查看: 5632|回復: 0
單片機驅動兩相三線制步進電動機Proteus仿真+代碼
這是兩相三線制的步進電動機的例子
  1. #include "AT89X51.h"
  2. int delay();
  3. void inti_lcd();
  4. void show_lcd(int);
  5. void cmd_wr();
  6. void ShowState();
  7. void clock(unsigned int Delay) ;
  8. void DoSpeed();       //計算速度
  9. //正轉值
  10. #define RIGHT_RUN 1
  11. //反轉值
  12. #define LEFT_RUN 0
  13. sbit RS=0xA0;
  14. sbit RW=0xA1;
  15. sbit E=0xA2;
  16. char SpeedChar[]="SPEED(n/min):";
  17. char StateChar[]="RUN STATE:";
  18. char STATE_CW[]="CW";
  19. char STATE_CCW[]="CCW";
  20. char SPEED[3]="050";
  21. unsigned int RunSpeed=50;                //速度
  22. unsigned char RunState=RIGHT_RUN;  //運行狀態
  23. main()
  24. {
  25.
  26.         /*定時器設置*/
  27.         TMOD=0x66;            //定時器0,1都為計數方式;方式2;
  28.         EA=1;                        //開中斷
  29.
  30.         TH0=0xff;                //定時器0初值FFH;
  31.         TL0=0xff;
  32.         ET0=1;
  33.         TR0=1;
  34.
  35.         TH1=0xff;                //定時器1初值FFH;
  36.         TL1=0xff;
  37.         ET1=1;
  38.         TR1=1;
  39.
  40.         IT0=1;                        //脈沖方式
  41.         EX0=1;                        //開外部中斷0:加速
  42.         IT1=1;                        //脈沖方式
  43.         EX1=1;                        //開外部中斷1:減速
  44.
  45.     inti_lcd();
  46.     DoSpeed();
  47.     ShowState();
  48.     while(1)
  49.     {
  50.       clock(RunSpeed);
  51.       P0_1=P0_1^0x01;
  52.     }
  53.
  54. }
  55. //定時器0中斷程序:正轉
  56. void t_0(void) interrupt 1
  57. {
  58.         RunState=RIGHT_RUN;
  59.     P0_0=1;
  60.     P1=0x01;
  61.     cmd_wr();
  62.     ShowState();
  63. }
  64. //定時器1中斷:反轉
  65. void t_1(void) interrupt 3
  66. {
  67.         RunState=LEFT_RUN;
  68.     P0_0=0;
  69.     P1=0x01;
  70.     cmd_wr();
  71.     ShowState();
  72.
  73. }
  74. //中斷0:加速程序
  75. void SpeedUp() interrupt 0
  76. {
  77.        if(RunSpeed>=12)
  78.           RunSpeed=RunSpeed-2;
  79.        DoSpeed();
  80.        P1=0x01;
  81.        cmd_wr();
  82.        ShowState();
  83.
  84. }
  85. //中斷1:減速程序
  86. void SpeedDowm() interrupt 2
  87. {
  88.
  89.     if(RunSpeed<=100)
  90.         RunSpeed=RunSpeed+2;
  91.     DoSpeed();
  92.     P1=0x01;
  93.     cmd_wr();
  94.     ShowState();
  95.
  96. }
  97. int delay()         //判斷LCD是否忙
  98. {
  99.     int a;
  100. start:
  101.
  102.     RS=0;
  103.     RW=1;
  104.     E=0;
  105.     for(a=0;a<2;a++);
  106.     E=1;
  107.     P1=0xff;
  108.     if(P1_7==0)
  109.        return 0;
  110.     else
  111.        goto start;
  112. }
  113. void inti_lcd()  //設置LCD方式
  114. {
  115.    P1=0x38;
  116.    cmd_wr();
  117.    delay();
  118.    P1=0x01;     //清除
  119.    cmd_wr();
  120.    delay();
  121.    P1=0x0f;
  122.    cmd_wr();
  123.    delay();
  124.    P1=0x06;
  125.    cmd_wr();
  126.    delay();
  127.    P1=0x0c;
  128.    cmd_wr();
  129.    delay();
  130. }
  131. void cmd_wr()           //寫控制字
  132. {
  133.    RS=0;
  134.    RW=0;
  135.    E=0;
  136.    E=1;
  137. }
  138. void show_lcd(int i)   //LCD顯示子程序
  139. {
  140.    P1=i;
  141.    RS=1;
  142.    RW=0;
  143.    E=0;
  144.    E=1;
  145. }
  146. void ShowState()    //顯示狀態與速度
  147. {
  148.     int i=0;
  149.     while(SpeedChar[i]!='\0')
  150.     {
  151.        delay();
  152.        show_lcd(SpeedChar[i]);
  153.        i++;
  154.     }
  155.
  156.     delay();
  157.     P1=0x80 | 0x0d;
  158.     cmd_wr();
  159.     i=0;
  160.     while(SPEED[i]!='\0')
  161.     {
  162.        delay();
  163.        show_lcd(SPEED[i]);
  164.        i++;
  165.     }
  166.     delay();
  167.     P1=0xC0;
  168.     cmd_wr();
  169.     i=0;
  170.     while(StateChar[i]!='\0')
  171.     {
  172.        delay();
  173.        show_lcd(StateChar[i]);
  174.        i++;
  175.     }
  176.     delay();
  177.     P1=0xC0 | 0x0A;
  178.     cmd_wr();
  179.     i=0;
  180.     if(RunState==RIGHT_RUN)
  181.         while(STATE_CW[i]!='\0')
  182.         {
  183.           delay();
  184.           show_lcd(STATE_CW[i]);
  185.           i++;
  186.         }
  187.     else
  188.        while(STATE_CCW[i]!='\0')
  189.         {
  190.           delay();
  191.           show_lcd(STATE_CCW[i]);
  192.           i++;
  193.         }
  194. }
  195. void clock(unsigned int Delay)   //1ms延時程序
  196. {  unsigned int i;
  197.    for(;Delay>0;Delay--)
  198.     for(i=0;i<124;i++);
  199.
  200. }
  201. void DoSpeed()
  202. {
  203.     SPEED[0]=(1000*6/RunSpeed/100)+48;
  204.     SPEED[1]=1000*6/RunSpeed%100/10+48;
  205.     SPEED[2]=1000*6/RunSpeed%10+48;
  206. }
步進電機控制,LCD顯示.zip (45.22 KB, 下載次數: 61)
