/////////////////////////// 紅外發(fā)射代碼 ///////////////////////////
#include <reg51.h>
sbit rfot=P1^6; //紅外線輸出
sbit akey=P1^2; //A鍵輸入
sbit bkey=P1^3; //B鍵輸入
sbit ckey=P1^4; //C鍵輸入
sbit dkey=P1^5; //D鍵輸入
void delay_ms(uint xms) //延時(shí)子函數(shù)1ms*xms
uint i,j;
for(i=xms;i>0;i--)
for(j=127;j>0;j--);
void delay_112() //紅外線延時(shí)函數(shù),延時(shí)1.12毫秒
uint m,n;
for(m=1;m>0;m--)
for(n=142;n>0;n--);
void delay_56() //紅外線延時(shí)函數(shù),延時(shí)0.56毫秒
uint m,n;
for(m=1;m>0;m--)
for(n=70;n>0;n--);
void delay_50() //紅外線延時(shí)函數(shù),延時(shí)0.5毫秒
uint m,n;
for(m=1;m>0;m--)
for(n=64;n>0;n--);
void bit_boot()
rfot=0; delay_ms(9);
rfot=1;
delay_ms(4);
delay_50();
void a_key() //A鍵編碼
uint i;
bit_boot();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_56();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0; delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112(); //用戶碼
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56(); //用戶反碼
rfot=0;
delay_ms(1);
rfot=1;
void b_key() //B鍵編碼
uint i;
bit_boot();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_56();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0; delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112(); 用戶碼
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56(); 用戶反碼
rfot=0;
delay_ms(1);
rfot=1;
void c_key() //C鍵編碼
uint i;
bit_boot();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_56();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0; delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112(); 用戶碼
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56(); 用戶反碼
rfot=0;
delay_ms(1);
rfot=1;
void d_key() //D鍵編碼
uint i;
bit_boot();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_56();
for(i=0;i<8;i++)
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0; delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_112(); 用戶碼
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_112();
rfot=0;
delay_56();
rfot=1;
delay_56();
rfot=0;
delay_56();
rfot=1;
delay_56(); 用戶反碼
rfot=0;
delay_ms(1);
rfot=1;
void init()
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
void keyscan() //鍵盤掃描程序
if(akey==0)
delay_ms(5);
if(akey==0)
a_key();
while(!akey);
if(bkey==0)
delay_ms(5);
if(bkey==0)
b_key();
while(!bkey);
if(ckey==0)
delay_ms(5);
if(ckey==0)
c_key();
while(!ckey);
if(dkey==0)
{ delay_ms(5);
if(dkey==0)
d_key();
while(!dkey);
TR0=~TR0;
void main() //程序從這里開始
init();
keyscan();
void T0_time()interrupt 1
/////////////////////////// 紅外接收代碼 ///////////////////////////
#include <reg51.h>
sbit rfin=P3^7; //紅外線輸入
uint i,j;
for(i=xms;i>0;i--)
for(j=127;j>0;j--);
uint m,n;
for(m=1;m>0;m--)
for(n=142;n>0;n--);
uint m,n;
for(m=1;m>0;m--)
for(n=70;n>0;n--);
uint m,n;
for(m=1;m>0;m--)
for(n=64;n>0;n--);
void delay_35() //紅外線延時(shí)函數(shù),延時(shí)0.35毫秒
{ uint m,n;
for(m=1;m>0;m--)
for(n=60;n>0;n--);
void delay_30() //紅外線延時(shí)函數(shù),延時(shí)0.30毫秒
uint m,n;
for(m=1;m>0;m--)
for(n=41;n>0;n--);
void delay_25() //紅外線延時(shí)函數(shù),延時(shí)0.25毫秒
uint m,n;
for(m=1;m>0;m--)
for(n=26;n>0;n--);
uchar i,j,k,temp,m;
uchar usercode,user_code,datecode,date_code;
//k=0;
//temp=0;
//rfin=0;
if(rfin==0)
for(m=0;m<10;m++) //跳過9mS引導(dǎo)區(qū)
if(rfin==0)
delay_56();
delay_30();
if(rfin==1) //跳過4.5mS引導(dǎo)區(qū)
delay_ms(4);
delay_50();
if(rfin==0);
{ delay_56;
delay_56;
delay_30;
for(i=0;i<4;i++)
temp=0;
k=1;
for(j=0;j<9;j++)
if(rfin==0)
k=0;
if(rfin==1)
k=1;
temp=(temp<<1)|k;
if(rfin==0)
delay_25();
if(rfin==1);
delay_56();
delay_30();
if(rfin==1)
delay_35();
if(rfin==1);
delay_56();
delay_30();
switch (i)
case 0: usercode=temp; //用戶碼數(shù)據(jù)寄存器
break;
case 1: user_code=temp; //用戶反碼數(shù)據(jù)寄存器
break; case 2: datecode=temp; //數(shù)據(jù)碼數(shù)據(jù)寄存器
break;
case 3: date_code=temp; //數(shù)據(jù)反碼數(shù)據(jù)寄存器
break;
P1=datecode; //將數(shù)據(jù)碼送入P1端口點(diǎn)亮LED
