查看: 1123|回復: 0
關于用socket實現一個超簡單的爬蟲
ID:436060 發表于 2018-11-29 20:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#僅供參考
import socket
import ssl
import re
import os
url = "http://csse.xjtlu.edu.cn/classes/CSE205/"
protocol = url.split('://')[0]
u = url.split('://')[1]
i = u.find('/')
host = u[:i]
path = u[i:]
file_path='D:\\{}'.format(host)
def  get_html(url):
    if protocol =='https':
        sock= ssl.wrap_socket(socket.socket())
        port = 443
    else:
        sock = socket.socket()
        port = 80
    sock.connect((host,port))
    request = 'GET {} HTTP/1.1\r\nhost:{}\r\n\r\n'.format(path, host)
    print( request)
    sock.send(request.encode())
    response = b''
    buffer_size = 1024
    while True:
        r = sock.recv(buffer_size)
        response += r
        if len(r) < buffer_size:
            break
    response = response.decode()
    print(response)
    return response
def get_img(response):
    imgre = re.compile(r"""<img\s.*?\s?src\s*=\s*['|"]?([^\s'"]+).*?>""",re.I)
    imglist = re.findall(imgre,response)
    for src in imglist:
            sock2= ssl.wrap_socket(socket.socket())
            port = 443
        else:
            sock2= socket.socket()
            port = 80
        sock2.connect((host,port))
        request2='GET {}{} HTTP/1.1\r\nhost:{}\r\n\r\n'.format(path,src,host)
        print(request2)
        sock2.send(request2.encode())
        response2 = b''
        buffer_size = 1024
        while True:
            r = sock2.recv(buffer_size)
            response2 += r
                break
        data=response2.split("\r\n\r\n".encode())[1]
        src=src.replace('/','.');
        file_path='D:\\{}\{}'.format(host,src)
        with open (file_path,'wb') as f:
            f.write(data)
def mkdir(file_path):
    isExists=os.path.exists(file_path)
    if not isExists:
        os.makedirs(file_path)
        return True
    else:
        return False
mkdir(file_path)
response = get_html(url)
get_img(response)
