查看: 4947|回復: 0
4乘4矩陣鍵盤控制數碼管顯示(附上原理圖)
因為昨天只給了代碼,管理員讓補上原理圖,因為剛來貴地,沒有找到編輯窗口,所以重新發一下,希望可以幫助有需要的同學們#include<reg52.h>
unsigned char code seg7code[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char k;
void delay10ms(void)
        unsigned char i,j;
        for(i=20;i>0;i--)
        for(j=248;j>0;j--);
void Getchar ( )
unsigned char X,Y,Z;
P1=0x0f;
if(P1!=0x0f)
        delay10ms();
        if(P1!=0x0f)
                X=P1;
                P1=0xf0;
                Y=P1;
                Z=X|Y;
switch ( Z )
                                case 0xee: k=0; break;
                                case 0xed: k=1; break;
                                case 0xeb: k=2; break;
                                case 0xe7: k=3; break;
                                case 0xde: k=4; break;
                                case 0xdd: k=5; break;
                                case 0xdb: k=6; break;
                                case 0xd7: k=7; break;
                                case 0xbe: k=8; break;
                                case 0xbd: k=9; break;
                                case 0xbb: k=10;break;
                                case 0xb7: k=11;break;
                                case 0x7e: k=12;break;
                                case 0x7d: k=13;break;
                                case 0x7b: k=14;break;
                                case 0x77: k=15;break;
                P1=0xff;
                Getchar();                //調用取鍵值函數
                P0=seg7code[k]
                P=0x0f;
原理圖
原理圖
