實驗五 A/D轉(zhuǎn)換實驗
一、實驗?zāi)康?br />
1. 了解單片機的A/D的工作原理。
2. 掌握單片機的A/D的應(yīng)用。
二、實驗內(nèi)容
//1. 編寫程序,使用單片機的A/D轉(zhuǎn)換口,采集外部輸入電壓,并把采集到的電壓在四位數(shù)碼管上顯示出來,單位為V,并保留兩位小數(shù)。
typedef unsigned char uchar;
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned int uint;
#include <stc15.h>
#include <intrins.h>
void AdInit();
void Timer1Init(void); //2毫秒@11.0592MHz
void tuiwan();
// 0 1 2 3 4 5 6 7 8 9 A B C D E F
u8 code BLOCK[]={ 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
uint advcc[8]={0};
uint advin[8]={0};
u16 vin,vcc,vee;
uchar n=0;
uchar ch=3;
u8 wei=1;
tuiwan();
Timer1Init(); //2毫秒@11.0592MHz
AdInit();
EA=1;
void AdInit()
P1M0=0x00;
P1M1=0xFF;
P1ASF=0x28;
ADC_CONTR=0x80;
EADC=1;
ADC_CONTR=0x88|ch;
void Adsevr() interrupt 5
ADC_CONTR=0x80;
if(ch==3)
advcc[n]=(ADC_RES<<2)+(ADC_RESL&0x03);
ch=5;
ADC_CONTR=0x88|ch;
else if(ch==5)
advin[n]=(ADC_RES<<2)+(ADC_RESL&0x03);
n++;
if(n>=8)
n=0;
ch=3;
ADC_CONTR=0x88|ch;
void tuiwan()
P2M0 |= 0xF0;
P2M1 &= ~0xF0;
P0M0 = 0xFF;
P0M1 = 0x00;
void Timer1Init(void) //2毫秒@11.0592MHz
AUXR |= 0x40; //定時器時鐘1T模式
TMOD &= 0x0F; //設(shè)置定時器模式
TL1 = 0x9A; //設(shè)置定時初值
TH1 = 0xA9; //設(shè)置定時初值
TF1 = 0; //清除TF1標(biāo)志
ET1 = 1; //使能定時器0中斷
TR1 = 1; //定時器1開始計時
void tm1_isr() interrupt 3
u8 i;
vin=0;
vcc=0;
for(i=0;i<8;i++)
vin=vin+advin[i];
vcc=vcc+advcc[i];
vcc=vcc>>3;
vin=vin>>3;
vin=vcc/1024.0*vin;
switch ( wei )
case 1:
P27=1;
P0=BLOCK[vin/1000%10]|0x80;
P24=0;
wei=2;
break;
case 2:
P24=1;
P0=BLOCK[vin/100%10] ;
P25=0;
wei=3;
break;
case 3:
P25=1;
P0=BLOCK[vin/10%10];
P26=0;
wei=4;
break;
case 4:
P26=1;
P0=BLOCK[vin%10];
P27=0;
wei=1;
break;
