查看: 3606|回復(fù): 0
怎么用矩陣鍵盤控制8*8led點陣,控制部分怎么加進(jìn)去?
ID:445287 發(fā)表于 2018-12-13 15:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
//--定義要使用的IO口--//
#define COMMONPORTS                P0
//--列選通控制--//
unsigned char code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
//--點陣字碼--//
unsigned char code CHARCODE[18][8]=
{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}  //中
void delay(unsigned int time)
  unsigned int i,j;
  for(i=0;i<time;i++)
    for(j=0;j<121;j++);
* 函數(shù)名         : Hc595SendByte(unsigned char dat)
* 函數(shù)功能                   : 想74H595發(fā)送一個字節(jié)的數(shù)據(jù)
* 輸入           : 無
* 輸出                  : 無
void Hc595SendByte(unsigned char dat)
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                SER=dat>>7;
                dat<<=1;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
* 函數(shù)名         : main
* 函數(shù)功能                   : 主函數(shù)
* 輸入           : 無
* 輸出                  : 無
        unsigned char tab, j;
        unsigned int  i;
                for(i= 0; i<50; i++ )   //兩個字之間的掃描間隔時間
                        for(tab=0;tab<8;tab++)
                                Hc595SendByte(0x00);                             //消隱
                                COMMONPORTS        = TAB[tab];                                 //輸出字碼
                                Hc595SendByte(CHARCODE[j][tab]);
                                delay(2);
                j++;
                if(j == 18)
                        j = 0;
