查看: 2689|回復: 1
關于單片機循跡小車的一些小問題,需要在循跡1分半鐘后跳出主函數實現直行5秒
ID:281692 發表于 2018-12-22 20:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
30黑幣
大背景是一個51單片機控制的一個小車,但需要在循跡1分半鐘后跳出主函數實現直行5秒,再返回主函數,拜托各位大神出出主意,
原代碼如下:#include <REGX52.H>
sbit LeftIR=P3^5;
sbit RightIR=P3^6;
sbit xunjiLED=P2^1;
sbit M1A=P0^0;
sbit M1B=P0^1;
sbit M2A=P0^2;
sbit M2B=P0^3;
sbit B1=P0^4;
sbit SB1=P0^6;
void tingzhi()
   M1A=0;                                   //??M1???A???????0
   M1B=0;                                   //??M1???B???????0
   M2A=0;                                   //??M2???A???????0
   M2B=0;
void qianjin()
   M1A=1;
   M1B=0;
   M2A=1;
   M2B=0;
void houtui()
   M1A=0;
   M1B=1;
   M2A=0;
   M2B=1;
void zuozhuan()
   M1A=0;
   M1B=1;
   M2A=1;
   M2B=0;
void youzhuan()
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=1;
void delay_nus(unsigned int i)
  i=i/10;
  while(--i);
void delay_nms(unsigned int n)
  n=n+1;
  while(--n)
  delay_nus(900);
void ControlCar(unsigned char ConType)
  tingzhi();
switch(ConType)
  case 1:  //???
    qianjin();
    break;
  case 2: //????
    houtui();
    break;
  case 3: //???
    zuozhuan();                               //M2??????
break;
  case 4: //???                          //?ж?????????????4
    youzhuan();                                //M1??????
                                          //M2??????
break;
  case 8: //??                          //?ж?????????????8
    tingzhi();
break;                                //?????????
void main()                               //?????????
  bit RunFlag=0;                          //????С?????б??λ
  //RunShow=0;                              //??????????
  ControlCar(8);                          //?????С????????
  while(1)                                //?????????
   xunjiLED = 0 ;
   Start:
   if(LeftIR == 0 && RightIR == 0)
      ControlCar(1);
      delay_nms (10);
   goto NextRun;
   if(LeftIR == 0 && RightIR == 1)
      ControlCar(3);
      delay_nms (10);
   goto NextRun;
   if(LeftIR == 1 && RightIR == 0)
      ControlCar(4);
      delay_nms (10);
   goto NextRun;
   if(LeftIR== 1&&RightIR == 1)
     ContrplCar(4);
     delay_nms(10);
  goto NextRun;
   goto Start;
   NextRun:
   ControlCar(8);
ID:123289 發表于 2018-12-24 11:22 | 只看該作者
如何理解你的“跳出主函數”?
