查看: 2777|回復: 1
關于stm32F103和stm32F4的俄羅斯方塊代碼
ID:457004 發表于 2018-12-28 09:54 | 顯示全部樓層 |閱讀模式
用stm32F103和stm32F4寫俄羅斯方塊代碼有何不同
  1. #include "stm32f10x.h"
  2. #include "stm32_eval.h"
  3. #include "key.h"
  4. #include "app.h"
  5. #include "printf.h"
  6. #include "adc.h"
  7. #include "lcd.h"
  8. //#include "bmp.c"
  9. #include "backimg.c"
  10. #include "RussiaGame.h"
  11.   #define GPIO_LED                   GPIOF
  12.   #define RCC_APB2Periph_GPIO_LED    RCC_APB2Periph_GPIOF
  13. extern __IO uint16_t ADCConvertedValue;
  14. extern __IO int sys_count;
  15. //extern u8 Image_Table[];
  16. /** @addtogroup STM32F10x_StdPeriph_Examples
  17.   * @{
  18.   */
  19. GPIO_InitTypeDef GPIO_InitStructure;
  20. /** @addtogroup EXTI_Example
  21.   * @{
  22.   */
  23. /* Private typedef -----------------------------------------------------------*/
  24. /* Private define ------------------------------------------------------------*/
  25. /* Private macro -------------------------------------------------------------*/
  26. /* Private variables ---------------------------------------------------------*/
  27. /* Private function prototypes -----------------------------------------------*/
  28. /* Private functions ---------------------------------------------------------*/
  29. /**
  30.   * @brief  Main program.
  31.   * @param  None
  32.   * @retval None
  33.   */
  34. extern u8 dis_tab_now[19][9];
  35. int main(void)
  36. {
  37.   //int x=0,y=0;
  38.
  39.   SystemInit();
  40.   InitUsart1();
  41.   STM3210E_LCD_Init();
  42.   KeyInit();
  43.   LedInit();
  44.   RussiaGameInit();
  45.   Printf("\r\nSysterm Init.");
  46.   while (1)
  47.   {
  48.           SecondHandle();
  49.         KeyHandle();
  50.         ChicRusiaStatus();
  51.   }
  52. }
  53. #ifdef  USE_FULL_ASSERT
  54. /**
  55.   * @brief  Reports the name of the source file and the source line number
  56.   *   where the assert_param error has occurred.
  57.   * @param  file: pointer to the source file name
  58.   * @param  line: assert_param error line source number
  59.   * @retval None
  60.   */
  61. void assert_failed(uint8_t* file, uint32_t line)
  62. {
  63.   /* User can add his own implementation to report the file name and line number,
  64.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  65.   /* Infinite loop */
  66.   while (1)
  67.   {
  68.   }
  69. }
  70. #endif
  71. /**
  72.   * @}
  73.   */
  74. /**
  75.   * @}
  76.   */
  77. /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
21.俄羅斯方塊.rar (530.01 KB, 下載次數: 46)
ID:1 發表于 2018-12-28 16:05 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
