查看: 2008|回復(fù): 1
單片機(jī)驅(qū)動24c16的程序整不明白了
ID:419868 發(fā)表于 2018-12-13 15:52 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
uchar xdata timercode[30][4];
按鍵改寫數(shù)組4個元素后寫入        page_write((addr*0x04),&timercode[addr][0],4);//24c16頁寫入函數(shù)
開機(jī)整體讀出
E2_BitRead(0x00,&timercode[0],80);//24c16讀數(shù)據(jù)函數(shù)
主函數(shù)調(diào)用上面兩個,想開機(jī)讀取數(shù)組存到數(shù)組里,然后改變數(shù)組后寫入,掉電可以不丟數(shù)據(jù),為什么老不對呢?
哪位好心的大神給看看唄!
下面的應(yīng)該沒問題,之前用過這個驅(qū)動的!
#include<reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
typedef unsigned long ulong;
sbit SDA=P2^0;
sbit SCL=P2^1;
void E2_delay()
        _nop_();
        _nop_();
        _nop_();
        _nop_();
void E2_start()
        SDA=1;
        SCL=1;
        E2_delay();
        SDA=0;
        E2_delay();
        SCL=0;
void E2_stop()
        SDA=0;
        SCL=0;
        E2_delay();
        SCL=1;
        E2_delay();
        SDA=1;
uchar E2_write(uchar dat)
        uchar mask;
        uchar ack;
        for(mask=0x80;mask>0;mask>>=1)
                SCL=0;
                E2_delay();
                SDA=(dat&mask);
                E2_delay();
                SCL=1;
                E2_delay();
        SCL=0;
        SDA=1;
        E2_delay();
        SCL=1;
        ack=SDA;
        E2_delay();
        SCL=0;
        return (~ack)&0x01;
void E2_read_ack()
        SCL=0;
        E2_delay();
        SDA=0;
        E2_delay();
        SCL=1;
        E2_delay();
        SCL=0;
void E2_read_Nack()
        SCL=0;
        E2_delay();
        SDA=1;
        E2_delay();
        SCL=1;
        E2_delay();
        SCL=0;
void E2_BitRead(uchar addr,uchar *dat,uchar len)
        uchar i;
        do
                E2_start();
                if(E2_write(0xa0))
                        break;
        }while(1);
        E2_write(addr);
        E2_start();
        E2_write(0xa1);
        while(len)
                SDA=1;
                for(i=0x80;i>0;i>>=1)
                        SCL=1;
                        if(SDA)
                                *dat|=i;
                                *dat&=~i;
                        E2_delay();
                        SCL=0;
                        E2_delay();
                E2_read_ack();
                dat++;
                len--;
                if(len==0)
                                SCL=1;
                                if(SDA)
                                        *dat|=i;
                                        *dat&=~i;
                                E2_delay();
                                SCL=0;
                                E2_delay();
                        E2_read_Nack();
                        E2_stop();
                        break;
void page_write(uchar addr,uchar *dat,uchar len)
        while(len>0)
                do
                        E2_start();
                        if(E2_write(0xa0))
                                break;
                }while(1);
                E2_write(addr);
                while(len--)
                        E2_write(*dat++);
                        addr++;
                        if((addr&0x07)==0)
                                break;
                E2_stop();
ID:419868 發(fā)表于 2018-12-13 15:57 | 只看該作者
在線等,急,麻煩大神不吝賜教。。。!
