#include<reg51.h> //頭文件
#include<LCD1602.h>
#include<ADC0832.h>
#include<EEPROM.h>
#include<INTERRUPT.h>
/*****************燈、蜂鳴器、按鍵引腳定義******************/
sbit led=P1^7; //LED燈(紅)
sbit buzz=P2^3; //蜂鳴器
sbit key_set=P1^0; //設(shè)置鍵
sbit key_jia=P1^3; //加鍵
sbit key_jian=P1^6; //減鍵
/*****************全局變量定義******************************/
#define K_MG_MV 2
#define IN_V 500
long ALValue;
uchar K_ZERO;
uint jiujia_up,zuijia_up;
uint set_f;
uchar num;
函數(shù)名稱:void fixed_display()
函數(shù)作用:固定顯示部分
參數(shù)說明:
lcd1602_write_character(0,1,"ALcohol content:");
lcd1602_write_character(8,2,"PPM");
函數(shù)名稱:void display1()
函數(shù)作用:顯示實際濃度值
參數(shù)說明:
void display1()
fixed_display();
if(K_ZERO+2>ADC_date)
K_ZERO=ADC_date;
ALValue=(long)IN_V*(ADC_date-K_ZERO)/255;
if(ALValue<0)
ALValue=0;
ALValue=ALValue*K_MG_MV;
LCD_disp_char(5,2,ASCII[ALValue/100]);
LCD_disp_char(6,2,ASCII[ALValue%100/10]);
LCD_disp_char(7,2,ASCII[ALValue%10]);
if(zuijia_up<=AVlalue)
led=0;
buzz=0;
if(jiujia_up<=ALValue)
led=0;
buzz=1;
led=1;
buzz=1;
函數(shù)名稱:void display2(void)
函數(shù)作用:顯示設(shè)置時酒駕、醉駕上限值
參數(shù)說明:
void display2(void)
num++;
if(num==254)
num=0;
lcd1602_write_character(0,1,"Jiujia Limit:");
lcd1602_write_character(0,2,"Ziujia Limit:");
if(num%2==0)
LCD_disp_char(13,1,ASCII[jiujia_up/100]);
LCD_disp_char(14,1,ASCII[jiujia_up%100/10]);
LCD_disp_char(15,1,ASCII[jiujia_up%10]);
LCD_disp_char(13,1,ASCII[ziujia_up/100]);
LCD_disp_char(13,1,ASCII[ziujia_up%100/10]);
LCD_disp_char(13,1,ASCII[ziujia_up%10]);
if(set_f==1)
LCD_disp_char(13,1,ASCII[13]);
LCD_disp_char(14,1,ASCII[13]);
LCD_disp_char(15,1,ASCII[13]);
if(set_f==2)
LCD_disp_char(13,2,ASCII[13]);
LCD_disp_char(14,2,ASCII[13]);
LCD_disp_char(15,2,ASCII[13]);
函數(shù)名稱:void delayms(uint ms)
函數(shù)作用:毫秒延時函數(shù)
參數(shù)說明:
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
函數(shù)名稱:void scan(void)
函數(shù)作用:按鍵檢測及處理
參數(shù)說明:
void scan(void)
//設(shè)置鍵,不支持連按
if(key_set==00)
delayms(7);
if(key_set==0)
led=1;
buzz=1;
if(set_f==0)
LCD_write_command(0x01);
delay_n40us(100);
display2();
set_f++;
if(set_f==3)
set_f=0;
EEPROM_delete(0x2002);
EEPROM_write(0x2002,jiujia_up/100);
EEPROM_write(0x200a,jiujia_up%100);
EEPROM_delete(0x2202);
EEPROM_write(0x2202,zuijia_up/100);
EEPROM_write(0x220a,zuijia_up%100);
delay_n40us(100);
fixed_display();
while(!key_set);
//加值鍵,支持連續(xù)
if(key_jia==0&&set_f!=0)
delayms(7);
if(key_jia==0set_f==1)
if(jiujia_up<999&&jiujia_up<zuijia_up-1)
jiujia_up++;
display2();
if(key_jia==0&&set_f==2)
if(zuijia_up<999)
zuijia_up++;
display2();
//減值鍵,支持連續(xù)
if(key_jian==0&&set_f!=0)
delayms(7);
if(key_jian==0set_f==1)
if(jiujia_up!=0)
jiujia_up--;
display2();
if(zuijia_up!=0&&zuijia_up>jiujia_up+1)
zuijia_up--;
display2();
函數(shù)名稱:void main()
函數(shù)作用:主函數(shù)
參數(shù)說明:
uchar i=0;
T0_init();
LCD_init();
/*EEPROM_delete(0x2002);
EEPROM_write(0x2002,80/100);
EEPROM_write(0x200a,80%100);
jiujia_up=EEPROM_read(0x2002);
jiujia_up=jiujia_up*100+EEPROM_read(0x200a);
/*EEPROM_delete(0x2202);
EEPROM_write(0x2202,150/100);
EEPROM_write(0x220a,150%100);
ziujia_up=EEPROM_read(0x2202);
ziujia_up=ziujia_up*100+EEPROM_read(0x220a);
while(!wait_f)
lcd1602_write_character(0,1,"Please wait for!");
LCD_disp_char(6,2,ASCII[(60-time)/10]);
LCD_disp_char(7,2,ASCII[(60-time)%10]);
LCD_disp_char(9,2,s);
ADC0832_read(0);
K_ZERO=ADC_date;
/*ADC0832_read(0);
LCD_disp_char(0,2,ASCII[K_ZERO/100]);
LCD_disp_char(1,2,ASCII[K_ZERO%100/10]);
LCD_disp_char(2,2,ASCII[K_ZERO%10]);//*/
scan();
if(set_f==0)
i++;
if(i>50)
ADC0832_read(0);
i=0;
display1();
display2();
