查看: 4563|回復: 0
Proteus仿真STM32,提示Access to register of unclocked peripheral at 0x40000000...
ID:441966 發表于 2018-12-8 09:28 | 顯示全部樓層 |閱讀模式
用proteus仿真STM32,用定時器控制LED燈閃爍,加載運行的時候老是提示Access to register of unclocked peripheral at 0x40000000 cause BUS_FAULT [U1_CM3CORE],有知道怎么解決的嗎。
