#include "stm32f10x.h"q
#include "stm32_eval.h"
#include <stdio.h>
#ifdef USE_STM32100B_EVAL
#include "stm32100b_eval_lcd.h"
#elif defined USE_STM3210B_EVAL
#include "stm3210b_eval_lcd.h"
#elif defined USE_STM3210E_EVAL
#include "stm3210e_eval_lcd.h"
#elif defined USE_STM3210C_EVAL
#include "stm3210c_eval_lcd.h"
#elif defined USE_STM32100E_EVAL
#include "stm32100e_eval_lcd.h"
#endif
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define MESSAGE1 "STM32 MD Value Line "
#define MESSAGE2 " Device running on "
#define MESSAGE3 " STM32100B-EVAL "
#elif defined (USE_STM3210B_EVAL)
#define MESSAGE1 "STM32 Medium Density"
#define MESSAGE3 " STM3210B-EVAL "
#elif defined (STM32F10X_XL) && defined (USE_STM3210E_EVAL)
#define MESSAGE1 " STM32 XL Density "
#define MESSAGE3 " STM3210E-EVAL "
#elif defined (USE_STM3210E_EVAL)
#define MESSAGE1 " STM32 High Density "
#elif defined (USE_STM3210C_EVAL)
#define MESSAGE1 " STM32 Connectivity "
#define MESSAGE2 " Line Device running"
#define MESSAGE3 " on STM3210C-EVAL "
#elif defined (USE_STM32100E_EVAL)
#define MESSAGE1 "STM32 HD Value Line "
#define MESSAGE3 " STM32100E-EVAL "
#endif
USART_InitTypeDef USART_InitStructure;
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
int main(void)
STM_EVAL_LEDInit(LED1);
STM_EVAL_LEDInit(LED2);
STM_EVAL_LEDInit(LED3);
STM_EVAL_LEDInit(LED4);
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM1, &USART_InitStructure);
/* Initialize the LCD */
STM32100B_LCD_Init();
STM3210B_LCD_Init();
STM3210E_LCD_Init();
STM3210C_LCD_Init();
STM32100E_LCD_Init();
#endif
/* Display message on STM3210X-EVAL LCD *************************************/
/* Clear the LCD */
LCD_Clear(LCD_COLOR_WHITE);
/* Set the LCD Back Color */
LCD_SetBackColor(LCD_COLOR_BLUE);
/* Set the LCD Text Color */
LCD_SetTextColor(LCD_COLOR_WHITE);
LCD_DisplayStringLine(LCD_LINE_0, (uint8_t *)MESSAGE1);
LCD_DisplayStringLine(LCD_LINE_1, (uint8_t *)MESSAGE2);
LCD_DisplayStringLine(LCD_LINE_2, (uint8_t *)MESSAGE3);
/* Retarget the C library printf function to the USARTx, can be USART1 or USART2
depending on the EVAL board you are using ********************************/
printf("\n\r %s", MESSAGE1);
printf(" %s", MESSAGE2);
printf(" %s\n\r", MESSAGE3);
/* Turn on leds available on STM3210X-EVAL **********************************/
STM_EVAL_LEDOn(LED1);
STM_EVAL_LEDOn(LED2);
STM_EVAL_LEDOn(LED3);
STM_EVAL_LEDOn(LED4);
/* Add your application code here
/* Infinite loop */
while (1)
PUTCHAR_PROTOTYPE
USART_SendData(EVAL_COM1, (uint8_t) ch);
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
test.zip
2018-12-26 15:12 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
305.54 KB, 下載次數(shù): 3, 下載積分: 黑幣 -5
相應(yīng)工程包
評(píng)分
查看全部評(píng)分
