- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit key_k1=P3^1;
- sbit key_k2=P3^0;
- sbit key_k3=P3^2;
- sbit key_k4=P3^3;
- uchar i,count;
- uchar code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- void delayms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void init()
- P0=0x00;
- P0=smgduan[i];
- LSA=0;LSB=0;LSC=0;
- delayms(5);
- P0=0x00;
- P0=smgduan[i];
- LSA=1;LSB=0;LSC=0;
- delayms(5);
- P0=0x00;
- P0=smgduan[i];
- LSA=0;LSB=1;LSC=0;
- delayms(5);
- P0=0x00;
- P0=smgduan[i];
- LSA=1;LSB=1;LSC=0;
- delayms(5);
- TMOD=0x01;//定時(shí)器0,工作模式1
- TH0=(65535-45872)/256;
- TL0=(65535-45872)%256;
- TR0=0;//啟動(dòng)定時(shí)器0
- void main()
- init();
- while(1)
- if(TF0==1)
- TF0=0;
- count++;
- if(count==2)
- count=0;
- i++;
- if(i>15)
- i=0;
- if(key_k1==0)
- delayms(5);
- if(key_k1==0)
- TR0=1; //啟動(dòng)定時(shí)器0
- while(!key_k1);
- if(key_k2==0)
- delayms(5);
- if(key_k2==0)
- TR0=0; //停止定時(shí)器0
- while(!key_k2);
復(fù)制代碼 |
開發(fā)板原理.pdf
2018-12-4 17:40 上傳
點(diǎn)擊文件名下載附件
404.98 KB, 下載次數(shù): 5
