查看: 2248|回復: 0
C語言在Dis_str(i,0,*p)處報錯指針轉換錯誤 怎么改
ID:377512 發表于 2018-12-17 20:21 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit RS = P3^5;
sbit RW = P3^6;
sbit EN = P3^4;
#define LCD1602_A P0
void delay_ms(uint n)
uint i,y;
for(i=n;i>0;i--)
  for(y=114;y>0;y--);
void Read_busy()
   uchar busy;
         LCD1602_A = 0xff;
         RS = 0;
         RW = 1;
        do{
           EN = 1;
                 busy = LCD1602_A;
                 EN = 0;
        }while(busy & 0x80);
void Write_cmd(uchar cmd)
    Read_busy();
          RS = 0;
                RW = 0;
                LCD1602_A = cmd;
                EN = 1;
                EN = 0;
void Write_dat(uchar dat)
  Read_busy();
        RS = 1;
        RW = 0;
        LCD1602_A = dat;
        EN = 1;
        EN = 0;
void Dis_onechar(uchar x, uchar y, uchar dat)
   if(y) x |= 0x40;
           x |= 0x80;
        Write_cmd(x);
        Write_dat(dat);
void Dis_str(uchar x, uchar y, uchar *str)
   if(y) x |= 0x40;
            x |= 0x80;
         Write_cmd(x);
         while(*str != '\0')
            Write_dat(*str++);
void Init_LCD1602()
   Write_cmd(0x38);
         Write_cmd(0x0c);
         Write_cmd(0x06);
         Write_cmd(0x01);
        uchar i = 1;
        uchar str[20]={"Just do it ! "} ;
        uchar *p;
        p = str;
        Init_LCD1602();
  Dis_str(i,0,*p);
        i++;
        P++;
        delay_ms(1000);
        delay_ms(1000);
