項目:音頻音樂盒
設計時間:2017.4.10
硬件描述:
軟件描述:
* 【實驗平臺】: QX-MCS51 單片機開發(fā)板
* 【外部晶振】: 11.0592mhz
* 【主控芯片】: STC89C52
* 【編譯環(huán)境】: Keil μVisio3
* 【程序功能】: 實驗板唱歌實驗(歌曲:兩只老虎)
* 【使用說明】:
#include <at89x52.h>
bit flag; //標志音樂輸出腳電平的高低
uchar ptr = 0x00; //取音符
uchar high; //計數(shù)器高位
uchar low; //計數(shù)器低位
// 本曲譜為 "兩只老虎",前兩個十六進制表示發(fā)聲頻率,后一個表示發(fā)聲時間,0x7F,0xFF 表示休止符
// 0x00 表示結束
// 1 _ 1_ 1 .5
uchar code music[] = {
0xFC,0x44,0x7F, 0xFC,0xAC,0x7F, 0xFD,0x09,0x7F, 0xFC,0x44,0xFF,
// 1 _ 2 3_1 5
// 1_ 2 3_1
0xFD,0x09,0x7F, 0xFD,0x34,0x7F, 0xFD,0x82,0xFF,
// 3_ 4 5
// 3_ 4 5
0xFD,0x82,0x7F, 0xFD,0xCB,0x7F, 0xFD,0x82,0x7F, 0xFD,0x34,0x7F,0xFD,0x09,0X7F,0XFC,0X44,0XFF,
// 5_ 6 5_4 3 1
// 5_ 6 5_4 3 1
0xFC,0xAC, 0X7F,0xFC,0x44,0X7F, 0xFC,0xAC,0X7F,0xFA,0x44,0xFF,
// 2 5 1 0
0xFC,0xAC,0X7F, 0xFC,0x44,0X7F, 0xFC,0xAC,0X7F, 0xFA,0x44,0xFF,
// 2 5 1 0
0x00//結束
void Init(void); //初始化函數(shù)
void DelayMs(unsigned int time); //毫秒級延時函數(shù)
uchar time;
Init();
TH0 = high;
TL0 = low;
while (1)
if (music[ptr] != 0xFF && music[ptr] != 0x00)//判斷是否是正常音符
TR0 = 0;
P2_3 = 1;
DelayMs(10); //間歇
TR0 = 1;
high = music[ptr]; //取設置頻率數(shù)值的高8 位
low = music[ptr + 1]; //取設置頻率數(shù)值的低8 位
time = music[ptr + 2]; //取發(fā)聲時間
DelayMs(time);
ptr += 3;
else if (music[ptr] == 0xFF) //判斷是否是休止符
DelayMs(time);
ptr += 3;
else //結束符,停止2 秒后繼續(xù)
TR0 = 0;
P2_3 = 1;
DelayMs(2000);
ptr = 0;
* 名稱:Count1(void) interrupt 1
* 功能:設置計時器0 溢出中斷,每中斷一次改變P2_3 引腳電平
void Count1(void) interrupt 1
TH0 = high;
TL0 = low;
if (flag == 0) //改變P2_3 引腳電平
P2_3 = 0;
flag = 1;
P2_3 = 1;
flag = 0;
* 名稱:Init()
* 功能:設置計數(shù)器0 工作方式,16 位計數(shù),溢出中斷方式
void Init()
TMOD = 0x01; //定時器0 處于計時方式,16 位
EA = 1;
ET0 = 1; //定時器0 溢出中斷
* 名稱:DelayMs(unsigned int time)
* 功能:延時time * 1ms 時間
unsigned int i;
unsigned int j;
for (j =0; j < time; j++) //每個循環(huán) 約 3ms
for (i =0; i < 363; i++)
