題目:設(shè)置過(guò)程,有一個(gè)水位選擇按鍵,選擇6個(gè)水位之一,相應(yīng)的有六個(gè)水位檢測(cè)點(diǎn),仿真時(shí)用六個(gè)開關(guān)表示。有一個(gè)程序選擇按鍵,選擇8個(gè)程序之一。一個(gè)啟動(dòng)/停止鍵,按照所選程序自動(dòng)洗衣。(2)洗衣過(guò)程,模擬完成其中兩個(gè)自動(dòng)洗衣程序——標(biāo)準(zhǔn)洗和輕柔洗的執(zhí)行過(guò)程。打開進(jìn)水電磁閥,(電磁閥用一個(gè)LED燈模擬),人工閉合開關(guān)表示水位到了該開關(guān)代表的水位檢測(cè)器,關(guān)閉進(jìn)水電磁閥,然后電機(jī)(proteus里面有)反復(fù)正轉(zhuǎn)、反轉(zhuǎn),并用PWM波控制電機(jī)轉(zhuǎn)速,輕柔洗轉(zhuǎn)速慢,換向快,甩干轉(zhuǎn)速最快......,直到洗完。為縮短演示時(shí)間,應(yīng)把各步驟時(shí)間縮短。
程序:
#include <REG51F.H>
//#include<reg52.h>
//#include <math.h>
//#include <intrins.h>
sbit sw=P1^3;
sbit ms=P1^5;
sbit qt=P1^7;
sbit aa=P1^6;
sbit bb=P1^4;
sbit cc=P0^7;
sbit p0_5=P0^5;
sbit p0_4=P0^4;
sbit p0_3=P0^3;
sbit p0_2=P0^2;
sbit p0_1=P0^1;
sbit p0_0=P0^0;
uint g,m,l;
uchar i,j,k;
void delay(void)
for (g=0;
g<1000;
g++);
void init_T2(void)
T2CON =0;
T2MOD =0;
RCAP2H =(65536-50000)/256;
RCAP2L =(65536-50000)%256;
TH2 =(65536-50000)/256;
TL2 =(65536-50000)%256;
ET2 = 1;
PT2 = 1;
TR2 = 1;
void swxz(void)
if(sw==0)
delay();
if(sw==0)
i++;
if(i==7)
i=1;
while(sw==0);
switch(i)
case 1:{p0_0=0;p0_1=1;p0_2=1;p0_3=1;p0_4=1;p0_5=1;}
break;
case 2:{p0_0=1;p0_1=0;p0_2=1;p0_3=1;p0_4=1;p0_5=1;}
break;
case 3:{p0_0=1;p0_1=1;p0_2=0;p0_3=1;p0_4=1;p0_5=1;}
break;
case 4:{p0_0=1;p0_1=1;p0_2=1;p0_3=0;p0_4=1;p0_5=1;}
break;
case 5:{p0_0=1;p0_1=1;p0_2=1;p0_3=1;p0_4=0;p0_5=1;}
break;
case 6:{p0_0=1;p0_1=1;p0_2=1;p0_3=1;p0_4=1;p0_5=0;}
break;
default:break;
void swjc(void)
switch(i)
case 1:{if(P3==0x03)
{EA=1;k=4;}}
break;
case 2:{if(P3==0x07)
{EA=1;k=4;}}
break;
case 3:{if(P3==0x0f)
{EA=1;k=4;}}
break;
case 4:{if(P3==0x1f)
{EA=1;k=4;}}
break;
case 5:{if(P3==0x3f)
{EA=1;k=4;}}
break;
case 6:{if(P3==0x7f)
{EA=1;k=4;}}
break;
default:{EA=0;P3=0xff;};
void qdtz(void)
if(qt==0)
delay();
if(qt==0)
k++;
while(qt==0);
switch(k)
case 2:cc=0;
break;
case 5:{aa=1;bb=1;EA=0;i=10;j=10;}
break;
default:cc=1;
void biaozhun(void)
qdtz();
swjc();
void qita(void)
void msxz(void) //Ä£ê½Ñ¡Ôñoˉêy
if(ms==0)
delay();
if(ms==0)
j++;
if(j==9)
j=1;
while(ms==0);
switch(j)
case 1:{P2=0xfe;biaozhun();}
break;
case 2:{P2=0xfd;qita();}
break;
case 3:{P2=0xfb;qita();}
break;
case 4:{P2=0xf7;qita();}
break;
case 5:{P2=0xef;qita();}
break;
case 6:{P2=0xdf;qita();}
break;
case 7:{P2=0xbf;qita();}
break;
case 8:{P2=0x7f;qita();}
break;
default:P2=0xff;
void main(void) //Ö÷oˉêy
i=0,j=0,k=1,l=1,m=0,aa=1,bb=1,cc=1;
init_T2();
swxz();
msxz();
if(m==1)
aa=1;
bb=0;
if(m==40)
l++;
aa=~aa;
bb=~bb;
m=2;
if(l==10)
i=7;
EA=0;
aa=1;
bb=1;
void dingshi(void) interrupt 5
m++;
TF2=0;
