_PWM>=20)
    Right_val_Push=0;
    Right_PWM=0;
//中斷
    void timer0()interrupt 1   using 2
     TH0=0XFc;          //1Ms定時
     TL0=0X18;
     time++;
     Left_val_PWM++;
     Right_val_PWM++;
     Left_PWM_out();
     Right_PWM_out();
#endif
CARHEAD.H(42): error C141: syntax error near '='
CARHEAD.H(43): error C141: syntax error near '='
CARHEAD.H(50): error C141: syntax error near '='
CARHEAD.H(51): error C141: syntax error near '='
CARHEAD.H(58): error C141: syntax error near '='
CARHEAD.H(59): error C141: syntax error near '='
CARHEAD.H(66): error C141: syntax error near '='
CARHEAD.H(67): error C141: syntax error near '='
CARHEAD.H(72): error C141: syntax error near '='
CARHEAD.H(73): error C141: syntax error near '='
CARHEAD.H(79): error C141: syntax error near '{'
CARHEAD.H(83): error C141: syntax error near '='
CARHEAD.H(87): error C141: syntax error near '='
CARHEAD.H(94): error C141: syntax error near '='
CARHEAD.H(101): error C141: syntax error near '{'
CARHEAD.H(105): error C141: syntax error near '='
CARHEAD.H(109): error C141: syntax error near '='
CARHEAD.H(116): error C141: syntax error near '='
Target not created
