查看: 1807|回復: 1
51單片機兩路循跡小車
ID:438586 發表于 2018-12-12 21:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define unint unsigned int
#define unchar unsigned char
sbit ENA = P2^0;
sbit ENB = P2^1;
sbit IN1 = P2^2;
sbit IN2 = P2^3;
sbit IN3 = P2^4;
sbit IN4 = P2^5;
sbit jiance1 = P1^0;  //????
sbit jiance2 = P1^1;  //????
int time1 = 0,shu = 0;
void zhengzhuan();
void youzhuan();
void zuozhuan();
void xunji();
void  Time0Config();
        Time0Config();
        P0=0xff;
           xunji();             //????
void  Time0Config()
        TMOD = 0x01;                //???0????1
        TH0 = 0x3C;
        TL0 = 0xB0;                        //?????????50ms
        ET0 = 1;                        //???0????
        TR0 = 1;
        EA  = 1;                                //?????
void zhengzhuan()
        int i;
        for(i=0;i<30;i++)
  IN1=1;
  IN2=0;
  IN3=1;
  IN4=0;
        for(i=0;i<10;i++)
  IN1=0;
  IN2=0;
  IN3=0;
  IN4=0;
void zuozhuan()
                int i;
        for(i=0;i<30;i++)
  IN1=1;
  IN2=0;
  IN3=0;
  IN4=0;
        for(i=0;i<10;i++)
  IN1=0;
  IN2=0;
  IN3=0;
  IN4=0;
void youzhuan()
                int i;
        for(i=0;i<30;i++)
   IN1=0;
   IN2=0;
   IN3=1;
   IN4=0;
        for(i=0;i<10;i++)
   IN1=0;
   IN2=0;
   IN3=0;
   IN4=0;
void stop()
                int i;
        for(i=0;i<100;i++)
   IN1=0;
   IN2=0;
   IN3=0;
   IN4=0;
void xunji()
                zhengzhuan();
                while(jiance1==1&&jiance2==0)
                        stop();
        //                break;
                while(jiance1==0&&jiance2==0)
                        zuozhuan();
                //        break;
                while(jiance1==1&&jiance2==1)
                        youzhuan();
                //        break;
void time0(void) interrupt 1     //???0??????
        TH0 = 0x3C;
        TL0 = 0xB0;
        time1++;
        if(!(time1 - 20))
        {  time1 = 0;
           shu++;
ID:1 發表于 2018-12-14 01:22 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
