查看: 1759|回復: 1
LCD12864液晶串行驅動顯示
ID:455848 發表于 2018-12-26 20:52 | 顯示全部樓層 |閱讀模式
12864液晶顯示
#include "lcd12864.h"
#include "reg51.h"
void delay_ms(unsigned char nms)
        unsigned int i, j;
        for(i = nms; i > 0; i--)
                for(j = 110; j > 0; j--);
void lcd_sendbyte(unsigned char byte)
        unsigned char i;
        for(i = 0; i < 8; i++)
                SCLK = 0;
                delay_ms(2);
                SID = (bit)(byte&0x80);
                SCLK = 1;
                byte = byte << 1;
void write_cmd(unsigned char cmd)
        CS = 1;
        lcd_sendbyte(0xf8);
        lcd_sendbyte(0xf0&cmd);
        lcd_sendbyte(0xf0&(cmd << 4));
        CS = 0;
        delay_ms(10);
void write_dat(unsigned char dat)
        CS = 1;
        lcd_sendbyte(0xfa);
        lcd_sendbyte(0xf0&dat);
        lcd_sendbyte(0xf0&(dat << 4));
        CS = 0;
        delay_ms(10);
void lcd_pos(unsigned char x, unsigned char y)
        unsigned char pos;
        switch(x)
                case 0: x = 0x80; break;
                case 1: x = 0x90; break;
                case 2: x = 0x88; break;
                case 3: x = 0x98; break;
        pos = x + y;
        write_cmd(pos);
void lcd12864_init()
        PSB = 0;
        write_cmd(0x30);
        delay_ms(5);
        write_cmd(0x0c);
        delay_ms(5);
        write_cmd(0x01);
        delay_ms(5);
void lcd_display(unsigned char line, unsigned char column, char *str)
        lcd_pos(line, column);
        while(*str)
                write_dat(*str++);
1.串行驅動顯示.rar
39.63 KB, 下載次數: 12, 下載積分: 黑幣 -5
12864顯示
ID:107536 發表于 2019-2-12 18:35 | 顯示全部樓層
垃圾,別下載
