查看: 6278|回復(fù): 11
51單片機(jī)+74HC138驅(qū)動(dòng)16*96點(diǎn)陣顯示漢字的Proteus仿真+源代碼
ID:21069 發(fā)表于 2018-12-22 20:57 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
16*96點(diǎn)陣仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源碼如下:
  1. /*********************   希望那些還在論壇苦惱的朋友們能看到這款16*16漢字顯示案例  ************************/
  2. #include<reg52.h>
  4. #define uint unsigned  int
  5. #define ulong unsigned long
  6. #define  CTRL_PORT  P2
  7. #define  DATA_PORT  P0
  8. #define  ADDR_PORT  P1
  9. uchar code *p;
  10. uchar code zifu[12][32]={
  11.
  12.         {0x00,0x01,0x00,0x01,0x3F,0x01,0xA0,0x7F,0xA1,0x20,0x52,0x12,0x14,0x02,0x08,0x02,
  13.         0x18,0x02,0x18,0x06,0x24,0x05,0x24,0x09,0x82,0x18,0x61,0x70,0x1C,0x20,0x00,0x00},
  14.
  15.         {0x02,0x00,0x84,0x01,0x6C,0x3E,0x24,0x22,0x20,0x22,0x20,0x22,0x27,0x22,0x24,0x22,
  16.         0xA4,0x22,0x64,0x2A,0x24,0x12,0x04,0x02,0x04,0x02,0x0A,0x00,0xF1,0x7F,0x00,0x00},
  17.
  18.         {0x80,0x00,0x80,0x00,0xFC,0x3F,0x80,0x00,0x90,0x0C,0xA0,0x04,0xC0,0x02,0xFE,0x7F,
  19.         0x80,0x01,0xC0,0x02,0xA0,0x04,0x90,0x18,0x8C,0x70,0x83,0x20,0x80,0x00,0x80,0x00},
  20.
  21.         {0x60,0x02,0x1C,0x0A,0x10,0x12,0x10,0x12,0x10,0x02,0xFF,0x7F,0x10,0x02,0x10,0x12,
  22.         0x70,0x14,0x1C,0x0C,0x13,0x04,0x10,0x0A,0x90,0x49,0x10,0x50,0x14,0x60,0x08,0x40},
  23.
  24.         {0x40,0x00,0x80,0x00,0xFE,0x7F,0x02,0x40,0x21,0x22,0x10,0x04,0x08,0x08,0x04,0x10,
  25.         0xF8,0x0F,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFE,0x3F,0x00,0x00},
  26.
  27.         {0x04,0x00,0xC8,0x3F,0x08,0x20,0x02,0x20,0xE2,0x27,0x22,0x24,0x22,0x24,0xE2,0x27,
  28.         0x22,0x24,0x22,0x24,0xE2,0x27,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x28,0x02,0x10}
  29. };
  30. uchar select_hc138[][4]=
  31. {
  32.         {0x20,0x21,0x22,0x23},
  33.         {0x24,0x25,0x26,0x27},
  34.
  35.         {0x10,0x11,0x12,0x13},
  36.         {0x14,0x15,0x16,0x17},
  37.         {0x18,0x19,0x1a,0x1b},
  38.         {0x1c,0x1d,0x1e,0x1f}
  39. };
  40. void delay(void)
  41. {
  42.         uchar i;
  43.         for(i=0;i<20;i++);
  44. }
  45. void plany(void)
  46. {
  47.         uchar i,j,k;
  48.         for(k=0;k<6;k++)
  49.         {
  50.                 for(j=0;j<1;j++)
  51.                 {
  52.                         for(i=0;i<8;i++)
  53.                         {
  54.                                 CTRL_PORT=select_hc138[k][0];
  55.                                 DATA_PORT=zifu[k][2*i];
  56.
  57.                                 ADDR_PORT=i;
  58.                                 delay();
  59.
  60.                                 CTRL_PORT=select_hc138[k][1];
  61.                                 DATA_PORT=zifu[k][2*i+1];
  62.
  63.                                 ADDR_PORT=i;
  64.                                 delay();
  65.                         }
  66.                         for(i=8;i<16;i++)
  67.                         {
  68.                                 CTRL_PORT=select_hc138[k][2];
  69.                                 DATA_PORT=zifu[k][2*i];
  70.
  71.                                 ADDR_PORT=i-8;
  72.                                 delay();
  73.
  74.                                 CTRL_PORT=select_hc138[k][3];
  75.                                 DATA_PORT=zifu[k][2*i+1];
  76.
  77.                                 ADDR_PORT=i-8;
  78.                                 delay();
  79.                         }
  80.                 }
  81.         }
  82. }
  83. void PORT_init()//可放main中,初始化分開放main看起來(lái)簡(jiǎn)節(jié)一些
  84. {
  85.         TMOD=0x01;
  86.         TH0=0xb1;
  87.         TL0=0xe0;
  88.         ET0=1;
  89.         EA=1;
  90. }
  91. void main()
  92. {
  93.         PORT_init();
  94.         while(1)
  95.         {
  96.                 p=zifu;
  97.                 plany();//此處加一定的延時(shí),讓P=另外一個(gè)定義數(shù)組,就能達(dá)到換內(nèi)容的效果
  98.         }
  99. }
  100. void timer0() interrupt 1 using 3
  101. {
  102.         TF0=0;
  103.         TH0=0xb1;
  104.         TL0=0xe0;
  105. }
附上原碼,仿真,取字工具
51知識(shí)點(diǎn)16vs16點(diǎn)陣基本操作.rar (342.7 KB, 下載次數(shù): 104)
評(píng)分
參與人數(shù) 7黑幣 +117 收起 理由
鉆牛尖滴劉尖尖 + 10
areyouok + 12 絕世好帖!
Sawardeakar + 12
shuisheng + 15 很給力!
Trump1438 + 10 很給力!
#include51.h + 8 贊一個(gè)!
查看全部評(píng)分
收藏收藏3 分享淘帖 頂 踩
ID:454000 發(fā)表于 2019-1-26 18:52 | 只看該作者
我來(lái)過(guò)一陣子!哈哈哈!
評(píng)分
參與人數(shù) 3黑幣 +42 收起 理由
站著說(shuō)話不腰疼 + 15
鉆牛尖滴劉尖尖 + 15
areyouok + 12 贊一個(gè)!
查看全部評(píng)分
ID:378732 發(fā)表于 2019-1-28 15:47 | 只看該作者
學(xué)習(xí)一下。
ID:472268 發(fā)表于 2019-2-7 00:33 | 只看該作者
真的不錯(cuò)!來(lái)你空間好好看了看
ID:474670 發(fā)表于 2019-2-9 13:59 | 只看該作者
很不錯(cuò),學(xué)習(xí)了
ID:475444 發(fā)表于 2019-2-11 13:33 | 只看該作者
強(qiáng)大,好人啊!
ID:478073 發(fā)表于 2019-2-19 19:21 | 只看該作者
強(qiáng)人啊!么么噠!
ID:478301 發(fā)表于 2019-2-19 23:42 | 只看該作者
很不錯(cuò),學(xué)習(xí)了,厲害厲害
ID:473186 發(fā)表于 2019-3-7 23:08 | 只看該作者
收下了,學(xué)習(xí)一下。
ID:485829 發(fā)表于 2019-10-14 22:02 | 只看該作者
贊,學(xué)習(xí)了
ID:413383 發(fā)表于 2019-10-14 23:31 | 只看該作者
收下了,學(xué)習(xí)一下。
ID:278783 發(fā)表于 2019-10-17 07:18 | 只看該作者
沒有仿真啊
