查看: 3393|回復: 0
求大佬幫我看看程序哪里出錯了,用STM32F103R6做的仿真實現不了程序,程序編譯沒錯
10黑幣
void GPIO_Configuration()
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB , ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3
                                                             |GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11| GPIO_Pin_10 | GPIO_Pin_12;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
void delay_us(unsigned long n)
  unsigned long j;
  while(n--)
    j=8;
        while(j--);
* Function Name  : delay_nms
* Description    : delay n ms
void delay_ms1(unsigned long n)
  while(n--)
    delay_us(1100);
void Write_Command_LCM(u8 com)
   GPIO_ResetBits(GPIOA,GPIO_Pin_11);
   GPIO_ResetBits(GPIOA,GPIO_Pin_12);
   GPIO_Write(GPIOB, com);
   GPIO_ResetBits(GPIOA,GPIO_Pin_10);
   delay_ms1(5);
   GPIO_SetBits(GPIOA,GPIO_Pin_10);
   delay_ms1(5);
void Write_Data_LCM(u8 info)
   GPIO_Write(GPIOB, info);
   GPIO_SetBits(GPIOA,GPIO_Pin_12);
   delay_ms1(5);
   delay_ms1(5);
              oˉêyÃû£oLCM_Init()
              1|  Äü£o¶ÔLCD 16023õê¼»ˉ
void LCM_Init(void)
    Write_Command_LCM(0x38);
    Write_Command_LCM(0x08);
        Write_Command_LCM(0x06);
    Write_Command_LCM(0x01);
    Write_Command_LCM(0x0C);
void Set_xy_LCM(unsigned char x, unsigned char y)
    unsigned char address;
    if( x == 0 )
               address = 0x80+y;
    if( x == 1 )
               address = 0xC0+y;
    Write_Command_LCM(address);
void Display1(unsigned int x, unsigned int y, unsigned char *s)
    Set_xy_LCM(x,y);
    while(*s)
        Write_Data_LCM(*s);
        s++;
int main(void)
        void GPIO_Configuration();
                Display1(0, 0, "www*szopen*cn");
          while(1);
主程序
主程序
LCD1602顯示.rar
264.09 KB, 下載次數: 11
程序
