查看: 4762|回復: 0
AVR單片機定時器做的門鈴程序+電路
ID:21069 發(fā)表于 2018-12-22 12:11 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#define F_CPU  1000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define INT8U   unsigned char
#define INT16U  unsigned int
#define DoorBell() (PORTD ^= 0x01)          /
#define Key_DOWN() ((PINB & 0x80) == 0x00)
volatile INT16U soundDelay;                 //兩個不同取值分別對應于"叮","咚"
int main()
        DDRB = 0;      PORTB = 0xff;
        DDRD = 0xff;
        TCCR1B = 0x01;
        TCNT1 = -700;
        sei();
                if( Key_DOWN() )
                        TIMSK = _BV(TOIE1);
                        soundDelay = -700;
                        _delay_ms(400);
                        soundDelay = -1000;
                        _delay_ms(600);
                        TIMSK = 0x00;
ISR ( TIMER1_OVF_vect )
        DoorBell();
                TCNT1 = soundDelay;
參與人數(shù) 6黑幣 +70 收起 理由
站著說話不腰疼 + 8
鉆牛尖滴劉尖尖 + 10
刀刀見紅 + 15 很給力!
Sawardeakar + 12
shuisheng + 15 贊一個!
Trump1438 + 10 贊一個!
