查看: 1252|回復(fù): 0
VHDL 7段顯示譯碼程序設(shè)計(jì)
ID:438444 發(fā)表于 2018-12-3 15:24 | 顯示全部樓層 |閱讀模式
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY DecL777 IS
PORT(A:IN STD_LOGIC_VECTOR(3 DOWNTO 0);
          LED7S:OUT STD_LOGIC_VECTOR(6 DOWNTO 0));
END ENTITY DecL777;
ARCHITECTURE one OF DecL777 IS
BEGIN
PROCESS(A)
BEGIN
                CASE A(3 DOWNTO 0) IS
                  WHEN "0000"=>LED7S<="0111111";
                  WHEN "0001"=>LED7S<="0000110";
                  WHEN "0010"=>LED7S<="1011011";
                  WHEN "0011"=>LED7S<="1001111";
                  WHEN "0100"=>LED7S<="1100110";
                  WHEN "0101"=>LED7S<="1101101";
                  WHEN "0110"=>LED7S<="1111101";
                  WHEN "0111"=>LED7S<="0000111";
                  WHEN "1000"=>LED7S<="1111111";
                  WHEN "1001"=>LED7S<="1101111";
                  WHEN "1010"=>LED7S<="1110111";
                  WHEN "1011"=>LED7S<="1111100";
                  WHEN "1100"=>LED7S<="0111001";
                  WHEN "1101"=>LED7S<="1011110";
                  WHEN "1110"=>LED7S<="1111001";
                  WHEN "1111"=>LED7S<="1110001";
                  WHEN OTHERS=>LED7S<="0000000";
END CASE;
END PROCESS;
END ARCHITECTURE one;
