查看: 2164|回復: 1
51單片機,數碼管顯示溫度
ID:438586 發表于 2018-12-12 21:08 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit DS=P2^2;
uint temp;
uchar flag1;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                        0x87,0xff,0xef};
void delay(uint count)
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)
   uint i;
   bit dat;
   DS=0;i++;
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);
  return(dat);
void tmpwritebyte(uchar dat)
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0x44);
uint tmp()
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)
   uchar A1,A2,A2t,A3;
   A1=temp/100;
   A2t=temp%100;
   A2=A2t/10;
   A3=A2t%10;
   dula=0;
   P0=table[A1];
   dula=1;
   dula=0;
   wela=0;
   P0=0x7e;
   wela=1;
   wela=0;
   delay(1);
   dula=0;
   P0=table1[A2];
   dula=1;
   dula=0;
   wela=0;
   P0=0x7d;
   wela=1;
   wela=0;
   delay(1);
   P0=table[A3];
   dula=1;
   dula=0;
   P0=0x7b;
   wela=1;
   wela=0;
   delay(1);
uchar a;
  do
    tmpchange();
        for(a=10;a>0;a--)
                  display(tmp());
  } while(1);
ID:1 發表于 2018-12-14 01:23 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
