查看: 3642|回復: 4
STM32L151外接3.6864MHz晶振,時鐘怎么還是32M?
ID:305865 發表于 2018-11-29 21:45 | 顯示全部樓層 |閱讀模式
愧為新手,公司有個以前做的項目,拿到前人留下的程序,想學習學習。剛上來就被時鐘搞混了。
這塊板子用的是STM32L151,外接3.6864MHz晶振,OSC32IN和OSC32out沒接晶振。這塊板子需要精確延時的。
按我理解,時鐘應該是3.6864*8/2=14.7456M,但是我看代碼里還是基于8M來設置的。
RCC_GetClocksFreq(&RCC_Clocks);      //獲取系統時鐘頻率,外部晶振8.00M,倍頻后系統時鐘8.000*8/2=32.00M
注釋是說外部晶振8M,可實際上沒有接8M,只接的是3.6864MHz晶振。
對應的RCC_GetClocksFreq如下:
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
  uint32_t tmp = 0, pllmul = 0, plldiv = 0, pllsource = 0, presc = 0, msirange = 0;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & RCC_CFGR_SWS;
  switch (tmp)
    case 0x00:  /* MSI used as system clock */
      msirange = (RCC->ICSCR & RCC_ICSCR_MSIRANGE ) >> 13;
      RCC_Clocks->SYSCLK_Frequency = (((1 << msirange) * 64000) - (MSITable[msirange] * 24000));
      break;
    case 0x04:  /* HSI used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSI_VALUE;
      break;
    case 0x08:  /* HSE used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSE_VALUE;
      break;
    case 0x0C:  /* PLL used as system clock */
      /* Get PLL clock source and multiplication factor ----------------------*/
      pllmul = RCC->CFGR & RCC_CFGR_PLLMUL;
      plldiv = RCC->CFGR & RCC_CFGR_PLLDIV;
      pllmul = PLLMulTable[(pllmul >> 18)];
      plldiv = (plldiv >> 22) + 1;
      pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
      if (pllsource == 0x00)
        /* HSI oscillator clock selected as PLL clock entry */
        RCC_Clocks->SYSCLK_Frequency = (((HSI_VALUE) * pllmul) / plldiv);
        /* HSE selected as PLL clock entry */
        RCC_Clocks->SYSCLK_Frequency = (((HSE_VALUE) * pllmul) / plldiv);
      break;
    default:
      break;
在system_stm32lxx.c里,看到倍頻分頻設置值跟外接8M一樣,幾乎沒改動。
    /*  PLL configuration: PLLCLK = (HSE * 8) / 2 = 32MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMUL |
                                        RCC_CFGR_PLLDIV));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMUL8 | RCC_CFGR_PLLDIV2);
我揣測是利用的內部的HSI 8M來計算的,我在相關代碼里沒找到使用HSI的語句,郁悶啊。也沒有發現用此晶振3.6864MHz晶振代替系統默認的8M。 哪位懇請幫理一下。新手琢磨了幾天了,對RCC還是有點糊涂。
ID:305865 發表于 2018-11-30 14:27 | 顯示全部樓層
自己頂一下。
ID:432182 發表于 2018-12-18 08:51 | 顯示全部樓層
用標準庫開發,使用外部時鐘,將庫函數stm32lxx.h里的8M改為3.6864M
ID:219315 發表于 2019-1-7 15:26 | 顯示全部樓層
關注學校中。
ID:192176 發表于 2021-1-1 20:25 | 顯示全部樓層
樓主解決了嗎?
