查看: 5323|回復(fù): 0
單片機(jī)8路搶答器仿真+程序(共陽數(shù)碼管)
ID:376780 發(fā)表于 2018-12-11 09:23 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
//總源程序
#include<reg51.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
sbit K0=P3^0;                  //開始搶答按鍵
sbit beep=P3^7;                //蜂鳴器
sbit D0=P3^1;                  //指示燈
sbit K1=P1^0;                  //1號選手搶答按鍵
sbit K2=P1^1;                  //2號選手搶答按鍵
sbit K3=P1^2;                  //3號選手搶答按鍵
sbit K4=P1^3;                  //4號選手搶答按鍵
sbit K5=P1^4;                  //5號選手搶答按鍵
sbit K6=P1^5;                  //6號選手搶答按鍵
sbit K7=P1^6;                  //7號選手搶答按鍵
sbit K8=P1^7;                  //8號選手搶答按鍵
char s;
uchar num=0;
char  time1;                                           //搶答時間
char  time2;                                           //答題限時時間
uint  m,n;                                             //T0,T1定時器定一秒時
bit   flag1,flag2,flag3,flag4;                         //標(biāo)志位
bit   aa,bb;                                           //時間調(diào)整標(biāo)志位
                         //延時子函數(shù)
void delay(uint z)
{uint x,y;
   for(x=z;x>0;x--)
  for(y=120;y>0;y--); }
uchar code table1[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,~0x40};
uchar code table2[]={
                                   //共陽數(shù)碼管位碼值
                                              ~0xfe,~0xfd,
                                              ~0xfb,~0xf7 };
                        //初始化子函數(shù)
void init()
{TMOD=0x11;
    TH0=(65536-2000)/256;
    TL0=(65536-2000)%256;
    TH1=(65536-2000)/256;
    TL1=(65536-2000)%256;
    ET0=1;
    ET1=1;
    EA=1;
    P0=~0x00;
    time1=10;
    time2=10;
    flag2=1; }
                          //開始鍵掃描子函數(shù)
  void key1()
  {uchar i=100;
    if(K0==0)
   {delay(10);
       if(K0==0)
     {    while(K0==0&&i)
               {i--;
                  delay(10);}
           TR0=1;
           s=time1;
           m=0;
           flag1=1;
           flag2=1;
           flag3=1;
           num=0;
           beep=1;
           D0=1;
           flag4=0;                              //清除違規(guī)標(biāo)志位
           aa=0;
           bb=0;
                           //選手搶答按鍵掃描子函數(shù)
void key()
{uchar i=100;
         if(K1==0)
            {delay(10);
              if(K1==0)
              {while(K1==0&&i)
                {i--;
                  delay(10);}
                  num=1;                                    //數(shù)碼管顯示1號"1"
                  TR0=0;                                    //關(guān)閉定時器0,時間停止
                  TR1=1;                                    //打開定時器1,使揚(yáng)聲器響一聲
                  flag2=0;                                  //關(guān)閉開始鍵標(biāo)志位,使再按其他七個鍵不會響應(yīng)
      if(K2==0)                                              //下面七個鍵的處理同上
           delay(10);
           if(K2==0)
            {while(K2==0&&i)
              {i--;
               delay(10);}
             num=2;
             TR0=0;
             TR1=1;
             flag2=0;                    //重要
   if(K3==0)
       {delay(10);
         if(K3==0)
         {while(K3==0&&i)
            {i--;
              delay(10);}
          num=3;
          TR0=0;
          TR1=1;
          flag2=0;
   if(K4==0)
    {delay(10);
       if(K4==0)
         {while(K4==0&&i)
             {i--;
               delay(10);}
           num=4;
           TR0=0;
           TR1=1;
           flag2=0;
   if(K5==0)
    {delay(10);
      if(K5==0)
         {while(K5==0&&i)
            {i--;
               delay(10);}
           num=5;
           TR0=0;
           TR1=1;
           flag2=0;
  if(K6==0)
  {delay(10);
   if(K6==0)
     {while(K6==0&&i)
           {i--;
             delay(10);}
          num=6;
          TR0=0;
          TR1=1;
          flag2=0;
if(K7==0)
    {delay(10);
           if(K7==0)
              {while(K7==0&&i)
                      {i--;
                             delay(10);}
                     num=7;
                         TR0=0;
                         TR1=1;
                         flag2=0;
  if(K8==0)
      {delay(10);
             if(K8==0)
                    {while(K8==0&&i)
                             {i--;
                                    delay(10);}
                          num=8;
                          TR0=0;
                          TR1=1;
                          flag2=0;
                            //數(shù)碼管顯示子函數(shù)
void display()
   {if(flag1==1)                                            //開始鍵按下,開始計時搶答
      {if(num!=0)                                           //如果有人搶答,則顯示相應(yīng)的幾號
             {P0=table1[num];                                   //顯示幾號搶到了
                  P2=table2[0];
                   delay(2);
                   P0=~0;
                   P2=~0xff;
                 else                                                  //否則沒人搶答,則前面不顯示幾號
                 {P0=~0x00;
                   P2=~0xff;}
                  P0=table1[s/10];                                     //下面為顯示搶答倒計時
                  P2=table2[2];
                  delay(2);
                  P0=~0;
                  P2=~0xff;
                  P0=table1[s%10];
                  P2=table2[3];
                  delay(2);
                  P2=~0xff;
                  P0=~0x00;
                  else                                                  //如果開始鍵沒有按下,則顯示F FF(若有違規(guī)者,則顯示違規(guī)號碼及 FF)或時間調(diào)整
                  {if(flag4==1)                                         //違規(guī)顯示
                     {if(num!=0)
                            {P0=table1[num];                                //顯示幾號違規(guī)了
                                  P2=table2[0];
                                  delay(2);
                                  P0=~0x00;
                                  P2=~0xff;
                                  P0=table1[15];                                   //下面顯示 FF,表示違規(guī)了
                                  P2=table2[2];
                                  delay(2);
                                  P0=~0x00;                                            //消隱
                                  P2=~0xff;
                                  P0=table1[15];
                                  P2=table2[3];
                                  delay(2);
                                  P0=~0x00;
                                  P2=~0xff;
                                  P0=~0x00;
                                  P2=~0xff;}
                                  else                                                 //沒有人違規(guī)才顯示調(diào)整時間
                                  {if(aa==1)
                                            P0=~0x76;                                           //第一位數(shù)碼管顯示"5(S)"(表示搶答時間調(diào)整)
                                                P2=table2[0];
                                                delay(2);
                                                P0=~0x00;
                                                P2=~0xff;
                                                P0=table1[time1/10];                               //下面顯示調(diào)整的搶答時間
                                        P2=table2[2];
                                                delay(2);
                                                P0=~0x00;
                                                P2=~0xff;
                                                P0=table1[time1%10];
                                                P2=table2[3];
                                                delay(2);
                                                P0=~0x00;
                                                P2=~0xff;
                                                else if(bb==1)
                                                {P0=~0x38;                               //第一位與第二位數(shù)碼管合起來顯示"T",表示答題 時間調(diào)整
                                                  P2=table2[0];
                                                  delay(2);
                                                  P0=~0x00;
                                                  P2=~0xff;
                                                  P0=table1[time2/10];
                                                  P2=table2[2];
                                                  delay(2);
                                                  P0=~0x00;
                                                  P2=~0xff;
                                                  P0=table1[time2%10];
                                                  P2=table2[3];
                                                  delay(2);
                                                  P0=~0x00;
                                                  P2=~0xff;
                                                 else                                  //否則顯示F FF
                                                 {P0=table1[15];
                                                   P2=table2[0];
                                                   delay(2);
                                                   P0=~0x00;
                                                   P0=table1[15];
                                                   P2=table2[2];
                                                   delay(2);
                                                   P0=~0x00;                             //消隱
                                                   P2=~0xff;
                                                   P0=table1[15];
                                                   P2=table2[3];
                                                   delay(2);
                                                   P0=~0x00;
                                                   P2=~0xff;
{uchar i=100;
  init();                                                           //調(diào)用初始化子函數(shù)
    {key1();                                                        //調(diào)用開始鍵掃描子函數(shù)
          if((flag1==0)&(flag2==1))                                           //違規(guī)
             {key();
                    if(num!=0)                                                    //開始鍵沒有按下時,有人按下了搶答器,則置違規(guī)標(biāo)志位
                          {flag4=1;
                             D0=0;
          if((flag1==1)&(flag2==1))                                           //如果開始鍵按下且搶答鍵沒有人按下,則進(jìn)行八路 搶答鍵掃描
              {key();}
                  display();                                                      //顯示到數(shù)碼管上
                                   //定時器0中斷子函數(shù)
void t0() interrupt 1
{TH0=(65536-2000)/256;//2ms
  if(flag3)        //開始(START)鍵按下,嘟一聲(長1秒),表示開始搶答
    beep=~beep;
         beep=1;
        if(s<5)        //搶答時間快到報警,隔1秒響一聲且紅燈閃爍,響三聲
        {if(s%2==0)
           {flag3=1;
             D0=0;}
           {flag3=0;
              D0=1;}
          m++;
          if(m==500)//1秒
            {m=0;
                  s--;
                  flag3=0;                                                            //關(guān)閉開始鍵按下響一秒的嘟聲
                  if(s==-1)
                    {s=20;
                          TR0=0;
                          flag1=0;                                                        //顯示F FF
                          flag2=1;
                          num=0;
                          D0=1;}
                                  //定時器1中斷子函數(shù)
void t1() interrupt 3                                                           //定時器1處理有人按下?lián)尨鹌鬣揭宦?長1秒)
   {TH1=(65536-2000)/256;
         beep=~beep;
         n++;
         if(n==500)
            {n=0;TR1=0;}
全部資料51hei下載地址:
單片機(jī).zip (53.98 KB, 下載次數(shù): 62)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏3 分享淘帖 頂 踩
