查看: 4546|回復: 1
用矩陣鍵盤控制led點陣,就是一個按鍵控制顯示一個數字那種,求大神幫忙
ID:445287 發表于 2018-12-13 15:58 | 顯示全部樓層 |閱讀模式
10黑幣
#include<reg51.h>
#include<intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
//--定義要使用的IO口--//
#define GPIO_DIG P0
#define GPIO_KEY P1
#define READPORTS P2
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u8 KeyValue;
void delay(u16 i){
    while(i--);
* 函 數 名         : KeyDown
* 函數功能                   : 檢測有按鍵按下并讀取鍵值
* 輸    入         : 無
* 輸    出         : 無
void KeyDown(void)
        char a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
                delay(1000);//延時10ms進行消抖
                if(GPIO_KEY!=0x0f)//再次檢測鍵盤是否按下
                        //測試列
                        GPIO_KEY=0X0F;
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d): KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //測試行
                        GPIO_KEY=0XF0;
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //檢測按鍵松手檢測
                                delay(1000);
                                a++;
//--列選通控制--//
unsigned char code TAB[8] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
//--點陣字碼--//
unsigned char code CHARCODE[16][8] = {
{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
* 函數名         : Hc595SendByte(unsigned char dat)
* 函數功能                   : 想74H595發送一個字節的數據
* 輸入           : 無
* 輸出                  : 無
void Hc595SendByte(unsigned char dat)
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                SER=dat>>7;
                dat<<=1;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
void main(){
        LSA=0; //給一個數碼管提供位選
        LSB=0;
        LSC=0;
    unsigned char tab, j;
    unsigned int  i;//無符號整數
    while(1){
        for(i= 0; i<5000; i++ ){//兩個字之間的掃描間隔時間
            for(tab=0;tab<8;tab++)
                                KeyDown();
                Hc595SendByte(0x00);//消隱
                GPIO_DIG = TAB[tab];                                 //輸出字碼
                Hc595SendByte(CHARCODE[KeyValue][tab]);
                delay(2);
        j++;
        if(j == 16){
            j = 0;
ID:1 發表于 2018-12-13 21:23 | 顯示全部樓層
您這個問題給的信息不全,估計是沒人能回答得了的,先轉移到冷門區了,自行點擊編輯按鈕補充一下吧,審核員會幫你重新轉到熱門問答區的
