查看: 1378|回復: 1
智能玩具小車C程序
ID:442104 發(fā)表于 2018-12-8 13:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
智能玩具小車練習C程序
編程器的讀寫軟件借助編程器,可以讀出未加密的單片機程序。
#include <reg51.h>
#include <intrins.h>
#define FOSC 18432000L
#define BAUD 9600
#define T1MS (65536-FOSC/1000)
#define T1MS (65536-FOSC/12/1000)
typedef unsigned char uchar;
typedef unsigned int uint;
#define URMD 0
sfr T2H = 0xd6;
sfr T2l = 0xd7;
sfr AUXR  = 0x8e;
sfr ADC_CONTR = 0xbc;
sfr ADC_RES   = 0xdb;
sfr ADC_LOW2  = 0xbe;
sfr P1ASF     = 0x9d;
#define ADC_POWER 0x80
#define ADC_FLAG  0X10
#define ADC_START 0x80
#define ADC_SPEEDLL 0x00
#define ADC_SPEEDL 0x20
#define ADC_SPEEDH 0x40
#define ADC_SPEEDHH 0x60
sbit P32 = P3^2;  //電機驅動口
sbit P10 = P1^0;
uint i=0,a,time_1=0,time_2=0;
uchar AD[5]={255,255,255,255,255};
void Delay(uint n)
    uint x;
    while(a--)
        x = 5000;
        while(x--);
void InitADC()
    P1ASF = 0xff;
    ADC_RES = 0;
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    Delay(2);
uchar GetADCResult(uchar ch)
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    while(!(ADC_CONTR & ADC_FLAG));
    ADC_CONTR &= ~ADC_FLAG;
    return ADC_RES;
void TIMER0_init()
    AUXR |= 0x80;
    AUXR &= 0x7f;
    TMOD = 0x01;
    TL0 = T1MS;
    TH0 = T1MS/256;
    TR0 = 1;
    ET0 = 1;
    EA  = 1;    //中斷配置    定時器延時1ms
    InitADC();
    TIMER0_init();
    P32 = 1    ;
   // P10 = 1;
void timer0() interrupt 1     //interrupt:表示此函數(shù)為中斷服務程序 interrupt 1 為定時器中斷0
    TL0 = T1MS;
    TH0 = T1MS/256;
    time_1++;
    if (time_1 == 2850  ) {
       time_1=0;
       P32 = 0;
       AD[i] = GetADCResult(0);
       if( (AD[0] == 0) && (AD[1] == 0) && (AD[2] == 0) && (AD[3] == 00) && (AD[4] == 00) && (ADC_LOW2 ==0) )    {
          P32 = 0;
          TR0 = 1;
       i++;
       if ( i == 6 )
          i=0;
       time_2++;
       if (time_2 ==1) {
          time_2 = 0;
          P32 = 0;
          TR0 = 1;
小車程序.doc
17.5 KB, 下載次數(shù): 3, 下載積分: 黑幣 -5
ID:1 發(fā)表于 2018-12-9 01:42 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
