- #include "PID.h"
- #include "stm32f10x.h"
- #include "motor.h"
- #include "delay.h"
- u16 ReadData = 0xffff;
- int BasicSpeed = 0;
- int LeftSpeed = 0;
- int RightSpeed = 0;
- int basespeed = 530;
- unsigned char bizhangflag1 = 0;
- unsigned char bizhangflag2 = 0;
- unsigned char bizhangflag3 = 0;
- unsigned char catchflag = 0;
- //紅外對管對應于PF1~PF10
- void TIM4_IRQHandler(void)
- static int LastError = 0;
- static int CurrentError = 0;
- static unsigned int PIDCounter = 0;
- unsigned char PIDflag = 0;
- static int DiffError = 0;
- // static int delay_time = 0;
- // static int IntError = 0;
- int Output = 0;
- unsigned char cornerflag = 0;
- if(TIM_GetITStatus(TIM4,TIM_IT_Update)==SET)
- // TIM_Cmd(TIM4, DISABLE);
- ReadData = GPIO_ReadInputData(GPIOF);
- /***************************************特殊情況******************************************************/
- /***************************************直角情況*******************************************/
- if(ReadData == 0xff81||ReadData==0xff03||ReadData==0xff01||ReadData==0xffc1||ReadData==0xff83||ReadData==0xff07||
- ReadData == 0xffe1||ReadData==0xffc3||ReadData==0xff87)
- delay_ms(15);
- if(GPIO_ReadInputData(GPIOF)==0xffff)
- motor(0,0);
- delay_ms(10);
- motor(-500,-500);
- delay_ms(250);
- motor(-500,500);
- while((GPIO_ReadInputData(GPIOF)!= 0xff9f)&&(GPIO_ReadInputData(GPIOF)!=0xffbf)&&(GPIO_ReadInputData(GPIOF)!=0xff1f)
- &&(GPIO_ReadInputData(GPIOF)!=0xff3f)&&(GPIO_ReadInputData(GPIOF)!=0xff8f));
- cornerflag = 1;
- if(ReadData ==0xf80f||ReadData ==0xf81f||ReadData==0xfc0f||ReadData==0xfc1f||ReadData==0xf83f||ReadData==0xfe0f||
- ReadData ==0xf87f||ReadData ==0xfc3f||ReadData==0xff0f)
- delay_ms(10);
- motor(0,0);
- delay_ms(10);
- motor(-500,-500);
- delay_ms(250);
- motor(500,-500);
- while((GPIO_ReadInputData(GPIOF)!= 0xff9f)&&(GPIO_ReadInputData(GPIOF)!=0xffbf)&&(GPIO_ReadInputData(GPIOF)!=0xff1f)&&
- (GPIO_ReadInputData(GPIOF)!=0xff3f)&&(GPIO_ReadInputData(GPIOF)!=0xff8f));
- cornerflag = 1;
- /***********************************虛線情況******************************/
- if(ReadData == 0xffff)
- motor(540,550);
- delay_us(30);
- cornerflag = 1;
- if(PIDCounter<10)
- PIDCounter++;
- if(PIDCounter == 10)
- PIDflag = 1;
- PIDCounter = 0;
- if((PIDflag == 1)||(cornerflag == 1))
- PIDflag=0;
- cornerflag = 0;
- LastError = CurrentError;
- switch(ReadData) //使用Pf1~Pf10
- case 0xff9f:CurrentError = 0;break;//1111 111110011110
- case 0xffbf:CurrentError = 1;break;//1111 111110111110
- case 0xff3f:CurrentError = 3;break;//1111 111100111110
- case 0xff7f:CurrentError = 4;break;//1111 111101111110
- case 0xfe7f:CurrentError = 6;break;//1111 111001111110
- case 0xfeff:CurrentError = 7;break;//1111 111011111110
- case 0xfcff:CurrentError = 9;break;//1111 110011111110
- case 0xfdff:CurrentError = 12;break;//1111 110111111110
- case 0xf9ff:CurrentError = 14;break;//1111 100111111110
- case 0xfbff:CurrentError = 16;break;//1111 101111111110
- case 0xffdf:CurrentError = -0;break;//1111 111111011110
- case 0xffcf:CurrentError = -1;break;//1111 111111001110
- case 0xffef:CurrentError = -3;break;//1111 111111101110
- case 0xffe7:CurrentError = -6;break;//1111 111111100110
- case 0xff77:CurrentError = -7;break;//1111 111101110110
- case 0xfff3:CurrentError = -9;break;//1111 111111110010
- case 0xfffb:CurrentError = -12;break;//1111 11111111010
- case 0xfff9:CurrentError = -14;break;//1111 11111111000
- case 0xfffc:CurrentError = -16;break;//1111 11111111100
- case 0xff1f:CurrentError = 3;break;//1111 111100011110
- case 0xfe3f:CurrentError = 6;break;//1111 111000111110
- case 0xfc7f:CurrentError = 12;break;//1111 110001111110
- case 0xf8ff:CurrentError = 17;break;//1111 100011111110
- case 0xff8f:CurrentError = -3;break;//1111 111110001110
- case 0xffc7:CurrentError = -6;break;//1111 111111000110
- case 0xffe3:CurrentError = -12;break;//1111 111111100010
- case 0xfff1:CurrentError = -17;break;//1111 111111110000
- default:break;
- if((CurrentError-LastError)>=6||((CurrentError-LastError)<=-6))
- BasicSpeed = 80 ;
- if((CurrentError>=7)||(CurrentError<=-7))
- BasicSpeed = 40;
- else
- BasicSpeed = basespeed;
- DiffError = CurrentError - LastError;
- Output = CurrentError * 45 + DiffError * 560 ;
- LeftSpeed = BasicSpeed - 6 + Output;
- RightSpeed = BasicSpeed - Output;
- if(LeftSpeed>550)
- LeftSpeed = 550;
- else if(LeftSpeed < -500)
- LeftSpeed = -500;
- if(RightSpeed>550)
- RightSpeed = 550;
- else if(RightSpeed < -500)
- RightSpeed = -500;
- motor(LeftSpeed,RightSpeed);
- //TIM_ClearITPendingBit(TIM4,TIM_FLAG_Update);
- // TIM_Cmd(TIM4, ENABLE);
- TIM_ClearITPendingBit(TIM4,TIM_FLAG_Update);
- void EXTI4_IRQHandler(void)
- TIM_Cmd(TIM4, DISABLE);
- // delay_ms(15);
- if( GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_4)==0)
- if(bizhangflag1 == 0) //第一次壁障 抄近道
- bizhangflag1 = 1;
- motor(0,0);
- delay_ms(145);
- motor(0,500);
- delay_ms(200);
- motor(545,550);
- delay_ms(1160);
- (GPIO_ReadInputData(GPIOF)!=0xff3f)&&(GPIO_ReadInputData(GPIOF)!=0xff8f)&&(GPIO_ReadInputData(GPIOF)!=0xffc7)
- &&(GPIO_ReadInputData(GPIOF)!=0xfe3f)&&(GPIO_ReadInputData(GPIOF)!=0xffbf)&&(GPIO_ReadInputData(GPIOF)!=0xffcf)
- &&(GPIO_ReadInputData(GPIOF)!=0xfff9)&&(GPIO_ReadInputData(GPIOF)!=0xf9ff)&&(GPIO_ReadInputData(GPIOF)!=0xfffb)&&
- (GPIO_ReadInputData(GPIOF)!=0xfdff));
- else
- if(bizhangflag3 == 0) //第二次壁障 減速 準備抓東西
- catchflag = 1;
- bizhangflag3 = 1;
- motor(0,0);
- delay_ms(400);
- basespeed = 120;
- else if(bizhangflag3 == 1) //第三次壁障 減速 準備放東西
- catchflag = 1;
- basespeed = 200;
- TIM_Cmd(TIM4, ENABLE);
- EXTI_ClearITPendingBit(EXTI_Line4);
- void EXTI2_IRQHandler(void)
- // delay_ms(5);
- if( (GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_2)==0)&&(catchflag == 1))
- if(bizhangflag2 == 0) //第一次觸碰開關 抓東西 繞開障礙物
- catchflag = 0;
- bizhangflag2= 1;
- motor(50,50);
- delay_ms(10);
- basespeed = 490;
- starthand();
- delay_ms(500);
- motor(-400,-400);
- delay_ms(400);
- motor(0,0);
- delay_ms(100);
- // motor(400,0);
- //delay_ms(8);
- // motor(0,0);
- // delay_ms(100);
- motor(280,540);
- &&(GPIO_ReadInputData(GPIOF)!=0xfe3f)&&(GPIO_ReadInputData(GPIOF)!=0xffbf)&&(GPIO_ReadInputData(GPIOF)!=0xffcf));
- // motor(0,0);
- delay_ms(30);
- else //第二次觸碰開關 放東西 全場結束
- motor(0,0);
- delay_ms(100);
- endhand();
- while(1); //全場結束
- EXTI_ClearITPendingBit(EXTI_Line2);
巡線小車程序.7z
(209.03 KB, 下載次數: 32)
2018-12-20 16:19 上傳
