設計KeyTask任務,當按下KEY0時動態創建任務,最多可以創建10個任務,這10個任務都執行一個函數MyTask,要求優先級是(PRIO_BASE+0,1,2,3,4,5,6,7,8,9),還要向不同的任務傳遞不同的參數(0,1,2,3,4,5,6,7,8,9)給MyTask函數,優先級為 (PRIO_BASE+0,1,2,3,4,5,6,7,8,9)的任務分別輸出數字(0,1,2,3,4,5,6,7,8,9)到LCD屏。當按下KEY1時動態的刪除剛創建的一個任務, 最多可刪除10個任務。
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "lcd.h"
- int main(void)
- u8 x=0;
- u8 lcd_id[12]; //存放LCD ID字符串
- delay_init(); //延時函數初始化
- uart_init(9600); //串口初始化為9600
- LED_Init(); //初始化與LED連接的硬件接口
- LCD_Init();
- POINT_COLOR=RED;
- sprintf((char*)lcd_id,"LCD ID:%04X",lcddev.id);//將LCD ID打印到lcd_id數組。
- while(1)
- switch(x)
- case 0:LCD_Clear(WHITE);break;
- case 1:LCD_Clear(BLACK);break;
- case 2:LCD_Clear(BLUE);break;
- case 3:LCD_Clear(RED);break;
- case 4:LCD_Clear(MAGENTA);break;
- case 5:LCD_Clear(GREEN);break;
- case 6:LCD_Clear(CYAN);break;
- case 7:LCD_Clear(YELLOW);break;
- case 8:LCD_Clear(BRRED);break;
- case 9:LCD_Clear(GRAY);break;
- case 10:LCD_Clear(LGRAY);break;
- case 11:LCD_Clear(BROWN);break;
- POINT_COLOR=RED;
- LCD_ShowString(30,40,200,24,24,"Mini STM32 ^_^");
- LCD_ShowString(30,70,200,16,16,"TFTLCD TEST");
- LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,110,200,16,16,lcd_id); //顯示LCD ID
- LCD_ShowString(30,130,200,12,12,"2014/3/7");
- x++;
- if(x==12)x=0;
- LED0=!LED0;
- delay_ms(1000);
