查看: 1479|回復(fù): 0
51中斷實(shí)現(xiàn)秒表
ID:405758 發(fā)表于 2018-12-3 14:16 | 顯示全部樓層 |閱讀模式
51單片機(jī)實(shí)現(xiàn)秒表計(jì)時(shí)完整代碼
#include <at89x52.h>
#include <intrins.h>
unsigned int count;
unsigned char cntr = 0;
unsigned char tab[]= {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f, 0x76};
unsigned char sj[2];
void bcdconvers()
        sj[0] = count / 10;
        sj[1] = count % 10;
void delay()
        unsigned int y ;
        for (y = 0; y < 10000; y++);
void display()
        unsigned char i, wei;
        wei = 0xfe;
        for(i = 0; i < 2; i++)
                P2 = 0xff;
                P0 = tab[sj[i]];
                P2 = wei;
                delay();
                wei = (wei << 1) + 1;
        TMOD = 0x01;
        TH0 = -50000 >> 8;
        TL0 = -50000;
        EA = 1;
        IT0=1;
        IT1=1;
        ET0 = 1;
        TR0 = 1;
        EX0=1;
        while (1)
                bcdconvers();
                display();
void T1PRG() interrupt 1
        TH0 = -50000 >> 8;
        TL0 = -50000;
        if (cntr == 20)
                count++;
                cntr = 0;
                cntr++;
        if (count >= 60)
                count = 0;
void key_0() interrupt 0
        count = count + 10;
        if (count >= 60)
                count = count - 60;
void key_1() interrupt 2
        count++;
        if (count >= 60)
                count = count - 60;
參與人數(shù) 1黑幣 +50 收起 理由
