查看: 4656|回復: 8
2019過年還有多少天____看過來
名稱:2018過年倒計時
#include<reg51.h>
#include<intrins.h>
#include "delay.h"
#define clock_segment XBYTE[0xBFFF] //時鐘段碼地址
#define clock_sel XBYTE[0x7FFF]     //時鐘位碼地址
#define year_segment XBYTE[0xEFFF]  //日歷段碼地址
#define year_sel XBYTE[0xDFFF]      //日歷位碼地址
#define retime_segment XBYTE[0xFBFF]//倒計時段碼地址
#define retime_sel XBYTE[0xF7FF]    //倒計時位碼地址
unsigned char time_num=0;//定時一秒次數
unsigned char shi_num=24;//小時位計數
unsigned char miao_ge=0; //秒個位
unsigned char miao_shi=0;//秒十位
unsigned char fen_ge=0;//分個位
unsigned char fen_shi=0;//分十位
unsigned char shi_ge=0;//時個位
unsigned char shi_shi=0;//時十位
unsigned char year_thousand=2;
unsigned char year_hundred=0;
unsigned char year_decade=1;
unsigned char year_unit=8;
unsigned char month_decade = 1;
unsigned char month_unit=2;
unsigned char day_decade=1;
unsigned char day_unit=8;
unsigned char retime_unit=3;
unsigned char retime_decade=1;
unsigned char retime_hundred=0;
unsigned char retime_thousand=0;
unsigned char year_thoustore; //保存年千位數據
unsigned char year_hundstore; //保存年百位數據
unsigned char year_decastore; //保存年十位數據
unsigned char year_unitstore; //保存年個位數據
unsigned char month_unitstore;//保存月個位數據
unsigned char month_decastore;//保存月十位數據
unsigned char day_unitstore;  //保存日個位數據
unsigned char day_decastore;  //保存日十位數據
unsigned char year_unitstore2;//保存年各位數據
unsigned char year_decastore2;//年位組合子程序用來保護數據用
unsigned char year_hundstore2;
unsigned char year_thoustore2;
unsigned char retime_ustore;  //保存倒計時各位數據
unsigned char retime_dstore;
unsigned char retime_hstore;
unsigned char retime_tstore;
unsigned char day_numj=31;  //奇數月31天
unsigned char day_numo=30;  //偶數月30天
unsigned char day_numooo=30;
unsigned char day_numoo;
unsigned char month_num=12;
unsigned int year_jointed; //年各位組合在一起,以便進行閏年判斷
unsigned int year_help1;
unsigned int year_help2;
unsigned char xiaoshi_ge;//閃爍時存小時個位
unsigned char xiaoshi_shi;//閃爍時存小時十位
unsigned char fenzhong_ge;//閃爍時存分鐘個位
unsigned char fenzhong_shi;//閃爍時存分鐘十位
unsigned char cort=0;//判斷第幾次按下確認鍵
sbit key_sure=P1^0;//調時或確認鍵
sbit key_dec=P1^2;//調時減鍵
bit first_sure=0; //第一次按下確認鍵
bit second_sure=0;//第二次按下確認鍵
bit third_sure=0; //第三次按下確認鍵
bit fourth_sure=0;//第四次按下確認鍵
bit fifth_sure=0; //第五次按下確認鍵
bit sixth_sure=0; //第六次按下確認鍵
bit seventh_sure=0;//第七次按下確認鍵
unsigned code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};//段碼表
/************函數聲明*************/
void shannum_jian(void);
void inc_key(void);
void dec_key(void);
void dis_dingshi(void);
void hour_shanshuo(void);
void min_shanshuo(void);
void kbscan(void);
void display(void);
void year_joint(void);
unsigned char judgement_leap(void);
void retime_flash(void);
    year_joint();       //調用年各位組合子程序
    if((year_jointed%4==0&&year_jointed%100!=0)||(year_jointed%100==0&&year_jointed%400==0))return(29); //是閏年二月29天
    else return(28);    //是平年二月28天
按鍵掃描子程序
void kbscan(void)
    unsigned char sccode;
    P1=0xff;
    if((P1&0xff)!=0xff)
        //delay(5);
        display();
        display();
        display();
        if((P1&0xff)!=0xff)
             sccode=P1;
             //while((P1&0xff)!=0xff)     //按鍵后消陡
             switch(sccode)
                case 0xfe:shannum_jian();break;
                case 0xfd:inc_key();         break;
                case 0xfb:dec_key();         break;
                default:                                  break;
確認鍵按鍵次數子程序
    cort++;
    if(cort==1)          //第一次按下確認鍵
        first_sure=1;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==2)    //第二次按下確認鍵
        first_sure=0;
        second_sure=1;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==3)    //第三次按下確認鍵
        first_sure=0;
        second_sure=0;
        third_sure=1;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==4)   //第四次按下確認鍵
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=1;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==5)   //第五次按下確認鍵
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=1;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==6)   //第六次按下確認鍵
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=1;
        seventh_sure=0;
    else if(cort==7)  //第七次按下確認鍵
        cort=0;
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=1;
void year_flash(void)
    unsigned char i;
    if(third_sure)
         year_thoustore=year_thousand;
         year_hundstore=year_hundred;
         year_decastore=year_decade;
         year_unitstore=year_unit;
         while(third_sure)
            for(i=0;i<18;i++)       //年位不顯示,其它位都顯示
                year_thousand=10;
                year_hundred=10;
                year_decade=10;
                year_unit=10;
                fen_ge=fenzhong_ge;
                fen_shi=fenzhong_shi;
                display();
                kbscan();
                if(!third_sure)i=51;   //如果不滿足立即跳出
            if(third_sure)
                for(i=0;i<18;i++)      //年位和其它位都顯示
                     year_thousand=year_thoustore;
                     year_hundred=year_hundstore;
                     year_decade=year_decastore;
                     year_unit=year_unitstore;
                     fen_ge=fenzhong_ge;
                         display();
                         kbscan();
月位閃爍子程序
void month_flash(void)
    unsigned char i;
    if(TR0==0)                                  //為日位潤平年二月天數做準備
            day_numo=judgement_leap();
            day_numoo=day_numo;
    if(fourth_sure)
        month_unitstore=month_unit;
        month_decastore=month_decade;
        while(fourth_sure)
            for(i=0;i<18;i++)
                 month_unit=10;
                 month_decade=10;
                 year_thousand=year_thoustore;    //送原始數據避免取到不顯示數據
                 display();
                 kbscan();
                 if(!fourth_sure)i=51;
            if(fourth_sure)
                 for(i=0;i<18;i++)
                    month_unit=month_unitstore;
                    month_decade=month_decastore;//送原始數據避免取到不顯示數據
                        display();
                        kbscan();
日位閃爍子程序
void day_flash(void)
    unsigned char i;
    if(fifth_sure)
        day_unitstore=day_unit;
        day_decastore=day_decade;
        while(fifth_sure)
            for(i=0;i<18;i++)
                day_unit=10;
                day_decade=10;
                month_unit=month_unitstore;       //送原始數據避免取到不顯示數據
                display();
                kbscan();
                if(!fifth_sure)i=51;
            if(fifth_sure)
                for(i=0;i<18;i++)
                     day_unit=day_unitstore;
                     day_decade=day_decastore;
                         display();
                         kbscan();
倒計時位閃爍子程序
    unsigned char i;
    if(sixth_sure)
        retime_ustore=retime_unit;
        retime_dstore=retime_decade;
        retime_hstore=retime_hundred;
        retime_tstore=retime_thousand;
        while(sixth_sure)
             for(i=0;i<18;i++)
                retime_unit=10;
                retime_decade=10;
                retime_hundred=10;
                retime_thousand=10;
                display();
                kbscan();
                if(!sixth_sure)i=51;
             if(sixth_sure)
                for(i=0;i<18;i++)
                   retime_unit=retime_ustore;
                   retime_decade=retime_dstore;
                   retime_hundred=retime_hstore;
                   retime_thousand=retime_tstore;
                   display();
                   kbscan();
        if(seventh_sure)                 //第八次確認鍵按下,啟動定時器,將各位的數據全部彈出,時鐘正常顯示
            seventh_sure=0;
            fen_ge=fenzhong_ge;
            shi_ge=xiaoshi_ge;
            shi_shi=xiaoshi_shi;
            TR0=1;
小時位閃爍子程序
void hour_flash(void)
    unsigned char i;
    if(first_sure)
        TR0=0;                //關定時器,進入閃爍
        xiaoshi_ge=shi_ge;    //保存時個位顯示的數據
        xiaoshi_shi=shi_shi;  //保存時十位顯示的數據
        while(first_sure)     //第一次確認鍵按下,在小時位閃爍
            for(i=0;i<18;i++) //小時位不顯示,其它位顯示
                shi_ge=10;
                shi_shi=10;
                display();
                kbscan();
                if(!first_sure)i=51;
            if(first_sure)
                for(i=0;i<18;i++)//小時位和其它位都顯示
                    shi_ge=xiaoshi_ge;
                        display();
                        kbscan();
分鐘位閃爍子程序
void min_flash(void)
    unsigned char i;
    if(second_sure)
            fenzhong_ge=fen_ge;     //保存分個位顯示的數據
            fenzhong_shi=fen_shi;   //保存分十位顯示的數據
            while(second_sure)      //第二次確認鍵按下,在分鐘位閃爍
                for(i=0;i<18;i++)//分鐘位不顯示,其它位都顯示
                        fen_ge=10;
                        fen_shi=10;
                    shi_ge=xiaoshi_ge;  //送小時個位的原始數據,避免調到小時個位不顯示時的數據
                    shi_shi=xiaoshi_shi;//送小時十位的原始數據,避免調到小時十位不顯示時的數據
                        display();
                        kbscan();
                    if(!second_sure)i=51;
                if(second_sure)
                    for(i=0;i<18;i++)      //分鐘位和其它位都顯示
                        fen_ge=fenzhong_ge;
                                display();
                                kbscan();
年位組合子程序
    year_unitstore2=year_unitstore;       //保存年各位數據
    year_decastore2=year_decastore;
    year_hundstore2=year_hundstore;
    year_thoustore2=year_thoustore;
    year_jointed=year_unitstore;
    year_decastore=year_decastore<<4;
    year_decastore=year_decastore&0xf0;
    year_jointed=year_jointed+year_decastore;       //得到年的抵8位
    year_jointed=year_jointed<<8;               //將年的低8和高8互換
    year_jointed=year_jointed+year_hundstore;
    year_thoustore=year_thoustore<<4;
    year_thoustore=year_thoustore&0xf0;
    year_jointed=year_jointed+year_thoustore;   //得到年,需將其進行高8與低8互換
    year_help1=year_jointed&0xff00;
    year_help1=year_help1>>8;                       //得到年低8位
    year_help2=year_jointed&0x00ff;
    year_help2=year_help2<<8;                       //得到年高8位
    year_jointed=year_help1+year_help2;         // 得到年位
    year_unitstore=year_unitstore2;
    year_decastore=year_decastore2;
    year_hundstore=year_hundstore2;
    year_thoustore=year_thoustore2;             //彈出年各位數據
定時器0中斷子程序
void timer0(void) interrupt 1 using 1
    TH0=0x3c;
    TL0=0xb0;
    if((++time_num)==20)
            time_num=0;
            ++miao_ge;   //定時一秒到,秒個位加一
當秒個位加到9時進一,
    if(miao_ge==10)
        miao_ge=0;
        if((++miao_shi)==6)
            miao_shi=0;
            if((++fen_ge)==10)
                fen_ge=0;
                if((++fen_shi)==6)
                        fen_shi=0;
                    if((--shi_num)!=0)
                        if((++shi_ge)==10)
                                        shi_ge=0;
                                    ++shi_shi;
                    else if(shi_num==0)
                            shi_num=24;
                                shi_ge=0;
                                shi_shi=0;
                            if(retime_unit==0&retime_decade==0&retime_hundred==0&retime_thousand==0)//倒計時減一
                                 if((--retime_unit)==10)
                                              retime_unit=0;
                                    if((--retime_decade)==10)
                                                     retime_decade=0;
                                            if((--retime_hundred)==10)
                                                         retime_hundred=0;
                                                if((--retime_thousand)==10)
        retime_thousand=0;
                        if((month_unit|0xfe)==0xff)     //是奇數月,日為31天
                                    if((--day_numj)!=0)                        //31天沒到
                                                if((++day_unit)==10)
        day_unit=0;
        ++day_decade;
                                    else if(day_numj==0)                        //31天到了
                                                       day_numj=31;
                                                           day_unit=1;
                                                       day_decade=0;
                                        if((--month_num)!=0)                 //12個月沒到
                                                            if((++month_unit)==10)
        month_unit=0;
        ++month_decade;
                                        else if(month_num==0)         //12個月到了
        month_num=12;
        month_unit=1;
                                                            month_decade=0;
                                            if((++year_unit)==10)        //年個位是否到9
        year_unit=0;
                                                             if((++year_decade)==10)
        year_decade=0;
        if((++year_hundred)==10)
        year_hundred=0;
                                                        if((++year_thousand)==10)year_thousand=0;
                        else if((month_unit|0xfe)!=0xff)    //是偶數月,日為30天
                            if((--day_numo)!=0)                        //30天沒到
                                                 day_unit=0;
                                                ++day_decade;
                            else if(day_numo==0)                        //30天到了
                                       if(month_unit==2)
                                            if(day_numoo==28)
                                                        day_numo=28;
                                                        day_unit=1;
                                                        day_decade=0;
                                        else if(day_numoo==29)
                                                        day_numo=29;
                                                        day_unit=1;
                                                        day_decade=0;
                                                day_numj=30;
                                                   day_unit=1;
                                               day_decade=0;
                                                        month_unit=0;
                                                    ++month_decade;
                                                month_num=12;
                                                month_unit=1;
                                                month_decade=0;
                                                          year_unit=0;
                                                             year_decade=0;
        year_hundred=0;
/*************主程序**************/
void main(void)
    TMOD=0x01;
    TH0=0x3c;
    TL0=0xb0;
    EA=1;
    ET0=1;
    TR0=1;
        kbscan();       //調按鍵掃描
        display();      //六個數碼管顯示
        hour_flash();   //調小時位閃爍
        min_flash();    //調分鐘位閃爍
        year_flash();   //年閃爍
        month_flash();  //月閃爍
        day_flash();    //日閃爍
        retime_flash();
        dis_dingshi();  //到一秒加一,到一分加一,到一小時加一,到24點清零
2019過年還有多少天.zip (22.81 KB, 下載次數: 42)
ID:449256 發表于 2018-12-18 20:19 | 只看該作者
你們都好厲害......
ID:472242 發表于 2019-2-3 21:11 | 只看該作者
收下了,很不錯的例子
ID:472268 發表于 2019-2-7 00:33 | 只看該作者
好的話不多說,收下了你的資料
ID:471066 發表于 2019-2-7 15:10 | 只看該作者
棒極了,最好資料
ID:469417 發表于 2019-2-7 21:38 | 只看該作者
2019年!好樣的
ID:475444 發表于 2019-2-11 13:35 | 只看該作者
謝謝分享!實力超強!
ID:478073 發表于 2019-2-19 19:22 | 只看該作者
謝謝分享!很好
ID:403303 發表于 2019-2-19 23:56 | 只看該作者
等我刷到這個帖子的時候離過年還有  -15  天
