智能循跡小車程序
#include<reg52.h>
//D0-D7:f,b,a,e,d,h,c,g 共陰依次編碼
//74LS04反相器驅(qū)動數(shù)碼管
uchar code table[10] = {0x5F,0x42,0x9E,0xD6,0xC3,0xD5,0xDD,0x46,0xDF,0xD7};
uchar i = 0; //用于0-3數(shù)碼管輪流顯示
uint j = 0; //計時的次數(shù)
uint time=0; //計時
uint pwm=16; //占空比
uint speed; //調(diào)制PWM波的當(dāng)前的值
sbit R=P3^2; //右邊傳感器P3^2
sbit L=P3^3; //左邊傳感器P3^3
//電機驅(qū)動口定義
sbit E NB=P1^0; //前輪電機停止控制使能
sbit E NA=P1^1; //后輪控制調(diào)速控制端口
sbit I N1=P1^2; //前輪
sbit I N2=P1^3; //前輪
sbit I N3=P1^4; //后輪
sbit I N4=P1^5; //后輪
void Init()
TMOD = 0x12; //定時器0用方式2,定時器1用方式1
TH0=(256-200)/256; //pwm
TL0=(256-200)/256;
TH1 = 0x0F8; //定時2ms
TL1 = 0x30;
EA = 1;
ET0 = 1;
ET1 = 1;
TR0 = 1;
TR1 = 1;
void tim0(void) interrupt 1 //產(chǎn)生PWM
speed ++;
if(speed <= pwm) //pwm 就相當(dāng)于占100的比例
ENA = 1;
else if(speed < 100)
ENA = 0;
speed = 0;
void time1() interrupt 3 //定時2ms
TH1 = 0x0F8;
TL1 = 0x30;
i =(i+1) % 4; //0-3循環(huán)
j++;
if(i == 0) //顯示最低位數(shù)碼管
P0 = 0x00; //段選清零防止亂碼
P0 = table[time%10]; //送段碼信號
if(i == 1)
P0 = 0x00;
P0 = table[time/ 10% 10];
if(i == 2)
P0 = 0x00;
P0 = table[time/ 100% 10];
if(i == 3)
P0 = 0x00;
P0 = table[time/ 1000% 10];
P2 = ( 0x10 << i ); //送位選信號
if(j == 500)
time ++; //500次為1秒
j = 0;
void forward() //前進(jìn)
IN2=1;
IN1=0;
void back() //后退
IN2=0;
IN1=1;
void left() //左轉(zhuǎn)
ENB=1; //打開使能
IN3=1;
IN4=0;
void right() //右轉(zhuǎn)
ENB=1; //打開使能
IN3=0;
IN4=1;
void stop() //停止
IN2=0;
IN1=0;
IN3=0;
IN4=0;
Init(); //定時器初始化
if(R==0 && L==1) //右傳感器檢測到黑線
right(); //右轉(zhuǎn)
forward();
while(R==0 && L==1);
if(R==1 && L==0) //左傳感器檢測到黑線
left();
forward();
while(R==1 && L==0);
if(R==0 && L==0) //都檢測到黑線則停止
stop();
j = 0; //定時器仍在工作,計數(shù)時間清空}
else //都沒有檢測到黑線
ENB = 0; //關(guān)閉轉(zhuǎn)向控制
forward();
