查看: 1835|回復: 2
為什么這個pwm調不了速度,而是會停了在動,現在測試的是循跡前兩個,大神幫我改進...
ID:439927 發表于 2018-12-10 12:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
100黑幣
#include<reg52.h>
#define uint usigned int
#define zuo_qian IN1 = 1; IN2 = 0
#define zuo_hou  IN1 = 0; IN2 = 1
#define you_qian IN3 = 0; IN4 = 1
#define you_hou  IN3 = 1; IN4 = 0
//????????λ??
sbit zuo   = P0^1;
sbit zhong = P0^2;
sbit you   = P0^3;
//????in1~4,????io??
sbit IN1 = P1^1;
sbit IN2 = P1^2;
sbit IN3 = P1^3;
sbit IN4 = P1^4;
sbit ENA = P1^5;
sbit ENB = P1^6;
sbit led = P1^0;
uchar zkb_zuo = 0;
uchar zkb_you = 0;
uchar t = 0;
void timer()
TMOD = 0x01; //????????λ????????
TH0 = (65535-100)/256;
TH0 = (65535-100)%256;
ET0 = 1;
TR0 = 1;
//??pwm???ε??????100???ж??????ж?100us?????pwm??????????????б???zkb_????
void timer0() interrupt 1
TH0 = (65535-100)/256;//?????趨???
if(t<zkb_zuo)//?????????t????????????????????
  ENA = 1;
  ENA = 0;//?????1/100
if(t<zkb_you)//?????????t????????????????????
  ENB = 1;
  ENB = 0;//?????1/100
t++;
if(t>=100)
  t = 0;
??1 ??1  ??1
  0  1  1  ????? ?????
  0  0  1  ????? С????
  1  0  1  ???
  1  0  0  ????? С????
  1  1  0  ????? ?????
void xunji()
if((zuo==1)&&(zhong==0))
  zkb_zuo = 100;
  zkb_you = 100;
  zuo_hou;
  you_qian;
  led = 0;
else if((zuo==1)&&(zhong==1))
  zkb_zuo = 40;
  zkb_you = 100;
  zuo_qian;
  you_qian;
  led = 1;
/* if((zuo==0)&&(zhong==1))
  led = 0;
else if((zuo==0)&&(zhong==0))
  led = 1;
else if((zuo==0)&&(zhong==1)&&(you==1))
  zkb_zuo = 20;
  zkb_you = 100;
  zuo_hou;
  you_qian;
else if((zuo==1)&&(zhong==0)&&(you==1))
  zkb_zuo = 80;
  zkb_you = 80;
  zuo_qian;
  you_qian;
else if((zuo==1)&&(zhong==0)&&(you==0))
  zkb_zuo = 20;
  zkb_you = 100;
  zuo_qian;
  you_hou;
else if((zuo==1)&&(zhong==1)&&(you==0))
  zkb_zuo = 100;
  zkb_you = 100;
  zuo_qian;
  you_hou;
timer();//??????????
EA=1;//?????ж?
  xunji();
ID:439927 發表于 2018-12-11 08:19 | 只看該作者
急救大神,我是小白,想弄個循跡小車
ID:424741 發表于 2018-12-11 09:46 | 只看該作者
我也是小白,請問差速的程序是怎樣寫的啊?比如要寫左轉,左邊的輪子速度20,右邊的輪子速度80,請問要怎樣寫。求大神指教。
