查看: 2615|回復: 8
keil編譯1602滾動顯示程序,總是有一處語法錯誤
ID:454913 發(fā)表于 2018-12-25 21:47 | 顯示全部樓層 |閱讀模式
我這個打的有問題嗎,為什么總是有一處語法錯誤,求大佬指教。
main.c
#include"main.h"
        init_lcd();
        while(1);
                display();
1602. C
#include"1602.h"
unsigned char code t0[]="Welcome to the";
unsigned char code t1[]="world of MCU!!!";
unsigned char code t2[]="Fighting!!!!!";
void delay(unsigned int time)
        unsigned int i,j;
        for(i=0;i<time;i++)
                for(j=0;j<200;j++);
void write_com(unsigned char com)
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void write_date(unsigned char date)
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void init_lcd()
        lcden=0;
        lcdrw=0;
        write_com(0x0f);
        write_com(0x38);
        write_com(0x01);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x80);
void display()
        unsigned int i;
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t0);
        delay(500);
        write_com(0x80+0x40);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        write_com(0x01);
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
         delay(500);
        for(i=0;i<16;i++);
                write_date(t2);
        delay(500);
        write_com(0x01);
Main.h
#include"reg52.h"
#include"1602.h"
1602.H
#include"reg52.h"
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
void delay(unsigned int time);
void write_com(unsigned char com);
void write_com(unsigned char date);
void init_lcd();
void display();
Build target 'Target 1'
compiling main.c...
compiling 1602.c...
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?DISPLAY?1602
Program Size: data=11.0 xdata=0 code=329
creating hex file from "main"...
"main" - 0 Error(s), 1 Warning(s).
ID:446654 發(fā)表于 2018-12-25 22:51 | 顯示全部樓層
是不是要這樣啊write_data(t0[i]);
ID:371527 發(fā)表于 2018-12-26 07:29 | 顯示全部樓層
不是錯誤,是警告,編譯可運行,有1個子程序在main內(nèi)未使用
ID:164602 發(fā)表于 2018-12-26 08:10 | 顯示全部樓層
新手的典型錯誤!!!!!
警告是說,你的display()函數(shù)沒有用上,我一看你的程序,果然是這個錯誤:
while(1);
這里不能有那個分號啊!!!!!
ID:213173 發(fā)表于 2018-12-26 08:44 | 顯示全部樓層
        init_lcd();
        while(1);//多了分號
                display();
整理后的程序
#include"reg52.h"
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
void init_lcd();
void display();
        init_lcd();
                display();
        unsigned int i,j;
        for(i=0;i<time;i++)
                for(j=0;j<200;j++);
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void init_lcd()
        lcden=0;
        lcdrw=0;
        write_com(0x0f);
        write_com(0x38);
        write_com(0x01);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x80);
void display()
        unsigned int i;
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t0);
        delay(500);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        write_com(0x01);
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        for(i=0;i<16;i++);
                write_date(t2);
        delay(500);
        write_com(0x01);
ID:134430 發(fā)表于 2018-12-26 09:35 | 顯示全部樓層
while(1);  這里的分號造成了{}里的delay函數(shù)不運行,程序在分號處死循環(huán),也就是停在這里,什么也不干。
ID:357520 發(fā)表于 2018-12-26 11:49 | 顯示全部樓層
語法錯誤應該不能編譯成功吧,看到樓主寫的代碼,就想起自己寫的了,感同身受,我們要努力學習
ID:455797 發(fā)表于 2018-12-26 19:55 | 顯示全部樓層
只是一個警告,不是錯誤,編譯就行
ID:134430 發(fā)表于 2018-12-26 22:33 | 顯示全部樓層
wulin 發(fā)表于 2018-12-26 08:44
        init_lcd();
        init_lcd();
                display();
5樓兄臺,這里整理完還是有問題的吧?while(1),永遠跳不出這個循環(huán),這里除了顯示其他什么都不做,而且顯示也不能調(diào)控,有什么意思嗎?想跳出來就應該加break;
